0 Replies Latest reply on Mar 7, 2011 2:38 AM by fingertrouble
    Crashing problem EXC_BAD_ACCESS (SIGABRT)
    fingertrouble
      Crashing reporter is offline/page not found?
      Have a problem with After Effects CS5 crashing randomly - here's the logs from the last two:
      Is it a corrupted font? I have removed one with was a serious error, but want to resolve this as it's slowing my work down.
      Process:         After Effects [2850]
      Path:            /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/MacOS/After Effects
      Identifier:      com.adobe.AfterEffects
      Version:         10.0.1 (10.0)
      Code Type:       X86-64 (Native)
      Parent Process:  launchd [233]
      Date/Time:       2011-03-03 13:17:42.585 +0000
      OS Version:      Mac OS X 10.6.6 (10J567)
      Report Version:  6
      Exception Type:  EXC_BAD_ACCESS (SIGABRT)
      Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Application Specific Information:
      abort() called
      Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
      0   libSystem.B.dylib                 0x00007fff80be9616 __kill + 10
      1   libSystem.B.dylib                 0x00007fff80c89cca abort + 83
      2   U.dylib                           0x0000000102a89867 U_LoadFrameworkBundle + 695
      3   libSystem.B.dylib                 0x00007fff80bfb67a _sigtramp + 26
      4   ???                               0x00007fff5fbfdf50 0 + 140734799798096
      5   ...e.AfterEffectsLib.framework    0x0000000100b51982 CRQRenderSettings::SetRS_FromPref(int) + 61698
      6   ...e.AfterEffectsLib.framework    0x0000000100b529a4 CRQRenderSettings::SetRS_FromPref(int) + 65828
      7   ...e.AfterEffectsLib.framework    0x0000000100b5a20b CRQRenderSettings::SetRS_FromPref(int) + 96651
      8   ...e.AfterEffectsLib.framework    0x0000000100b498f9 CRQRenderSettings::SetRS_FromPref(int) + 28793
      9   ...e.AfterEffectsLib.framework    0x0000000100a1d7e3 COutlineDir::GetOutlinePano() + 23411
      10  ...e.AfterEffectsLib.framework    0x0000000100a1ff45 COutlineDir::GetOutlinePano() + 33493
      11  ...e.AfterEffectsLib.framework    0x0000000100af0811 CTLOutlinePano::CenterCurrentTimeIfNecessary() + 8865
      12  ...e.AfterEffectsLib.framework    0x00000001006d4679 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 393
      13  ...e.AfterEffectsLib.framework    0x00000001006d4594 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 164
      14  ...e.AfterEffectsLib.framework    0x00000001006d4594 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 164
      15  ...e.AfterEffectsLib.framework    0x0000000100702ad8  dvacore::utility::SearchLiveHelp(std::basic_string<unsigned short,  std::char_traits<unsigned short>, std::allocator<unsigned  short> >) + 7480
      16  ...e.AfterEffectsLib.framework    0x0000000100a17c0e GetCEffects(BEE_Layer*) + 67326
      17  com.adobe.dvaui.framework         0x00000001031d9822  dvaui::ui::UI_Node::UI_DispatchMouseEventToLeaf(dvaui::ui::UI_Node*,  dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&) + 146
      18  com.adobe.dvaui.framework         0x00000001031dc7d5  dvaui::ui::UI_Node::DispatchMouseEvent::operator()(dvaui::ui::UI_Node*,  dvaui::ui::UI_Node*, dvacore::geom::PointT<float> const&)  const + 165
      19  com.adobe.dvaui.framework         0x00000001031e6243  std::pair<bool, dvaui::ui::UI_Node*>  dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeafT<dvaui::ui::UI_Node::DispatchMouseEv ent>(dvaui::ui::UI_Node::DispatchMouseEvent&,  dvacore::geom::PointT<float> const&, bool) + 131
      20  com.adobe.dvaui.framework         0x00000001031e0613  dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeaf(dvaui::ui::MouseEvent  const&, bool) + 83
      21  com.adobe.dvaui.framework         0x00000001031e1dcf  dvaui::ui::UI_Node::UI_DispatchMouseEventToTarget(dvaui::ui::UI_Node*,  dvaui::ui::MouseEvent const&, bool) + 159
      22  com.adobe.dvaui.framework         0x00000001031e1eb4  dvaui::ui::UI_Node::UI_DispatchMouseEvent(dvaui::ui::MouseEvent  const&, bool) + 68
      23  com.adobe.dvaui.framework         0x0000000103255433  dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent  const&, bool) + 595
      24  com.adobe.dvaui.framework         0x0000000103251249  dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_Event  const&) + 313
      25  com.adobe.dvaui.framework         0x00000001032578a2 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 450
      26  com.adobe.dvaui.framework         0x000000010324238f dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 31
      27  com.adobe.dvaui.framework         0x000000010324808b dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 59
      28  com.adobe.dvacore.framework       0x0000000102d4de16 int  dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*,  void*) + 38
      29  ...e.AfterEffectsLib.framework    0x0000000100663396 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5382
      30  ...e.AfterEffectsLib.framework    0x00000001006634c1 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5681
      31  com.adobe.dvacore.framework       0x0000000102d4ccf5 void  dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>,  bool*) + 197
      32  com.adobe.dvacore.framework       0x0000000102d4ec83 void  dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>,  bool*) + 99
      33  com.adobe.dvaui.framework         0x000000010324b34d -[DVAMacContainerView mouseDown:] + 253
      34  com.apple.AppKit                  0x00007fff882d934f -[NSWindow sendEvent:] + 5409
      35  com.apple.AppKit                  0x00007fff8820ea86 -[NSApplication sendEvent:] + 4719
      36  com.adobe.dvaui.framework         0x0000000103243d6f -[DVAMacApplication sendEvent:] + 223
      37  ...e.AfterEffectsLib.framework    0x0000000100470f73 0x10046a000 + 28531
      38  com.apple.AppKit                  0x00007fff881a54da -[NSApplication run] + 474
      39  ...e.AfterEffectsLib.framework    0x00000001006b74a2  PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char  const*, char const*, PT_TrackerEntryPoints const*) + 16386
      40  ...e.AfterEffectsLib.framework    0x000000010066181c SetAPETerminateFunc(boost::function<void ()()> const&) + 1308
      41  ...e.AfterEffectsLib.framework    0x0000000100661ee4 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 84
      42  com.adobe.AfterEffects            0x00000001000043b8 main + 1144
      43  com.adobe.AfterEffects            0x0000000100003895 _start + 227
      44  com.adobe.AfterEffects            0x00000001000037b1 start + 33
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib                 0x00007fff80bb416a kevent + 10
      1   libSystem.B.dylib                 0x00007fff80bb603d _dispatch_mgr_invoke + 154
      2   libSystem.B.dylib                 0x00007fff80bb5d14 _dispatch_queue_invoke + 185
      3   libSystem.B.dylib                 0x00007fff80bb583e _dispatch_worker_thread2 + 252
      4   libSystem.B.dylib                 0x00007fff80bb5168 _pthread_wqthread + 353
      5   libSystem.B.dylib                 0x00007fff80bb5005 start_wqthread + 13
      Thread 2:
      0   libSystem.B.dylib                 0x00007fff80bd5fca __semwait_signal + 10
      1   libSystem.B.dylib                 0x00007fff80bd9de1 _pthread_cond_wait + 1286
      2   com.adobe.amt.services            0x000000010dd23c53 AMTConditionLock::LockWhenCondition(int) + 37
      3   com.adobe.amt.services            0x000000010dd1ccce _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 92
      4   com.adobe.amt.services            0x000000010dd23cbe AMTThread::Worker(void*) + 28
      5   libSystem.B.dylib                 0x00007fff80bd4536 _pthread_start + 331
      6   libSystem.B.dylib                 0x00007fff80bd43e9 thread_start + 13
      Thread 3:
      2   ...ple.CoreServices.CarbonCore    0x00007fff8291ce27 TSWaitOnCondition + 118
      3   ...ple.CoreServices.CarbonCore    0x00007fff8288c310 TSWaitOnConditionTimedRelative + 177
      4   ...ple.CoreServices.CarbonCore    0x00007fff8288621b MPWaitOnQueue + 215
      5   ...e.Frameworks.ASL.Foundation    0x0000000104dc2080 ASL::(anonymous namespace)::TaskProc(void*) + 96
      6   ...ple.CoreServices.CarbonCore    0x00007fff8285e411 PrivateMPEntryPoint + 63
      7   libSystem.B.dylib                 0x00007fff80bd4536 _pthread_start + 331
      8   libSystem.B.dylib                 0x00007fff80bd43e9 thread_start + 13
      Thread 4:
      5   AdobeACE                          0x0000000108eff18d 0x108ec5000 + 237965
      6   AdobeACE                          0x0000000108efeb3a 0x108ec5000 + 236346
      7   ...ple.CoreServices.CarbonCore    0x00007fff8285e411 PrivateMPEntryPoint + 63
      8   libSystem.B.dylib                 0x00007fff80bd4536 _pthread_start + 331
      9   libSystem.B.dylib                 0x00007fff80bd43e9 thread_start + 13
      Thread 5:
      Thread 6:
      Thread 7:
      5   com.adobe.dvacore.framework       0x0000000102db5a1f  dvacore::threads::(anonymous  namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue>  const&, boost::shared_ptr<dvacore::threads::Gate> const&)  + 143
      6   com.adobe.dvacore.framework       0x0000000102d4ed5e boost::function0<void>::operator()() const + 46
      7   com.adobe.dvacore.framework       0x0000000102dade53  dvacore::threads::(anonymous namespace)::LaunchThread(std::string  const&, boost::function0<void> const&,  dvacore::threads::ThreadPriority, boost::function<void ()()>  const&, boost::function<void ()()> const&) + 99
      8   ...obe.boost_threads.framework    0x0000000107fd4ac4 thread_proxy + 132
      9   libSystem.B.dylib                 0x00007fff80bd4536 _pthread_start + 331
      10  libSystem.B.dylib                 0x00007fff80bd43e9 thread_start + 13
      Thread 8:
      Thread 9:
      Thread 10:
      Thread 11:
      Thread 12:
      Thread 13:
      Thread 14:
      1   ...dobe.dvatransport.framework    0x0000000107d2ec4e boost::asio::detail::kqueue_reactor<false>::run(bool) + 478
      2   ...dobe.dvatransport.framework    0x0000000107d2fd05  boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false>  >::run(boost::system::error_code&) + 517
      3   ...dobe.dvatransport.framework    0x0000000107d0d8cc SkyConnectionEnv::MainLoop() + 76
      4   ...dobe.dvatransport.framework    0x0000000107d0d939 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
      5   ...obe.boost_threads.framework    0x0000000107fd4ac4 thread_proxy + 132
      6   libSystem.B.dylib                 0x00007fff80bd4536 _pthread_start + 331
      7   libSystem.B.dylib                 0x00007fff80bd43e9 thread_start + 13
      Thread 15:
      2   ...dobe.dvatransport.framework    0x0000000107d2fe3f  boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false>  >::run(boost::system::error_code&) + 831
      3   ...dobe.dvatransport.framework    0x0000000107d30a35  boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service<boost::asio ::ip::tcp>::work_io_service_runner>::run()  + 53
      4   ...dobe.dvatransport.framework    0x0000000107d15c79 asio_detail_posix_thread_function + 25
      Thread 16:
      Thread 17:
      Thread 18:
      Thread 19:
      2   com.adobe.AfterEffects.MThread    0x00000001282fea8f main + 20783
      3   com.adobe.dvacore.framework       0x0000000102d4ed5e boost::function0<void>::operator()() const + 46
      4   com.adobe.dvacore.framework       0x0000000102dade53  dvacore::threads::(anonymous namespace)::LaunchThread(std::string  const&, boost::function0<void> const&,  dvacore::threads::ThreadPriority, boost::function<void ()()>  const&, boost::function<void ()()> const&) + 99
      Thread 20:
      Thread 21:
      Thread 22:
      Thread 23:
      Thread 24:
      2   com.adobe.AfterEffects.OpenEXR    0x000000012a0814c6 IlmThread::Semaphore::wait() + 70
      3   com.adobe.AfterEffects.OpenEXR    0x000000012a08033c IlmThread::(anonymous namespace)::WorkerThread::run() + 188
      4   libSystem.B.dylib                 0x00007fff80bd4536 _pthread_start + 331
      5   libSystem.B.dylib                 0x00007fff80bd43e9 thread_start + 13
      Thread 25:
      Thread 26:
      Thread 27:
      Thread 28:
      1   libSystem.B.dylib                 0x00007fff80bd5e59 nanosleep + 148
      2   ...dobe.AfterEffects.Scripting    0x000000012ab08c7b zcfree + 197989
      3   ...dobe.AfterEffects.Scripting    0x000000012aaebc93 zcfree + 79229
      4   ...dobe.AfterEffects.Scripting    0x000000012ab08d76 zcfree + 198240
      Thread 29:
      2   com.adobe.adobeswfl               0x000000012b3da89d APXGetHostAPI + 2465805
      3   com.adobe.adobeswfl               0x000000012b1935e9 APXGetHostAPI + 77145
      4   com.adobe.adobeswfl               0x000000012b3da9b1 APXGetHostAPI + 2466081
      5   com.adobe.adobeswfl               0x000000012b3dad1a APXGetHostAPI + 2466954
      6   com.adobe.adobeswfl               0x000000012b3dae49 APXGetHostAPI + 2467257
      Thread 30:
      Thread 31:
      Thread 32:
      Thread 33:
      0   libSystem.B.dylib                 0x00007fff80b9b2da mach_msg_trap + 10
      1   libSystem.B.dylib                 0x00007fff80b9b94d mach_msg + 59
      2   com.apple.CoreFoundation          0x00007fff81c12932 __CFRunLoopRun + 1698
      3   com.apple.CoreFoundation          0x00007fff81c11dbf CFRunLoopRunSpecific + 575
      4   com.apple.CoreMediaIOServices     0x00007fff85e7b62b MIO::DAL::RunLoop::OwnThread(void*) + 147
      5   com.apple.CoreMediaIOServices     0x00007fff85e7d1f6 CAPThread::Entry(CAPThread*) + 140
      Thread 34:
      0   libSystem.B.dylib                 0x00007fff80b9b33a semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib                 0x00007fff80bd9cd2 _pthread_cond_wait + 1015
      2   com.adobe.adobeswfl               0x000000012b3da869 APXGetHostAPI + 2465753
      3   com.adobe.adobeswfl               0x000000012b3f70ec APXGetHostAPI + 2582620
      Thread 35:
      3   com.adobe.adobeswfl               0x000000012b574ef3 APXGetHostAPI + 4146787
      Thread 36:
      2   libtbb.dylib                      0x000000010001222c tbb::internal::GenericScheduler::wait_while_pool_is_empty() + 92
      3   libtbb.dylib                      0x000000010001cb84  tbb::internal::CustomScheduler<tbb::internal::IntelSchedulerTraits>::wait_for_all(tbb::ta sk&,  tbb::task*) + 1858
      4   libtbb.dylib                      0x0000000100014e3a tbb::internal::GenericScheduler::worker_routine(void*) + 632
      Thread 37:
      Thread 38:
      Thread 39:
      Thread 40:
      2   ...e.AfterEffectsLib.framework    0x00000001006a901e  ae::egg::KeyboardEvent::KeyboardEvent(dvaui::ui::KeyboardEvent  const&) + 40558
      3   ...e.AfterEffectsLib.framework    0x00000001006abe26  ae::egg::KeyboardEvent::KeyboardEvent(dvaui::ui::KeyboardEvent  const&) + 52342
      4   com.adobe.dvacore.framework       0x0000000102d4ed5e boost::function0<void>::operator()() const + 46
      5   com.adobe.dvacore.framework       0x0000000102dade53  dvacore::threads::(anonymous namespace)::LaunchThread(std::string  const&, boost::function0<void> const&,  dvacore::threads::ThreadPriority, boost::function<void ()()>  const&, boost::function<void ()()> const&) + 99
      6   ...obe.boost_threads.framework    0x0000000107fd4ac4 thread_proxy + 132
      Thread 41:
      0   libSystem.B.dylib                 0x00007fff80b9b32e semaphore_timedwait_trap + 10
      1   ...ple.CoreServices.CarbonCore    0x00007fff828f31f2 MPWaitOnSemaphore + 96
      2   MultiProcessor Support            0x0000000125ce7bd1 ThreadFunction(void*) + 69
      3   ...ple.CoreServices.CarbonCore    0x00007fff8285e411 PrivateMPEntryPoint + 63
      Thread 42:
      Thread 43:
      Thread 44:
      2   com.BorisFX.bcc_ae_8bit           0x00000001373b5563 XSyncEvent::WaitForEvent(int) + 131
      3   com.BorisFX.bcc_ae_8bit           0x00000001374ba94b OGL::Thread::Process() + 155
      4   com.BorisFX.bcc_ae_8bit           0x00000001373b5752 XSyncThreadTask(void*) + 18
      Thread 45:
      5   com.BorisFX.bcc_ae_8bit           0x0000000136a6be31 Queue::Wait(long*, Job**, int) + 17
      6   com.BorisFX.bcc_ae_8bit           0x0000000137184f3d BankQueue::DoMPTask(Task*) + 77
      7   com.BorisFX.bcc_ae_8bit           0x00000001371850a3 Task::MPTask(void*) + 19
      8   ...ple.CoreServices.CarbonCore    0x00007fff8285e411 PrivateMPEntryPoint + 63
      Thread 46:
      Thread 47:
      Thread 48:
      Thread 49:  com.apple.CFSocket.private
      0   libSystem.B.dylib                 0x00007fff80bdee92 select$DARWIN_EXTSN + 10
      1   com.apple.CoreFoundation          0x00007fff81c34498 __CFSocketManager + 824
      2   libSystem.B.dylib                 0x00007fff80bd4536 _pthread_start + 331
      3   libSystem.B.dylib                 0x00007fff80bd43e9 thread_start + 13
      Thread 50:
      Thread 51:
      2   com.apple.audio.CoreAudio         0x00007fff831b967c CAGuard::WaitFor(unsigned long long) + 168
      3   com.apple.audio.CoreAudio         0x00007fff831bbc0b CAGuard::WaitUntil(unsigned long long) + 185
      4   com.apple.audio.CoreAudio         0x00007fff831b9d75 HP_IOThread::WorkLoop() + 1369
      5   com.apple.audio.CoreAudio         0x00007fff831b9817 HP_IOThread::ThreadEntry(HP_IOThread*) + 9
      6   com.apple.audio.CoreAudio         0x00007fff831b9745 CAPThread::Entry(CAPThread*) + 125
      Thread 52:
      0   libSystem.B.dylib                 0x00007fff80bb4f8a __workq_kernreturn + 10
      1   libSystem.B.dylib                 0x00007fff80bb539c _pthread_wqthread + 917
      2   libSystem.B.dylib                 0x00007fff80bb5005 start_wqthread + 13
      Thread 53:
      Thread 54:
      Thread 0 crashed with X86 Thread State (64-bit):
         rax: 0x0000000000000000  rbx: 0x00007fff5fbfdab0  rcx: 0x00007fff5fbfda88  rdx: 0x0000000000000000
         rdi: 0x0000000000000b22  rsi: 0x0000000000000006  rbp: 0x00007fff5fbfdaa0  rsp: 0x00007fff5fbfda88
          r8: 0x0000000102a96760   r9: 0x0000000000000001  r10: 0x00007fff80be5656  r11: 0x0000000000000206
         r12: 0x00007fff5fbfdac0  r13: 0x00007fff5fbfe180  r14: 0x00000001b0f21c50  r15: 0x000000010eaa6410
         rip: 0x00007fff80be9616  rfl: 0x0000000000000206  cr2: 0x00007fff80c74436
      Binary Images:
              0x100000000 -        0x100004ff3 +com.adobe.AfterEffects 10.0.1  (10.0) <6B57EDE6-8898-E72E-05C0-D54EA9E78EF7> /Applications/Adobe  After Effects CS5/Adobe After Effects CS5.app/Contents/MacOS/After  Effects
              0x100009000 -        0x100022feb +libtbb.dylib ??? (???)  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/libtbb.dylib
              0x100033000 -        0x100039feb +libtbbmalloc.dylib ??? (???)  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/libtbbmalloc.dylib
              0x100040000 -        0x10004cff5  +com.adobe.boost_signals.framework boost_signals version 5.0.0  (5.0.0.213330) <7C5184BC-4FE9-56D9-CAE9-49D669C6108B>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
              0x10005e000 -        0x10005ffff  +com.adobe.boost_system.framework boost_system version 5.0.0  (5.0.0.213330) <5B2E6816-3C31-78F7-A163-368475286EDA>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
              0x100065000 -        0x10006cff3  +com.adobe.boost_date_time.framework boost_date_time version 5.0.0  (5.0.0.213330) <784431BB-1A4A-5F0F-4641-0541FE7F4430>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
              0x10007c000 -        0x100081ffd +com.adobe.AdobeCrashReporter  3.0 (3.0.20100302) <DFFB9A08-8369-D65F-161F-7C61D562E307>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
              0x100086000 -        0x1001c9fef +WRServices ??? (???)  <DD50D315-C0EC-C729-AC67-92588187E8C7> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
              0x100215000 -        0x100319fef +hydra_filters ??? (???)  <177463AB-3833-13B3-20B3-7B228BE9BC9C> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/hydra_filters.framework/Versions/A/hydra_filters
              0x10040e000 -        0x10042cfff +image_runtime ??? (???)  <5896DB90-E23E-5C6E-98E5-8E52698ACE61> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
              0x100466000 -        0x100467fff +ALOG.dylib ??? (???)  <247DF308-661D-FC7A-4A53-C8EA58CB478C> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ALOG.dylib
              0x10046a000 -        0x100e3efef  +com.adobe.AfterEffectsLib.framework AfterFXLib 1.0 (1.0)  <8B3C384E-FD17-7C25-FC5B-2D226C5A30DA> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AfterFXLib.framework/Versions/A/AfterFXLib
              0x101197000 -        0x101197ff7 +AEFX.dylib ??? (???)  <87957ABB-824B-D113-11F1-E9950FBC356E> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AEFX.dylib
              0x10119a000 -        0x101555fe7 +BEE.dylib ??? (???)  <C494E8DB-1734-E409-6792-B49FD70F809F> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BEE.dylib
              0x10179e000 -        0x1017adff3 +BEZ.dylib ??? (???)  <D478437D-E3E9-DF6F-C269-E4786331B205> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BEZ.dylib
              0x1017b1000 -        0x1017bcff3 +BM.dylib ??? (???)  <C3D22738-E352-F136-7EFB-FCA84A8DF3F2> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BM.dylib
              0x1017c3000 -        0x1017fefff +COR.dylib ??? (???)  <82A66D1C-3411-28F7-55E4-44F5B23CD179> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/COR.dylib
              0x10181a000 -        0x10183aff7 +FILE.dylib ??? (???)  <8D94218F-3D12-5DD1-F7ED-995E32F320D7> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FILE.dylib
              0x101848000 -        0x101875fff +FLO.dylib ??? (???)  <5ADDC857-45E8-C8CD-38BC-9B1745179E60> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FLO.dylib
              0x10187b000 -        0x10193efff +FLT.dylib ??? (???)  <2902EB47-A004-31D1-DC5F-A0E2FF8FECE7> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FLT.dylib
              0x1019a1000 -        0x1019a8ff3 +LIST.dylib ??? (???)  <EBCE800F-92A6-6DE5-A588-25C7ABE134B1> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/LIST.dylib
              0x1019ac000 -        0x1019bffff +M.dylib ??? (???)  <9C5728D1-8641-C50C-65A8-B32357F2C3E6> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/M.dylib
              0x1019c4000 -        0x1019cdff7 +MC.dylib ??? (???)  <D14CEF04-2834-3D70-2EA8-80D122832D00> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MC.dylib
              0x1019d4000 -        0x101a34fff +MSK.dylib ??? (???)  <E7026CA5-C04F-79F5-FCBC-4EDD42404683> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MSK.dylib
              0x101a48000 -        0x101a5fff7 +OM.dylib ??? (???)  <24285638-08B3-5017-BB4C-C352BD01B3A6> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/OM.dylib
              0x101a67000 -        0x101a89ff7 +P.dylib ??? (???)  <3ADABBEF-01A7-DC39-A53D-BA41C3FA402D> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/P.dylib
              0x101a92000 -        0x101ddbfff +PF.dylib ??? (???)  <F5764ECA-0A0D-468F-3320-CDF9E32862F2> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PF.dylib
              0x101e17000 -        0x102020fef +PIN.dylib ??? (???)  <0C3F81B8-33B7-D233-3296-1BF9B878761D> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PIN.dylib
              0x1020a1000 -        0x1020bbfff +PLUG.dylib ??? (???)  <C4AAFD62-C761-417D-2E19-1282372830A3> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PLUG.dylib
              0x1020c6000 -        0x1020d9fff +PR.dylib ??? (???)  <80E85C07-A375-A91F-8062-88AA924AE278> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PR.dylib
              0x1020e0000 -        0x1020e6fff +PREF.dylib ??? (???)  <86484BE5-76F4-4732-7131-8B22A4AB6B47> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PREF.dylib
              0x1020ea000 -        0x102102fff +RG.dylib ??? (???)  <73804179-7CFE-B9EB-FE60-28386D472CC3> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RG.dylib
              0x10210b000 -        0x10210dff7 +RI.dylib ??? (???)  <A4E4E647-4A64-F605-00DD-40954ED0AA00> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RI.dylib
              0x102110000 -        0x102111fff +RND.dylib ??? (???)  <CFA19218-EE1C-869B-CB20-A2AC8875CD94> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RND.dylib
              0x102118000 -        0x102177ff7 +SLU.dylib ??? (???)  <AD49A5CA-0E54-5427-850E-7C1F6CE19A8D> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SLU.dylib
              0x10219d000 -        0x1021b9ffd +SND.dylib ??? (???)  <A030E529-FE40-6952-0E2F-116BB4896D6C> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SND.dylib
              0x1021c1000 -        0x1021c4ff1 +STR.dylib ??? (???)  <6AEB75A1-DC87-589A-9260-B8F8D0FF0186> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/STR.dylib
              0x1021c8000 -        0x1021cbfff +T.dylib ??? (???)  <56B3122B-B555-5DE2-578C-28E07782987E> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/T.dylib
              0x1021ce000 -        0x10220bff5 +TDB.dylib ??? (???)  <F9C692F8-04DE-AF9B-1043-6ED200788D4A> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/TDB.dylib
              0x10221f000 -        0x1028cafe5 +TXT.dylib ??? (???)  <2406D646-4453-6A1E-E760-9259539A793D> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/TXT.dylib
              0x102a69000 -        0x102aa5ff1 +U.dylib ??? (???)  <F11F145C-1AF8-9E01-6BA9-CC2914BB8F64> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/U.dylib
              0x102ab9000 -        0x102abdfff +VAL.dylib ??? (???)  <643F797E-4BA9-7A56-AD6D-30213837097D> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VAL.dylib
              0x102ac0000 -        0x102b70fff +com.adobe.exo.framework exo  version 5.0.0 (5.0.0.213330)  <E4327151-F451-DD21-0696-CC980D027822> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/exo.framework/Versions/A/exo
              0x102c77000 -        0x102c9dff3 +PREM.dylib ??? (???)  <FF94B54D-43D7-D3C8-D9CA-CF3C27E676E0> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PREM.dylib
              0x102cb1000 -        0x102d0afff +FRP.dylib ??? (???)  <590CA539-77C5-3671-821F-EE1A4B1DF5C5> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FRP.dylib
              0x102d27000 -        0x102e85ff7 +com.adobe.dvacore.framework  dvacore version 5.0.0 (5.0.0.213330)  <2ED41E92-CA4E-F981-0A73-EECDD22BAE5D> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
              0x102ff9000 -        0x103340ff7 +com.adobe.dvaui.framework dvaui  version 5.0.0 (5.0.0.213330)  <26699551-C5FE-77C5-D6B9-0C6034B41E3F> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
              0x103701000 -        0x1037affff  +com.adobe.dvaworkspace.framework dvaworkspace version 5.0.0  (5.0.0.213330) <705E0390-9563-FA39-9AD1-4328B2C9E1C0>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
              0x10388b000 -        0x1038abfef  +com.adobe.dvaunittesting.framework dvaunittesting version 5.0.0  (5.0.0.213330) <7ADEF3C2-30B8-547F-3E1D-BB80B4D6509A>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
              0x1038d4000 -        0x1038e4ff8 +com.adobe.ahclientframework  1.5.0.30 (1.5.0.30) <5D6FFC4E-7B81-3E8C-F0D4-66A3FA94A837>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
              0x1038ef000 -        0x103967fef +com.adobe.adobe_caps adobe_caps  3.0.116.0 (3.0.116.0) <4A355686-1451-B19A-0C55-DFE49FD2539E>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
              0x10397d000 -        0x1039e2fff +aif_core ??? (???)  <568D781D-2C64-2929-2D54-4D5ED733BA5A> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
              0x103a24000 -        0x103c53fff +aif_ogl ??? (???)  <8B39A818-2295-27C0-C7CC-23205863A910> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
              0x103e17000 -        0x103e2dfff +data_flow ??? (???)  <773FBF60-436C-D83C-70C3-DF184CE733AE> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
              0x103e60000 -        0x104355fef +image_compiler ??? (???)  <B5099546-A56B-24C4-F073-37A7AE81AA24> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/image_compiler.framework/Versions/A/image_compiler
              0x104895000 -        0x10492bfff +image_flow ??? (???)  <2752F430-8256-E728-D11B-5F0734CD3D0D> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
              0x104a11000 -        0x104a50ff7  +com.adobe.dynamiclinkui.framework dynamiclinkui version 5.0.0  (5.0.0.213330) <BD01B92F-BA04-F1A9-6155-1B42C24C4526>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
              0x104aa6000 -        0x104c6ffff +com.adobe.dynamiclink.framework  dynamiclink version 5.0.0 (5.0.0.213330)  <B56BCABE-8A7D-DFC3-F188-63102A103BEA> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
              0x104d8d000 -        0x104defff5  +com.adobe.MediaCore.Frameworks.ASL.Foundation 1.0 (1.0)  <8A37AB47-7613-9C3E-227F-7D9B7BC874E9> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
              0x104ed6000 -        0x104eecfff +ASLMessaging ??? (???)  <FF6E2081-5AFD-3A38-E302-E59229FD8C1D> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
              0x104f0b000 -        0x104f1cffe +ASLUnitTesting ??? (???)  <B08CF505-E518-72F2-6BD3-2F8220F4A9D8> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
              0x104f34000 -        0x104f4eff3  +com.adobe.MediaCore.Frameworks.AudioFilterHost 1.0 (1.0)  <77D98EE7-4093-301B-31C8-6304642AC4DE> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
              0x104f76000 -        0x104faefff  +com.adobe.MediaCore.Frameworks.AudioFilters ??? (1.0)  <78471468-4C7F-0CF6-140D-798FCAF1AECB> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
              0x105019000 -        0x105091fe3  +com.adobe.MediaCore.Frameworks.AudioRenderer ??? (1.0)  <D121C229-4251-5D3A-595F-650A02AE5B90> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
              0x10512c000 -        0x10516afe1  +com.adobe.MediaCore.Frameworks.AudioSupport 1.0 (1.0)  <B082D5D2-92C2-4038-3583-6E624C2A0533> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
              0x1051b3000 -        0x105c24fef  +com.adobe.MediaCore.Frameworks.Backend ??? (1.0)  <0BB48068-8E97-BF23-C679-6AE5DFDCD49B> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
              0x10694b000 -        0x106aefff3  +com.adobe.MediaCore.Frameworks.ImageRenderer ??? (1.0)  <B4CCC972-CADD-7751-7F46-7F28674F4DBF> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
              0x106c1f000 -        0x106da9ff7  +com.adobe.MediaCore.Frameworks.ImporterHost 1.0 (1.0)  <F34576C9-5DF6-9085-4804-8C5A074A512E> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
              0x106f6b000 -        0x106f9ffff +com.adobe.MediaFoundation ???  (1.0) <2237E626-39E2-4FC7-0886-7385E9A0D827> /Applications/Adobe  After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
              0x106fe2000 -        0x106fe5fff  +com.adobe.MediaCore.Frameworks.MediaUtils 1.0 (1.0)  <DE5FE590-E42C-70DA-0872-6FB725861729> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
              0x106fea000 -        0x106febfff  +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0)  <E6A57F34-8922-5D13-B6BE-1D53C0675555> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
              0x106ff0000 -        0x10702bfff  +com.adobe.MediaCore.Frameworks.MLFoundation 1.0 (1.0)  <F9C61C12-0EA0-EA53-5AF0-81381E8C782B> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
              0x10707b000 -        0x1070adfff  +com.adobe.MediaCore.Frameworks.PluginSupport 1.0 (1.0)  <D60E282B-70B2-2A0F-AFAE-EC4C84AE27CB> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
              0x1070ec000 -        0x1070edfff +PRM ??? (???)  <BDF8EC3E-8EA0-FCB1-8A7B-38CEF4020BE1> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
              0x1070f1000 -        0x107129fff  +com.adobe.MediaCore.Frameworks.SweetPeaSupport 1.0 (1.0)  <CD2EBF6A-F10E-2B20-9F57-D6F49E5883B0> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
              0x10717a000 -        0x1071c3fff +com.adobe.MediaCore.VideoFrame  1.0 (1.0) <271EA98F-DEB4-932F-3F78-1E76BFE5B8F1>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
              0x107211000 -        0x10732dfff  +com.adobe.MediaCore.Frameworks.VideoRenderer 1.0 (1.0)  <3DA8F0D4-6E35-7EE4-EA45-E31F3B4D34FB> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
              0x107497000 -        0x10753ffe1 +com.adobe.dvaeve.framework  dvaeve version 5.0.0 (5.0.0.213330)  <3320F862-69F9-91B9-77B3-58638E9A5F57> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
              0x10763c000 -        0x1076affff  +com.adobe.MediaCore.Frameworks.PlayerHost 1.0 (1.0)  <B285C74F-2478-5536-7936-CD061F43A182> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
              0x10774a000 -        0x10781cfff  +com.adobe.MediaCore.Frameworks.VideoFilterHost 1.0 (1.0)  <6A71B201-FF19-4B17-E188-48B7AE5F3A3E> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
              0x1078df000 -        0x107949ff7 +com.adobe.amtlib amtlib  3.0.0.64 (3.0.0.64) <6B2F73C2-10AB-08B3-4AB0-A31C83D1E5E0>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
              0x10797c000 -        0x107a1aff2 +libicucnv.dylib.36.0 36.0.0  (compatibility 36.0.0) <5651FB7C-24ED-8CC8-2ADE-A5CB7CA493C3>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
              0x107a3a000 -        0x107a55fff +libicudata.dylib.36.0 36.0.0  (compatibility 36.0.0) <FEF83A1C-8D48-66B4-BED6-B91835D1AA68>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
              0x107a58000 -        0x107ab2fff +com.adobe.dvametadata.framework  dvametadata version 5.0.0 (5.0.0.213330)  <18F7D94A-F4DB-1721-FBDF-1ED970BCF942> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
              0x107b34000 -        0x107bb8fff  +com.adobe.dvametadataUI.framework dvametadataUI version 5.0.0  (5.0.0.213330) <73A09435-12CC-3B38-8681-B72FED6E4D9D>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
              0x107c4f000 -        0x107c93ff7  +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 5.0.0  (5.0.0.213330) <83DDA3DF-57A0-AEDF-2793-685ABA6E8CCE>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
              0x107cb3000 -        0x107cccfff  +com.adobe.dvamediatypes.framework dvamediatypes version 5.0.0  (5.0.0.213330) <5859F2A1-3BFC-8EAD-F008-AF0333FF44B8>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
              0x107ceb000 -        0x107d61ff7  +com.adobe.dvatransport.framework dvatransport version 5.0.0  (5.0.0.213330) <DA8FFA3F-BD11-2EE7-A974-228F49E1652D>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
              0x107de4000 -        0x107e20ff3 +com.adobe.dvamarshal.framework  dvamarshal version 5.0.0 (5.0.0.213330)  <625FCBA1-47B3-DAD5-C15B-78E572F6717A> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
              0x107e8c000 -        0x107e9afff  +com.adobe.MediaCore.Frameworks.ProjectSupport 1.0 (1.0)  <57A965FC-3754-BFB3-A1D0-253D5B39E901> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
              0x107eae000 -        0x107ef1fff +DynamicLinkMedia ??? (???)  <FF94B2FF-93A5-623E-04A6-125572A95FE3> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
              0x107f5e000 -        0x107f5eff7  libmx.A.dylib 315.0.0  (compatibility 1.0.0) <B146C134-CE18-EC95-12F8-E5C2BCB43A6B>  /usr/lib/libmx.A.dylib
              0x107f61000 -        0x107f8cff6 +AdobeAXE8SharedExpat ??? (???)  <F5C1010B-CAFF-5290-8B55-6FEB3A287225> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
              0x107f9e000 -        0x107fa4ff7  com.apple.agl 3.0.12  (AGL-3.0.12) <1AB34F57-2E8D-42FB-A484-5CCB928CA456>  /System/Library/Frameworks/AGL.framework/Versions/A/AGL
              0x107fab000 -        0x107fc8fff +AdobeBIB ??? (???)  <3FF7BFF2-52DF-046A-A081-2BDB1055A1B4> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
              0x107fd2000 -        0x107fdaff3  +com.adobe.boost_threads.framework boost_threads version 5.0.0  (5.0.0.213330) <50E5F61F-42D9-1F4D-EBF7-47BE6A864A73>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
              0x107fe9000 -        0x10803ffeb  +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011)  <03B80698-2C3B-A232-F15F-8F08F8963A19> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
              0x108084000 -        0x108142ffb +filter_graph ??? (???)  <3C2316AB-7ACF-A257-97EF-33E00FD5AC67> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/filter_graph.framework/Versions/A/filter_graph
              0x10826a000 -        0x1082c8ffd +AdobeXMP ??? (???)  <29839F01-4A21-5B72-FF9A-E030D214F5E2> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
              0x1082d6000 -        0x108362fe3 +AdobeXMPFiles ??? (???)  <C4531436-CA4F-8A06-0481-CD1648C20C48> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
              0x10839a000 -        0x10843afef +com.adobe.AdobeScCore ScCore  4.1.25 (4.1.25.10116) <2049AC79-9EFA-1D8B-C577-174B36569A29>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
              0x108480000 -        0x108524ffb +com.adobe.AdobeExtendScript  ExtendScript 4.1.25 (4.1.25.10116)  <B2464DBF-230E-3187-6004-F8A804ED24A3> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
              0x108586000 -        0x108664fef +AdobeAXEDOMCore ??? (???)  <8D4592B8-5DA1-D957-B1BA-FB20116514DD> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
              0x1086dc000 -        0x108a0dfe7 +AdobeCoolType ??? (???)  <C93152AA-AC85-5157-0B28-AFE1D6CAA31F> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
              0x108aa9000 -        0x108df3fe7 +AdobeAGM ??? (???)  <E48474D7-E499-6F7A-9F2A-E9A82D075405> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
              0x108ec5000 -        0x108fdafff +AdobeACE ??? (???)  <0A896D92-86A5-D870-9BE0-755ADD1B1A33> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
              0x108fff000 -        0x109020fff +AdobeBIBUtils ??? (???)  <1468CBC0-B799-0808-91D1-78BAD0320F99> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
              0x10902d000 -        0x109100ffb +AdobeJP2K ??? (???)  <8571D9BA-44F9-92A3-0444-5FFAC2994B88> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
              0x109120000 -        0x109161ff7 +AdobeARE ??? (???)  <CE1A57E7-5175-C3A7-B644-94B4D149ED13> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
              0x10916b000 -        0x1097c3fef +AdobePDFL ??? (???)  <45AA7483-10A6-2DAB-1FF8-62C9E615039E> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
              0x109912000 -        0x109e23fff +AdobeMPS ??? (???)  <10C4E979-45F3-A7C6-0438-262CE5F595B9> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
              0x109ef9000 -        0x109f24fef +AdobeAXE16SharedExpat ??? (???)  <F5E56D3B-AE0E-245C-E706-DFA630D6771C> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedEx pat
              0x109f36000 -        0x10acf9fff +com.adobe.psl AdobePSL  12.0.0.7667 (12.0.0.7667) <F1C9409D-033E-58D0-B902-6422BC488AA5>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
              0x10b069000 -        0x10b114feb  +com.adobe.MediaCore.Frameworks.ExporterHost 1.0 (1.0)  <6F779FBA-40D3-16A5-D7EC-609CF6450518> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
              0x10b228000 -        0x10b248feb +SegMatServices.dylib ??? (???)  <FBBD1251-FEF4-80E8-57EC-919B332187D5> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/SegMatServices.dylib
              0x10b255000 -        0x10b255ff7 +SAM.dylib ??? (???)  <4502C9CF-D856-7BC4-E22A-9BEB4119B2AD> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SAM.dylib
              0x10b258000 -        0x10b33efe7  libcrypto.0.9.7.dylib 0.9.7  (compatibility 0.9.7) <BA5E5276-8696-906D-0A37-0FFEF022B482>  /usr/lib/libcrypto.0.9.7.dylib
              0x10b396000 -        0x10b66efe6 +libxerces-c-3.0.dylib ??? (???)  <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/libxerces-c-3.0.dylib
              0x10b7e8000 -        0x10b7feff6  +com.adobe.AMEAppFoundation.framework ??? (1.0)  <14C553BC-BF4B-C2F1-51E3-0E318D7E727A> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
              0x10b81f000 -        0x10b842ff1  +com.adobe.PostEncodeHost.framework ??? (1.0)  <45EEDD75-E549-F676-2A8E-B3EEA45FC1D8> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
              0x10b870000 -        0x10b92cff7 +AMEWrapper ??? (???)  <21631AD0-2C5F-B73D-22AA-D6712710D6E3> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
              0x10b9eb000 -        0x10baf2fff +com.adobe.EncoderHost.framework  ??? (1.0) <C7488EFE-B96F-8FD9-5CE5-4EF91C6E0E38>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
              0x10bbf7000 -        0x10bdc4fff +com.adobe.SettingsUI.framework  ??? (1.0) <089295DC-226C-B898-9FB7-BA037FE2F56A>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
              0x10c021000 -        0x10c07fff7  +com.adobe.MediaCore.Frameworks.Utilities.QT32Client 1.0 (1.0)  <93CFE7E1-52A1-95A0-1126-B8CB1304D81F> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
              0x10c0ed000 -        0x10c118fff   com.apple.carbonframeworktemplate 1.0 (1.0)  <71D2D8B4-2E61-C6D7-B134-5116431765BE> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
              0x10c152000 -        0x10c17bfff +ameproperties ??? (???)  <64AA3464-459A-77A6-C400-3D5B957161D4> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
              0x10c1be000 -        0x10c1c2ff2 +com.adobe.AppServices.framework  ??? (1.0) <AA9FAEBA-4D36-1F43-7AE7-F19593D57964>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServices
              0x10c680000 -        0x10c6c2fff  +com.adobe.MediaCore.ImporterQuickTime 1.0 (1.0)  <7A2D8B05-C5A9-E892-CB39-8E69E60390D5> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(MediaCore)/ImporterQuickTime.bundle/Contents/MacOS/ImporterQui ckTime
              0x10c703000 -        0x10c705fef  com.apple.textencoding.unicode  2.3 (2.3) <B254327D-2C4A-3296-5812-6F74C7FFECD9>  /System/Library/TextEncodings/Unicode  Encodings.bundle/Contents/MacOS/Unicode Encodings
              0x10da3a000 -        0x10da64ff1 +com.mainconcept.mc_dec_dv 8.5  (8.5.0.14572) <CFF0820D-B6C1-0DB8-43DE-35169748FD94>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/mc_dec_dv.framework/mc_dec_dv
              0x10dac7000 -        0x10dacffff +com.adobe.asneu.framework asneu  version 1.7.0.1 (1.7.0.1) <3D59CB21-F5C7-4232-AB00-DFEB04206024>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
              0x10dd00000 -        0x10dd70ff6 +com.adobe.amt.services  AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010  21:49:00) (3.0.0.64) <52FF1F9B-9991-ECE2-C7E3-09DA1B368CBE>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
              0x10dfe7000 -        0x10dfebfff +com.adobe.AfterEffects.EasyEase  ??? (???) <BABE30E9-6001-5F0D-8083-6540AAD2DA61>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/EasyEase.plugin/Contents/MacOS/EasyEase
              0x10dfee000 -        0x10dff2ff7 +com.adobe.AfterEffects.ExpScale  ??? (???) <5A75FEEA-77D5-EC6F-0EC5-DDA8BD78F058>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/ExpScale.plugin/Contents/MacOS/ExpScale
              0x10dff5000 -        0x10dff9ff7  libFontRegistryUI.dylib ???  (???) <763B8E8F-8602-2096-7CC8-CEE1F4248028>  /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
              0x11fffd000 -        0x120004ff7  +com.adobe.MediaCore.ImporterWave 1.0 (1.0)  <1AE53963-D095-02D6-15AB-308126B926E3> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(MediaCore)/ImporterWave.bundle/Contents/MacOS/ImporterWave
              0x1202c6000 -        0x1202c7fff  libCyrillicConverter.dylib  49.0.0 (compatibility 1.0.0)  <0739FD38-CF46-0ECC-517C-E187C5A3B8D6>  /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
              0x1202cc000 -        0x1202cdfff +com.BorisFX.BCC Lightning X 7 .  0 . 2, 16 bit (111) <624CEB8E-74CE-31BE-7D41-107306A54CD2>  /Library/Application Support/Adobe/Common/Plug-ins/CS5/MediaCore/Boris  Continuum Complete 7.0/BCC Lightning X 64Bit.bundle/Contents/MacOS/BCC  Lightning X 64Bit
              0x1202d4000 -        0x1202d5fff +com.BorisFX.BCC Particle System  X 7 . 0 . 2, 16 bit (111) <E6F9A998-F4F3-44BB-F237-E018C66D0971>  /Library/Application Support/Adobe/Common/Plug-ins/CS5/MediaCore/Boris  Continuum Complete 7.0/BCC Particle System X  64Bit.bundle/Contents/MacOS/BCC Particle System X 64Bit
              0x120303000 -        0x120304ff7 +com.adobe.AfterEffects.Paint  ??? (???) <EED2E53D-7D8A-80A0-6C09-2EF2B94076EF>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Paint.plugin/Contents/MacOS/Paint
              0x120307000 -        0x120316fff +com.adobe.AfterEffects.FreePin  ??? (???) <34D09883-0648-CEB6-4100-DDCDB8B8B8D4>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Puppet.plugin/Contents/MacOS/FreePin
              0x12031a000 -        0x120334fff +com.adobe.pip ??? (5.0.0.2021)  <47380937-5088-41F7-50FA-ADAC9B15C783> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
              0x120368000 -        0x120371fff +FastCore ??? (???)  <4A676BFE-2C56-9651-EFF7-E804EC45C87F> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/FastCore.plugin/Contents/MacOS/FastCore
              0x1206be000 -        0x1206e4fff  GLRendererFloat ??? (???)  <8256EA93-A236-8B55-F214-65896DDB7A0E>  /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
              0x1206fc000 -        0x1206fdfff +com.BorisFX.BCC 3DExt Img  Shatter X 7 . 0 . 2, 16 bit (111)  <6704052D-7DF1-1A25-28A5-B9F463BB0770> /Library/Application  Support/Adobe/Common/Plug-ins/CS5/MediaCore/Boris Continuum Complete  7.0/BCC 3DExt Img Shatter X 64Bit.bundle/Contents/MacOS/BCC 3DExt Img  Shatter X 64Bit
              0x120883000 -        0x120a14fef  GLEngine ??? (???)  <AE898A2A-1C12-9FDB-455F-32601F030904>  /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
              0x120a45000 -        0x120e68fef  libclh.dylib 3.1.1 C  (3.1.1)  <66455CD1-8C09-4A8F-EDA1-D4F2F30663F1>  /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
              0x120e96000 -        0x121d4ffe7   com.apple.driver.AppleIntelHDGraphicsGLDriver 1.6.26 (6.2.6)  <27B7C1AF-1188-249F-840D-D32CF71F9E4B>  /System/Library/Extensions/AppleIntelHDGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelH DGraphicsGLDriver
              0x1225e0000 -        0x1225e1fff  ATSHI.dylib ??? (???)  <F6C4F446-7AC4-7A17-9302-C38A016322B6>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
              0x1245ec000 -        0x1245f0fff  com.apple.audio.AudioIPCPlugIn  1.1.6 (1.1.6) <F99C2FBC-103D-DB2D-8D53-CFB8CEFA90F8>  /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
              0x1245f5000 -        0x1245fbfff   com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12)  <933CA4C6-F428-0E2E-DCBE-FA0284914092>  /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
              0x125bfc000 -        0x125c2aff3 +MMXCore ??? (???)  <0E398A83-FEBA-9272-4A07-04055F56EF16> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/MMXCore.plugin/Contents/MacOS/MMXCore
              0x125cb2000 -        0x125d1dff0 +MultiProcessor Support ???  (???) <101FF20A-2063-75D7-76FC-56974AFBAABE> /Applications/Adobe  After Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/MultiProcessor  Support.plugin/Contents/MacOS/MultiProcessor Support
              0x125d8f000 -        0x125d91fff +com.adobe.AfterEffects.Write_on  ??? (???) <D14890E8-B675-DA80-399A-3E49F96BE1D9>  /Applications/Adobe After Effects  CS5/Plug-ins/Effects/Write_on.plugin/Contents/MacOS/Write_on
              0x12654f000 -        0x126576ff1 +com.mainconcept.mc_enc_dv 8.5  (8.5.0.14572) <46AB8404-6892-F7BF-150E-D8249ECFD0B8>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
              0x126796000 -        0x12679bfff  +com.adobe.MediaCore.ExporterCoreAudio 1.0 (1.0)  <C1A74B80-D569-C330-D735-448B4FAC782F> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(MediaCore)/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCor eAudio
              0x1267a2000 -        0x1267b1fe7  +com.adobe.MediaCore.Frameworks.AudioConverter 1.0 (1.0)  <CCA6D5A2-0C71-5323-7B1C-E072DCE41C2B> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AudioConverter.framework/Versions/A/AudioConverter
              0x1267e9000 -        0x1269d3fef   com.apple.audio.codecs.Components 2.0.2 (2.0.2)  <CC28CC1B-ACD4-151F-BC5B-E842AC7F075F>  /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
              0x126a3f000 -        0x126a65ff3  +com.adobe.MediaCore.ExporterQuickTimeHost 1.0 (1.0)  <DCE19C8F-D9C7-0272-0EB2-FC8C2DF63485> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(MediaCore)/ExporterQuickTimeHost.bundle/Contents/MacOS/Exporte rQuickTimeHost
              0x126a95000 -        0x126aadff3  +com.adobe.MediaCore.Frameworks.QTParser 1.0 (1.0)  <514A4B12-E7B0-7C96-DBF2-C07C3026B87B> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
              0x126af7000 -        0x126afbfff +com.adobe.AfterEffects.TRKeys  ??? (???) <FF272930-752F-FB11-E057-09DFDCCAB3A8>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/TRKeys.plugin/Contents/MacOS/TRKeys
              0x1278ef000 -        0x1278f0fff +com.BorisFX.BCC Drop Shadow X 7  . 0 . 2, 16 bit (111) <6FE37743-3CAD-D63C-A66D-6499B6F112A1>  /Library/Application Support/Adobe/Common/Plug-ins/CS5/MediaCore/Boris  Continuum Complete 7.0/BCC Drop Shadow X 64Bit.bundle/Contents/MacOS/BCC  Drop Shadow X 64Bit
              0x1278f9000 -        0x1278fcff7 +com.adobe.AfterEffects.Durer  ??? (???) <41DC9F1C-A47C-DBD2-2982-ABEEA82D1568>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Standard3D.plugin/Contents/MacOS/Durer
              0x127a00000 -        0x127ad0ff7  +com.adobe.MediaCore.IPPMPEGDecoder 1.0 (1.0)  <AE3B4FE4-2BD1-FFE3-3657-390214479EF8> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/IPPMPEGDecoder.framework/IPPMPEGDecoder
              0x127b15000 -        0x127cdcfef +com.adobe.MediaCore.ImporterRED  1.01 (1.0) <3381CDA1-F8D1-D2D1-E93E-C1B0C82364CE>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(MediaCore)/ImporterRED.bundle/Contents/MacOS/ImporterRED
              0x1282c8000 -        0x1282c9fff +com.BorisFX.BCC Colorize Glow X  7 . 0 . 2, 16 bit (111) <DE78DA93-0E24-7E08-DAE6-C2D1A19CCEB0>  /Library/Application Support/Adobe/Common/Plug-ins/CS5/MediaCore/Boris  Continuum Complete 7.0/BCC Colorize Glow X  64Bit.bundle/Contents/MacOS/BCC Colorize Glow X 64Bit
              0x1282f4000 -        0x128300fff +com.adobe.AfterEffects.MThread  ??? (???) <E50EF468-274F-D3A0-15A3-B9CB3B9AAF7D>  /Applications/Adobe After Effects  CS5/Plug-ins/Extensions/Mthread.plugin/Contents/MacOS/MThread
              0x128490000 -        0x128511fff  +com.adobe.AfterEffects.AEGPDriver ??? (???)  <C7F9ADE5-79D2-A88E-953D-E1AE3B1F0BDC> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Required/AEGPDriver.plugin/Contents/MacOS/AEGPDriver
              0x128549000 -        0x12855ffe7  +com.adobe.AfterEffects.PS3Export ??? (???)  <1444127E-DF55-B376-ACE5-DDA0C2F3CF54> /Applications/Adobe After  Effects CS5/Plug-ins/Format/PS Layer  Export.plugin/Contents/MacOS/PS3Export
              0x12856b000 -        0x12858dff3  +com.adobe.AfterEffects.PS3Import ??? (???)  <79DCB388-3CC8-D018-DF14-A3C0F3E7C7D9> /Applications/Adobe After  Effects CS5/Plug-ins/Format/PS Layer  Import.plugin/Contents/MacOS/PS3Import
              0x12859e000 -        0x1285a4ff7 +com.adobe.AfterEffects.Sequence  ??? (???) <160CE07F-F2DF-CB1D-A013-D556E4D3AB41>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/Sequence.plugin/Contents/MacOS/Sequence
              0x1285a9000 -        0x1285c6fff +com.adobe.AfterEffects.AudioPal  ??? (???) <B8A77B49-F592-27C7-000A-9DBA0B1435EA>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Audio Palette.plugin/Contents/MacOS/AudioPal
              0x1285d8000 -        0x1285e4ff7  +com.adobe.AfterEffects.LocalizePresets ??? (???)  <38093080-3398-168D-C9AA-11F046EA3ED2> /Applications/Adobe After  Effects  CS5/Plug-ins/Extensions/LocalizePresets.plugin/Contents/MacOS/LocalizePresets
              0x1285ed000 -        0x1285f8fff +com.adobe.AfterEffects.Analyzer  ??? (???) <12EF3B3B-A7E5-9413-6DBB-16DC078B0A58>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/Analyzer.plugin/Contents/MacOS/Analyzer
              0x128700000 -        0x128776fff +com.adobe.AfterEffects.Escher  ??? (???) <6DE5ADDB-608B-DC6B-F45D-1D7A81B03B26>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Advanced3D.plugin/Contents/MacOS/Escher
              0x128783000 -        0x128801ff3  +com.adobe.AfterEffects.AEDynamicLinkServer ??? (???)  <E47693B4-C03B-5DE6-F4D6-C905E1BB7008> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Required/AEDynamicLinkServer.plugin/Contents/MacOS/AEDynamicLinkServer
              0x12893b000 -        0x128978feb  +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications  1.0.0.64 (1.0.0.64) <CD8BD7C7-0F66-29B6-C158-A6EF8DF69996>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
              0x1289b4000 -        0x1289b8fff +com.adobe.AfterEffects.Echo ???  (???) <8C4418C7-0C23-BFBA-16C2-CAA1CF1CE24D> /Applications/Adobe  After Effects CS5/Plug-ins/Effects/Echo.plugin/Contents/MacOS/Echo
              0x1289be000 -        0x1289edffb +com.adobe.AfterEffects.BrushPal  ??? (???) <92CBF24B-AF40-3506-61F4-019C623477EA>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Brush Palette.plugin/Contents/MacOS/BrushPal
              0x128a05000 -        0x128a45ff7 +com.adobe.AfterEffects.CharPal  ??? (???) <394E75A6-99E0-2866-3E70-8CBD4D4DB82B>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Character  Palette.plugin/Contents/MacOS/CharPal
              0x128a66000 -        0x128a88fff +com.adobe.AfterEffects.InfoPal  ??? (???) <99F70291-C93F-D95A-30FF-4E7871A7ADFD>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Info Palette.plugin/Contents/MacOS/InfoPal
              0x128a9c000 -        0x128ac8ffb +com.adobe.AfterEffects.PaintPal  ??? (???) <F7F81EDD-5E6B-B38C-56B9-D71768D31A5B>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Paint Palette.plugin/Contents/MacOS/PaintPal
              0x128ae0000 -        0x128b01ff7 +com.adobe.AfterEffects.ParaPal  ??? (???) <38D78DA1-664C-EEA6-703C-2A110897B406>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Paragraph  Palette.plugin/Contents/MacOS/ParaPal
              0x128b15000 -        0x128cacfff +com.adobe.AfterEffects.SnapCut  ??? (???) <D3827117-B036-C6B8-8A22-C207C78044DC>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Roto Brush.plugin/Contents/MacOS/SnapCut
              0x128cdb000 -        0x128cfdfff +com.adobe.AfterEffects.TimePal  ??? (???) <9D721EAD-2BA9-9BDC-6E1B-42BBBFDF7D77>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Time Palette.plugin/Contents/MacOS/TimePal
              0x128d13000 -        0x128d56fff +com.adobe.AfterEffects.ToolPal  ??? (???) <CA44FE3D-6552-5F3D-A1AE-B71EC5A264EA>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Tool Palette.plugin/Contents/MacOS/ToolPal
              0x128d77000 -        0x128d97ffb  +com.adobe.AfterEffects.TrackerPal ??? (???)  <C7DB4C26-39A7-5F9B-2E47-6520A00BF339> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Required/Tracker  Palette.plugin/Contents/MacOS/TrackerPal
              0x128da9000 -        0x129b7bff7  +com.ImagineerSystems.mochashapeconverter4ae 1 (1.0.0)  <3C1F5D08-D515-9E24-35ED-CC76FCCA9675> /Applications/Adobe After  Effects CS5/Plug-ins/Effects/Imagineer/mocha shape converter for  AE.plugin/Contents/MacOS/mochashapeconverter4ae
              0x129d48000 -        0x129daefff  +com.adobe.AfterEffects.AE_OpenGL ??? (???)  <76576A65-32D6-7092-59E3-F6A20F48A617> /Applications/Adobe After  Effects  CS5/Plug-ins/Extensions/AE_OpenGL.plugin/Contents/MacOS/AE_OpenGL
              0x129fc2000 -        0x12a044fe3  +com.adobe.AfterEffects.FlashExporter ??? (???)  <4DCFBC46-FCA2-D963-4979-E0FB994F5108> /Applications/Adobe After  Effects  CS5/Plug-ins/Format/FlashExporter.plugin/Contents/MacOS/FlashExporter
              0x12a071000 -        0x12a1c2feb +com.adobe.AfterEffects.OpenEXR  ??? (???) <E570DDA8-8CD5-5C4B-A8EA-38B63E89231A>  /Applications/Adobe After Effects  CS5/Plug-ins/Format/OpenEXR.plugin/Contents/MacOS/OpenEXR
              0x12a41f000 -        0x12a44ffff +com.adobe.AfterEffects.PNGIO  ??? (???) <DC8B178A-5AF7-6219-CDC2-4F757FC0DAAF>  /Applications/Adobe After Effects  CS5/Plug-ins/Format/PNGIO.plugin/Contents/MacOS/PNGIO
              0x12a45b000 -        0x12a510fff  +com.adobe.AfterEffects.PremiereProImport ??? (???)  <F1237486-5CCC-04C4-98F8-78449851498D> /Applications/Adobe After  Effects  CS5/Plug-ins/Format/PremiereProImport/PremiereProImport.plugin/Contents/MacOS/PremierePro Import
              0x12a53d000 -        0x12a5abfff  +com.adobe.MediaCore.Frameworks.UI 1.0 (1.0)  <E878778B-7ACB-28FA-2535-D2852B4CE1D2> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
              0x12a61c000 -        0x12a678fff +com.adobe.AfterEffects.TIFFIO  ??? (???) <9CF4A767-872F-0D4D-8A6C-AEEE4019B2B9>  /Applications/Adobe After Effects  CS5/Plug-ins/Format/TIFF.plugin/Contents/MacOS/TIFFIO
              0x12a688000 -        0x12a74cfeb +com.adobe.AfterEffects.Vic ???  (???) <6FFC5C50-4976-9665-3D39-EEE7438A7CB1> /Applications/Adobe  After Effects CS5/Plug-ins/Format/Vector  Output.plugin/Contents/MacOS/Vic
              0x12a7a3000 -        0x12a7bcff3 +com.adobe.AfterEffects.Align  ??? (???) <249E6544-947A-121D-46A7-1061A4B3A088>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/Align.plugin/Contents/MacOS/Align
              0x12a7cb000 -        0x12a7dbfff  +com.adobe.AfterEffects.MayaImport ??? (???)  <6E4E0B7B-3551-90E3-CEB3-FAC2125876E9> /Applications/Adobe After  Effects  CS5/Plug-ins/Keyframe/MayaImport.plugin/Contents/MacOS/MayaImport
              0x12a7de000 -        0x12a7f5ff7 +com.adobe.AfterEffects.MetaPal  ??? (???) <4CE0F462-1B67-3A32-C24F-A7921D090017>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/MetaPal.plugin/Contents/MacOS/MetaPal
              0x12a806000 -        0x12a830fff +com.adobe.AfterEffects.Moka ???  (???) <8E21D291-BF16-644F-4526-D3256CDBDF21> /Applications/Adobe  After Effects CS5/Plug-ins/Keyframe/Moka.plugin/Contents/MacOS/Moka
              0x12a841000 -        0x12a855ffb  +com.adobe.AfterEffects.MotionSketch ??? (???)  <F4C3B429-E11E-C7EF-E9F1-6FAA97F274D3> /Applications/Adobe After  Effects  CS5/Plug-ins/Keyframe/MotionSketch.plugin/Contents/MacOS/MotionSketch
              0x12a863000 -        0x12a867ff7  +com.adobe.AfterEffects.RPFImport ??? (???)  <E30E57A5-1DFE-915C-EB88-B33CE9F6E05E> /Applications/Adobe After  Effects CS5/Plug-ins/Keyframe/RPFImport.plugin/Contents/MacOS/RPFImport
              0x12a86a000 -        0x12acbefff  +com.adobe.AfterEffects.Scripting ??? (???)  <5C90290F-9EBA-D6B1-D6CB-08E4757E5AA9> /Applications/Adobe After  Effects CS5/Plug-ins/Keyframe/Scripting.plugin/Contents/MacOS/Scripting
              0x12ae4a000 -        0x12ae4eff8 +com.adobe.ape.shim adbeape  version 3.1.65.7508 (3.1.65.7508)  <0C380604-C686-C2E4-0535-C1FAB230187E> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
              0x12ae52000 -        0x12ae72ffb +com.adobe.ape adbeapecore  version 3.1.70.10055 (3.1.70.10055)  <66373ADB-0865-ECDB-D3D0-B3373FC43919> /Library/Application  Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
              0x12b153000 -        0x12bfbbff3 +com.adobe.adobeswfl ???  (2.0.0.10053) <ADE7E8AA-80B6-7BAC-8205-13D7A0E89DF8>  /Library/Application  Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/Ado beSWFL
              0x12d3c9000 -        0x12d407ff7  com.apple.DP.ScreenInputDevice  13.0 (13.0) <22174597-D163-7A20-C82A-C00C2CA19640>  /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/AppleScreenInpu tDevice.plugin/Contents/MacOS/AppleScreenInputDevice
              0x12d879000 -        0x12d8a1fff  com.apple.mio.DAL.VDC_4 134.0  (1160) <B7B57FA5-1C74-149A-43D1-51DE9479B521>  /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/VDC.plugin/Cont ents/MacOS/VDC
              0x12db4e000 -        0x12db65fe7  libJapaneseConverter.dylib  49.0.0 (compatibility 1.0.0)  <5C25B45F-7A9E-3259-0532-E13B34B5398A>  /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
              0x12db69000 -        0x12db78fe7   libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0)  <50541300-118F-BE28-86DB-0F42738A9338>  /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
              0x12db7c000 -        0x12db8efff   libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0)  <CC30A563-5E4C-7ACE-3B73-90E8F582171A>  /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
              0x12db92000 -        0x12dbb3fef  libKoreanConverter.dylib 49.0.0  (compatibility 1.0.0) <1CC25A05-9E4C-ACBE-546E-34063A4CEB09>  /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
              0x12dfd1000 -        0x12dfe0ff7 +com.adobe.AfterEffects.Curves  ??? (???) <C75D1DDD-841D-427F-BD81-914294939D50>  /Applications/Adobe After Effects  CS5/Plug-ins/Effects/Curves.plugin/Contents/MacOS/Curves
              0x12dff9000 -        0x12e002fff +com.adobe.AfterEffects.Exposure  ??? (???) <ABCFB92B-BCEF-E03B-FE46-4D45679D2F5A>  /Applications/Adobe After Effects  CS5/Plug-ins/Effects/Exposure.plugin/Contents/MacOS/Exposure
              0x12e005000 -        0x12e00fff7 +com.adobe.AfterEffects.Glow ???  (???) <05AF0BF4-EE7E-CF3A-8399-65DBA65D4A5D> /Applications/Adobe  After Effects CS5/Plug-ins/Effects/Glow.plugin/Contents/MacOS/Glow
              0x12e043000 -        0x12e057ffb +com.adobe.AfterEffects.Smoother  ??? (???) <A59E60FC-9404-BC72-E08B-FD37A9FF887C>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/Smoother.plugin/Contents/MacOS/Smoother
              0x12e065000 -        0x12e07bff3 +com.adobe.AfterEffects.Wiggler  ??? (???) <FD0E7F65-6500-B0D9-CE8D-B3E43ACC4E73>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/Wiggler.plugin/Contents/MacOS/Wiggler
              0x12e0fc000 -        0x12e0fdff7  +com.adobe.AfterEffects.Strobe_Light ??? (???)  <1AA8BFB0-C183-68D5-6C5D-D7EDD2C93176> /Applications/Adobe After  Effects  CS5/Plug-ins/Effects/Strobe_Light.plugin/Contents/MacOS/Strobe_Light
              0x12e4c2000 -        0x12e4c7ff7  +com.adobe.AfterEffects.Transform ??? (???)  <19C41586-1A01-D301-EB21-DFC8D71B174D> /Applications/Adobe After  Effects CS5/Plug-ins/Effects/Transform.plugin/Contents/MacOS/Transform
              0x12e4f6000 -        0x12e4f9fff  +com.adobe.AfterEffects.DirectionalBlur ??? (???)  <6334C5FD-3922-2D86-D5A0-EF0B8770BA85> /Applications/Adobe After  Effects  CS5/Plug-ins/Effects/DirectionalBlur.plugin/Contents/MacOS/DirectionalBlur
              0x12f1a0000 -        0x12f29dfff  +com.adobe.AfterEffects.RefineMatte ??? (???)  <E75264FC-E965-9BE7-F268-DA8B88A0A2FA> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Required/RefineMatte.plugin/Contents/MacOS/RefineMatte
              0x134ed9000 -        0x134ee5fff  +com.cycoresystems.CCfx.MrMercury 1.0 (???)  <FDC7EE23-2DDB-239D-1919-7B54676CE29E> /Applications/Adobe After  Effects  CS5/Plug-ins/Effects/CycoreFX/MrMercury.plugin/Contents/MacOS/MrMercury
              0x134eea000 -        0x134eeeff7  +com.adobe.AfterEffects.RoughenEdges ??? (???)  <25E3B30B-6C72-5A08-D4FD-9624A001E250> /Applications/Adobe After  Effects  CS5/Plug-ins/Effects/RoughenEdges.plugin/Contents/MacOS/RoughenEdges
              0x135000000 -        0x135e9dff7 +com.BorisFX.bcc_ae_16bit 7 . 0 .  2, 16 bit (111) <52C4E80A-21FA-240F-EF8C-00445B98990E>  /Library/Application  Support/BorisFX/Lib/BCC7BitDepthSupport/BCC7_AE_16Bit_64.bundle/Contents/MacOS/BCC7_AE_16 Bit_64
              0x1368d8000 -        0x137761fef +com.BorisFX.bcc_ae_8bit 7 . 0 .  2, 8 bit (111) <A2E2AA43-2DF7-89C3-31CC-3BE5B212D277>  /Library/Application  Support/BorisFX/Lib/BCC7BitDepthSupport/BCC7_AE_8Bit_64.bundle/Contents/MacOS/BCC7_AE_8Bi t_64
              0x13819a000 -        0x1381a6fff  +com.adobe.AfterEffects.atg_extract ??? (???)  <1A512551-CA7C-FC14-CB74-F8D9C997CB2B> /Applications/Adobe After  Effects  CS5/Plug-ins/Effects/Inner-Outer-Key.plugin/Contents/MacOS/atg_extract
              0x13857a000 -        0x1385c5ff7  +com.adobe.AfterEffects.Scribble_Fill ??? (???)  <422D22AD-626A-ECD3-5EE1-950C10DD257A> /Applications/Adobe After  Effects  CS5/Plug-ins/Effects/Scribble.plugin/Contents/MacOS/Scribble_Fill
              0x16fafd000 -        0x16fb00fef  libLatinSuppConverter.dylib  49.0.0 (compatibility 1.0.0)  <227677D0-9CF3-E007-E4C0-8DCECDA1AE9B>  /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
              0x1827b9000 -        0x18281efff +com.adobe.MediaCore.ImporterMp3  1.0 (1.0) <71F80DA9-0E3B-5333-B0BF-5F333A260E0C>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(MediaCore)/ImporterMP3.bundle/Contents/MacOS/ImporterMp3
              0x1b32b0000 -        0x1b32b7fff  com.apple.URLMount.AFPPlugin  3.2.1 (3.2.1) <4A425908-9801-14B3-DAB5-46165B89DF93>  /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp
              0x200000000 -        0x200787fef  com.apple.GeForceGLDriver  1.6.26 (6.2.6) <BAAEDD99-82FA-2C7F-CD66-E0977C670CC5>  /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
              0x283700000 -        0x28374afff  com.apple.AppleShareClientCore  2.0 (2.0) <C8193C5A-CDEE-39E5-1BEF-174D29678E6C>  /System/Library/Frameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore
           0x7fff5fc00000 -     0x7fff5fc3bdef  dyld 132.1 (???) <B536F2F1-9DF1-3B6C-1C2C-9075EA219A06> /usr/lib/dyld
           0x7fff80003000 -     0x7fff80004ff7  com.apple.TrustEvaluationAgent  1.1 (1) <306FD9EE-A301-41D5-EBDE-2FC52F28229C>  /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
           0x7fff80051000 -     0x7fff80082fff  libGLImage.dylib ??? (???)  <1A8E58CF-FA2F-14F7-A097-D34EEA8A7D03>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
           0x7fff80083000 -     0x7fff80091ff7  libkxld.dylib ??? (???)  <4016E9E6-0645-5384-A697-2775B5228113>  /usr/lib/system/libkxld.dylib
           0x7fff80092000 -     0x7fff800e1ff7   com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0)  <17EFD646-6F53-36E9-56BF-5A339E83EFFC>  /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
           0x7fff800e2000 -     0x7fff80153ff7  com.apple.AppleVAFramework  4.10.12 (4.10.12) <1B68BE43-4C54-87F5-0723-0B0A14CD21E8>  /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
           0x7fff80154000 -     0x7fff803befef  com.apple.QuartzComposer 4.2  ({156.28}) <7586E7BD-D3BD-0EAC-5AC9-0BFA3679017C>  /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
           0x7fff803bf000 -     0x7fff80402fef  libtidy.A.dylib ??? (???)  <2F4273D3-418B-668C-F488-7E659D3A8C23> /usr/lib/libtidy.A.dylib
           0x7fff80403000 -     0x7fff80493fff  com.apple.SearchKit 1.3.0  (1.3.0) <3403E658-A54E-A79A-12EB-E090E8743984>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
           0x7fff8057e000 -     0x7fff805bbff7  libFontRegistry.dylib ??? (???)  <8C69F685-3507-1B8F-51AD-6183D5E88979>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
           0x7fff8075b000 -     0x7fff807a5ff7  com.apple.Metadata 10.6.3  (507.15) <5170FCE0-ED6C-2E3E-AB28-1DDE3F628FC5>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
           0x7fff80821000 -     0x7fff80827fff  libCGXCoreImage.A.dylib 545.0.0  (compatibility 64.0.0) <4EE16374-A094-D542-5BC5-7E846D0CE56E>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
           0x7fff80828000 -     0x7fff80828ff7  com.apple.vecLib 3.6 (vecLib  3.6) <08D3D45D-908B-B86A-00BA-0F978D2702A7>  /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
           0x7fff80862000 -     0x7fff80979fef  libxml2.2.dylib 10.3.0  (compatibility 10.0.0) <7DC5239F-CD6A-820C-7C66-C528D7E27649>  /usr/lib/libxml2.2.dylib
           0x7fff8097a000 -     0x7fff80a2ffe7  com.apple.ink.framework 1.3.3  (107) <D76C7591-B060-E2DE-6634-968FDABD87EF>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
           0x7fff80a30000 -     0x7fff80a41ff7  libz.1.dylib 1.2.3  (compatibility 1.0.0) <FB5EE53A-0534-0FFA-B2ED-486609433717>  /usr/lib/libz.1.dylib
           0x7fff80a42000 -     0x7fff80ae2fff  com.apple.LaunchServices 362.2  (362.2) <A8EDC37C-1D40-5ED0-49BE-90EF110A6B3A>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
           0x7fff80b9a000 -     0x7fff80d5bfff  libSystem.B.dylib 125.2.1  (compatibility 1.0.0) <71E6D4C9-F945-6EC2-998C-D61AD590DAB6>  /usr/lib/libSystem.B.dylib
           0x7fff80dd9000 -     0x7fff80ddeff7  com.apple.CommonPanels 1.2.4  (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
           0x7fff80ddf000 -     0x7fff80e20fff  com.apple.SystemConfiguration  1.10.5 (1.10.2) <FB39F09C-57BB-D8CC-348D-93E00C602F7D>  /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
           0x7fff80e21000 -     0x7fff80edeff7   com.apple.CoreServices.OSServices 357 (357)  <718F0719-DC9F-E392-7C64-9D7DFE3D02E2>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
           0x7fff80edf000 -     0x7fff80eeefff  com.apple.NetFS 3.2.1 (3.2.1)  <3FC302C9-A5C6-A9CA-08CE-435AD05499F1>  /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
           0x7fff80eef000 -     0x7fff81175fff  com.apple.security 6.1.1  (37594) <1B4E1ABD-1BB3-DA49-F574-0EEB23E73C6A>  /System/Library/Frameworks/Security.framework/Versions/A/Security
           0x7fff81176000 -     0x7fff81241fe7  ColorSyncDeprecated.dylib 4.6.0  (compatibility 1.0.0) <3C223A94-EF14-28C5-844B-C25DFC87FB42>  /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
           0x7fff81242000 -     0x7fff812acfe7  libvMisc.dylib 268.0.1  (compatibility 1.0.0) <7D8B6D68-7E70-2AF2-BF9F-2CD56145909C>  /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
           0x7fff812ad000 -     0x7fff812b2fff  libGFXShared.dylib ??? (???)  <991F8197-FD06-2AF1-F99B-E448ED4FB2AC>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
           0x7fff812bb000 -     0x7fff812d0ff7  com.apple.LangAnalysis 1.6.6  (1.6.6) <DC999B32-BF41-94C8-0583-27D9AB463E8B>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
           0x7fff81332000 -     0x7fff81384ff7  com.apple.HIServices 1.8.2  (???) <7C91D07D-FA20-0882-632F-0CAE4FAC2B79>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
           0x7fff81385000 -     0x7fff813e7fe7  com.apple.datadetectorscore 2.0  (80.7) <5F0F865C-A80F-FE7F-7DF8-894A4A99EACA>  /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
           0x7fff813e8000 -     0x7fff81421fef  libcups.2.dylib 2.8.0  (compatibility 2.0.0) <561D0DCB-47AD-A12C-9066-70E4CBAD331C>  /usr/lib/libcups.2.dylib
           0x7fff814bb000 -     0x7fff81502fff  com.apple.QuickLookFramework  2.3 (327.6) <11DFB135-24A6-C0BC-5B97-ECE352A4B488>  /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
           0x7fff8155d000 -     0x7fff81642fef  com.apple.DesktopServices 1.5.9  (1.5.9) <27890B2C-0CD2-7C27-9D0C-D5952C5E8438>  /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
           0x7fff81643000 -     0x7fff817fafef  com.apple.ImageIO.framework  3.0.4 (3.0.4) <2CB9997A-A28D-80BC-5921-E7D50BBCACA7>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
           0x7fff817fb000 -     0x7fff81800fff  libGIF.dylib ??? (???)  <9A2723D8-61F9-6D65-D254-4F9273CDA54A>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
           0x7fff81801000 -     0x7fff81b9efe7  com.apple.QuartzCore 1.6.3  (227.34) <215222AF-B30A-7CE5-C46C-1A766C1D1D2E>  /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
           0x7fff81b9f000 -     0x7fff81bc5fe7  libJPEG.dylib ??? (???)  <6690F15D-E970-2678-430E-590A94F5C8E9>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
           0x7fff81bc6000 -     0x7fff81d3dfe7  com.apple.CoreFoundation 6.6.4  (550.42) <770C572A-CF70-168F-F43C-242B9114FCB5>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
           0x7fff81d8e000 -     0x7fff81fc9fef  com.apple.imageKit 2.0.3 (1.0)  <5D18C246-303A-6580-9DC9-79BE79467C95>  /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
           0x7fff81ffa000 -     0x7fff820b0fff  libobjc.A.dylib 227.0.0  (compatibility 1.0.0) <B1F5CDC0-96BD-C7C0-BEAA-1E2259DDE067>  /usr/lib/libobjc.A.dylib
           0x7fff820b1000 -     0x7fff8216afff  libsqlite3.dylib 9.6.0  (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150>  /usr/lib/libsqlite3.dylib
           0x7fff8216b000 -     0x7fff821b2ff7  com.apple.coreui 2 (114)  <BB09E685-1F5D-0676-1A0E-295610B387A8>  /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
           0x7fff821b3000 -     0x7fff821b9ff7  IOSurface ??? (???)  <04EDCEDE-E36F-15F8-DC67-E61E149D2C9A>  /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
           0x7fff821ba000 -     0x7fff821e5ff7  libxslt.1.dylib 3.24.0  (compatibility 3.0.0) <87A0B228-B24A-C426-C3FB-B40D7258DD49>  /usr/lib/libxslt.1.dylib
           0x7fff8221b000 -     0x7fff82287ff7  com.apple.CorePDF 1.3 (1.3)  <6770FFB0-DEA0-61E0-3520-4B95CCF5D1CF>  /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
           0x7fff82638000 -     0x7fff82687fef  libTIFF.dylib ??? (???)  <AE9DC484-1382-F7AD-FE25-C28082FCB5D9>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
           0x7fff8268d000 -     0x7fff82727fff   com.apple.ApplicationServices.ATS 4.4 (???)  <395849EE-244A-7323-6CBA-E71E3B722984>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
           0x7fff82728000 -     0x7fff82802ff7  com.apple.vImage 4.0 (4.0)  <354F34BF-B221-A3C9-2CA7-9BE5E14AD5AD>  /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
           0x7fff82826000 -     0x7fff82831ff7   com.apple.speech.recognition.framework 3.11.1 (3.11.1)  <60484D84-BA63-13DD-50E9-ABDA402C3C45>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
           0x7fff82857000 -     0x7fff82b8bfff   com.apple.CoreServices.CarbonCore 861.23 (861.23)  <08F360FA-1771-4F0B-F356-BEF68BB9D421>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
           0x7fff82b8c000 -     0x7fff82c41fe7  com.apple.ColorSync 4.6.3  (4.6.3) <AA93AD96-6974-9104-BF55-AF7A813C8A1B>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
           0x7fff82c42000 -     0x7fff82d6aff7  com.apple.MediaToolbox 0.484.20  (484.20) <628A7245-7ADE-AD47-3368-CF8EDCA6CC1C>  /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
           0x7fff82d83000 -     0x7fff82d83ff7  com.apple.ApplicationServices  38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
           0x7fff82ef6000 -     0x7fff82efcff7  com.apple.DiskArbitration 2.3  (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A>  /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
           0x7fff82efd000 -     0x7fff830e0fff  libType1Scaler.dylib ??? (???)  <3A1AFBA4-958E-DD07-297E-DF1FB2C96D7C>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
           0x7fff830e1000 -     0x7fff83136ff7   com.apple.framework.familycontrols 2.0.2 (2020)  <A3CFF697-B9DB-A7E5-3B39-9DA9B34F0595>  /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
           0x7fff83137000 -     0x7fff8317fff7  libvDSP.dylib 268.0.1  (compatibility 1.0.0) <170DE04F-89AB-E295-0880-D69CAFBD7979>  /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
           0x7fff83180000 -     0x7fff83183fff  com.apple.help 1.3.1 (41)  <E311A81E-9870-A430-1E16-AFF6C92CE6E5>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
           0x7fff83184000 -     0x7fff8319afe7   com.apple.MultitouchSupport.framework 207.10 (207.10)  <1828C264-A54A-7FDD-FE1B-49DDE3F50779>  /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
           0x7fff8319b000 -     0x7fff8321afe7  com.apple.audio.CoreAudio 3.2.6  (3.2.6) <1DD64A62-0DE4-223F-F781-B272FECF80F0>  /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
           0x7fff8321b000 -     0x7fff8365ffef  libLAPACK.dylib 219.0.0  (compatibility 1.0.0) <E14EC4C6-B055-A4AC-B971-42AB644E4A7C>  /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
           0x7fff83660000 -     0x7fff83699ff7  com.apple.MeshKit 1.1 (49.2)  <2860E92F-5B68-E8DD-0E8F-BF3DD6ACF330>  /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
           0x7fff838e4000 -     0x7fff838ffff7  com.apple.openscripting 1.3.1  (???) <5A6ECC32-04D0-9A62-635D-1DD03EC6E190>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
           0x7fff83918000 -     0x7fff83948fef  com.apple.shortcut 1.1 (1.1)  <A99C9D8E-290B-B1E4-FEA5-CC5F2FB9C18D>  /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
           0x7fff83949000 -     0x7fff83995fff  libauto.dylib ??? (???)  <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
           0x7fff83a8e000 -     0x7fff84298fe7  libBLAS.dylib 219.0.0  (compatibility 1.0.0) <EEE5CE62-9155-6559-2AEA-05CED0F5B0F1>  /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
           0x7fff842b2000 -     0x7fff842b2ff7  com.apple.Carbon 150 (152)  <19B37B7B-1594-AD0A-7F14-FA2F85AD7241>  /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
           0x7fff842b3000 -     0x7fff842b4fff  liblangid.dylib ??? (???)  <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
           0x7fff842b5000 -     0x7fff84538ff7  com.apple.Foundation 6.6.4  (751.42) <9A99D378-E97A-8C0F-3857-D0FAA30FCDD5>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
           0x7fff84539000 -     0x7fff84539ff7  com.apple.quartzframework 1.5  (1.5) <B182B579-BCCE-81BF-8DA2-9E0B7BDF8516>  /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
           0x7fff8453a000 -     0x7fff84644ff7  com.apple.MeshKitIO 1.1 (49.2)  <B9E2EB6C-66F6-CFAD-4530-DDA4355D7FBA>  /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
           0x7fff84645000 -     0x7fff84646ff7  com.apple.audio.units.AudioUnit  1.6.5 (1.6.5) <14F14B5E-9287-BC36-0C3F-6592E6696CD4>  /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
           0x7fff84647000 -     0x7fff847b6fe7  com.apple.QTKit 7.6.6 (1756)  <250AB242-816D-9F5D-94FB-18BF2AE9AAE7>  /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
           0x7fff847b7000 -     0x7fff847f8ff7  com.apple.CoreMedia 0.484.20  (484.20) <42F3B74A-F886-33A0-40EE-8399B12BD32A>  /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
           0x7fff847f9000 -     0x7fff84833fff  libssl.0.9.8.dylib 0.9.8  (compatibility 0.9.8) <C7153747-50E3-32DA-426F-CC4C505D1D6C>  /usr/lib/libssl.0.9.8.dylib
           0x7fff854a8000 -     0x7fff854aafff  com.apple.print.framework.Print  6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
           0x7fff854f2000 -     0x7fff85508fef  libbsm.0.dylib ??? (???)  <83676D2E-23CD-45CD-BE5C-35FCFFBBBDBB> /usr/lib/libbsm.0.dylib
           0x7fff85509000 -     0x7fff85509ff7  com.apple.Accelerate.vecLib 3.6  (vecLib 3.6) <DA9BFF01-40DF-EBD5-ABB7-787DAF2D77CF>  /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
           0x7fff8550a000 -     0x7fff85553ff7  com.apple.securityinterface  4.0.1 (40418) <E2DC796D-84EC-48F5-34A9-DF614573BE74>  /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
           0x7fff85570000 -     0x7fff855d8fff  com.apple.MeshKitRuntime 1.1  (49.2) <C57FDCEE-CED0-06A8-2890-A3F6BB851998>  /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
           0x7fff855d9000 -     0x7fff856fffff   com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5)  <B51023BB-A5C9-3C65-268B-6B86B901BB2C>  /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
           0x7fff85805000 -     0x7fff85926fe7  libcrypto.0.9.8.dylib 0.9.8  (compatibility 0.9.8) <48AEAFE1-21F4-B3C8-4199-35AD5E8D0613>  /usr/lib/libcrypto.0.9.8.dylib
           0x7fff8592d000 -     0x7fff8594dff7   com.apple.DirectoryService.Framework 3.6 (621.9)  <FF6567B5-56BD-F3EC-E59D-1EC583C3CF73>  /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
           0x7fff8594e000 -     0x7fff85c4cfe7  com.apple.HIToolbox 1.6.4 (???)  <263AD497-F4CC-9610-E7D3-B95CF6F02030>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
           0x7fff85c4d000 -     0x7fff85c66fff  com.apple.CFOpenDirectory 10.6  (10.6) <CCF79716-7CC6-2520-C6EB-A4F56AD0A207>  /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
           0x7fff85c67000 -     0x7fff85cf6fff  com.apple.PDFKit 2.5.1 (2.5.1)  <927B9F90-3EBE-768E-8B18-BE43B4B58190>  /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
           0x7fff85cf7000 -     0x7fff85e10fef  libGLProgrammability.dylib ???  (???) <4F2DC233-7DD2-1204-CAA5-3E6524F0AB75>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
           0x7fff85e11000 -     0x7fff85e2eff7  libPng.dylib ??? (???)  <14043CBC-329F-4009-299E-DEE411E16134>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
           0x7fff85e65000 -     0x7fff85e6cfff  com.apple.OpenDirectory 10.6  (10.6) <4200CFB0-DBA1-62B8-7C7C-91446D89551F>  /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
           0x7fff85e6d000 -     0x7fff85eb2fff  com.apple.CoreMediaIOServices  134.0 (1160) <033C41A6-EB9B-6B3B-781A-AF001A945C7A>  /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
           0x7fff85eb3000 -     0x7fff85eb6ff7  libCoreVMClient.dylib ??? (???)  <609598E6-195D-E5D4-3B92-AE8D9768829C>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
           0x7fff85edf000 -     0x7fff865dc06f  com.apple.CoreGraphics 1.545.0  (???) <356D59D6-1DD1-8BFF-F9B3-1CE51D2F1EC7>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
           0x7fff865dd000 -     0x7fff865ecfff  com.apple.opengl 1.6.12  (1.6.12) <DE3F0528-7759-CDFD-A2CF-C51D3C9C8B39>  /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
           0x7fff865ed000 -     0x7fff865f1ff7  libCGXType.A.dylib 545.0.0  (compatibility 64.0.0) <63F77AC8-84CB-0C2F-8D2B-190EE5CCDB45>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
           0x7fff865f2000 -     0x7fff869fcfff  com.apple.RawCamera.bundle  3.5.0 (551) <FC906EA7-3E89-CA01-6D48-E157EF1E83F0>  /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
           0x7fff869fd000 -     0x7fff86a1efff  libresolv.9.dylib 41.0.0  (compatibility 1.0.0) <6993F348-428F-C97E-7A84-7BD2EDC46A62>  /usr/lib/libresolv.9.dylib
           0x7fff86a1f000 -     0x7fff86a25ff7  com.apple.CommerceCore 1.0 (6)  <E8A1144C-5666-9840-4729-256FE69CDBDB>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
           0x7fff86a26000 -     0x7fff86a26ff7  com.apple.Accelerate 1.6  (Accelerate 1.6) <2BB7D669-4B40-6A52-ADBD-DA4DB3BC0B1B>  /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
           0x7fff86ba1000 -     0x7fff86c01fe7  com.apple.framework.IOKit 2.0  (???) <D107CB8A-5182-3AC4-35D0-07068A695C05>  /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
           0x7fff86c2a000 -     0x7fff86c2bfff  com.apple.MonitorPanelFramework  1.3.0 (1.3.0) <5062DACE-FCE7-8E41-F5F6-58821778629C>  /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
           0x7fff86d6a000 -     0x7fff86dadff7  libRIP.A.dylib 545.0.0  (compatibility 64.0.0) <7E30B5F6-99FD-C716-8670-5DD4B4BAED72>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
           0x7fff86dae000 -     0x7fff86dc4fff  com.apple.ImageCapture 6.0.1  (6.0.1) <09ABF2E9-D110-71A9-4A6F-8A61B683E936>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
           0x7fff86dc5000 -     0x7fff86e0efef  libGLU.dylib ??? (???)  <CCE779A9-2467-A5AA-A558-691E43A1105F>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
           0x7fff86e0f000 -     0x7fff86e20fff   com.apple.DSObjCWrappers.Framework 10.6 (134)  <3C08225D-517E-2822-6152-F6EB13A4ADF9>  /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
           0x7fff86e21000 -     0x7fff86fdffff  libicucore.A.dylib 40.0.0  (compatibility 1.0.0) <781E7B63-2AD0-E9BA-927C-4521DB616D02>  /usr/lib/libicucore.A.dylib
           0x7fff86fe0000 -     0x7fff87008fff  com.apple.DictionaryServices  1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
           0x7fff87009000 -     0x7fff87014ff7  com.apple.HelpData 2.0.4 (34)  <0DA6CA96-4E7D-7B22-7E37-218AF084C493>  /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
           0x7fff87015000 -     0x7fff870e7fe7  com.apple.CFNetwork 454.11.5  (454.11.5) <B3E2BE12-D7AA-5940-632A-1E5E7BF8E6E3>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
           0x7fff870e8000 -     0x7fff875ecfe7  com.apple.VideoToolbox 0.484.20  (484.20) <8B6B82D2-350B-E9D3-5433-51453CDA65B4>  /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
           0x7fff875ff000 -     0x7fff87613fff  libGL.dylib ??? (???)  <1EB1BD0F-C17F-55DF-B8B4-8E9CF99359D4>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
           0x7fff87614000 -     0x7fff87803fe7  com.apple.JavaScriptCore  6533.19 (6533.19.1) <233B3E34-CDC4-668A-529A-7E61D510D991>  /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
           0x7fff87804000 -     0x7fff87807ff7  com.apple.securityhi 4.0  (36638) <38935851-09E4-DDAB-DB1D-30ADC39F7ED0>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
           0x7fff87838000 -     0x7fff87874fe7  libcurl.4.dylib 6.1.0  (compatibility 6.0.0) <1E041185-131C-C237-C250-38BE933A269A>  /usr/lib/libcurl.4.dylib
           0x7fff8796e000 -     0x7fff879a0fff  libTrueTypeScaler.dylib ???  (???) <B9ECE1BD-A716-9F65-6466-4444D641F584>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
           0x7fff879a1000 -     0x7fff87a1efef  libstdc++.6.dylib 7.9.0  (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C>  /usr/lib/libstdc++.6.dylib
           0x7fff87a1f000 -     0x7fff87a2cfe7  libCSync.A.dylib 545.0.0  (compatibility 64.0.0) <397B9057-5CDF-3B19-4E61-9DFD49369375>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
           0x7fff87a2d000 -     0x7fff87ab9fef  SecurityFoundation ??? (???)  <6860DE26-0D42-D1E8-CD7C-5B42D78C1E1D>  /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
           0x7fff87aba000 -     0x7fff87addfff  com.apple.opencl 12.3 (12.3)  <D30A45FC-4520-45AF-3CA5-092313DB5D54>  /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
           0x7fff87ade000 -     0x7fff87b5cfff  com.apple.CoreText 3.5.0 (???)  <4D5C7932-293B-17FF-7309-B580BB1953EA>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
           0x7fff87b5d000 -     0x7fff87b8cff7  com.apple.quartzfilters 1.6.0  (1.6.0) <9CECB4FC-1CCF-B8A2-B935-5888B21CBEEF>  /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
           0x7fff8809a000 -     0x7fff8809aff7  com.apple.Cocoa 6.6 (???)  <68B0BE46-6E24-C96F-B341-054CF9E8F3B6>  /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
           0x7fff8809b000 -     0x7fff880d8fff  com.apple.LDAPFramework 2.0  (120.1) <1683330C-2908-9A45-AFF1-2282792C2570>  /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
           0x7fff880d9000 -     0x7fff88188fff  edu.mit.Kerberos 6.5.10  (6.5.10) <F3F76EDF-5660-78F0-FE6E-33B6174F55A4>  /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
           0x7fff88189000 -     0x7fff8819bfe7  libsasl2.2.dylib 3.15.0  (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97>  /usr/lib/libsasl2.2.dylib
           0x7fff8819c000 -     0x7fff88b92fff  com.apple.AppKit 6.6.7  (1038.35) <9F4DF818-9DB9-98DA-490C-EF29EA757A97>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
           0x7fff88b93000 -     0x7fff88c54fe7  libFontParser.dylib ??? (???)  <8B12D37E-3A95-5A73-509C-3AA991E0C546>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
           0x7fff88c55000 -     0x7fff88d93fff  com.apple.CoreData 102.1 (251)  <782F29CA-ACC7-4A77-5772-52FBE2CEFB5E>  /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
           0x7fff88e09000 -     0x7fff88e2eff7  com.apple.CoreVideo 1.6.2  (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288>  /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
           0x7fff88e2f000 -     0x7fff88e70fef  com.apple.QD 3.36 (???)  <5DC41E81-32C9-65B2-5528-B33E934D5BB4>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
           0x7fff88e71000 -     0x7fff88eb5fe7  com.apple.ImageCaptureCore  1.0.3 (1.0.3) <913FFA89-0AC8-0A8D-CC2A-364CB0F303BA>  /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
           0x7fff88eb6000 -     0x7fff88eb6ff7  com.apple.CoreServices 44 (44)  <DC7400FB-851E-7B8A-5BF6-6F50094302FB>  /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
           0x7fff88edc000 -     0x7fff88f61ff7   com.apple.print.framework.PrintCore 6.3 (312.7)  <CDFE82DD-D811-A091-179F-6E76069B432D>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
           0x7fff88f6b000 -     0x7fff88fa6fff  com.apple.AE 496.4 (496.4)  <64C27EC8-FC7F-EA6B-9435-9A3452425915>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
           0x7fff88fa7000 -     0x7fff89029fff  com.apple.QuickLookUIFramework  2.3 (327.6) <9093682A-0E2D-7D27-5F22-C96FD00AE970>  /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
           0x7fff8902a000 -     0x7fff8902eff7  libmathCommon.A.dylib 315.0.0  (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5>  /usr/lib/system/libmathCommon.A.dylib
           0x7fff8902f000 -     0x7fff89038ff7  com.apple.DisplayServicesFW  2.3.0 (283) <3D05929C-AB17-B8A4-DC81-87C27C59E664>  /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
           0x7fff8913a000 -     0x7fff8913cfff  libRadiance.dylib ??? (???)  <76438F90-DD4B-9941-9367-F2DFDF927876>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
           0x7fff8913d000 -     0x7fff89151ff7   com.apple.speech.synthesis.framework 3.10.35 (3.10.35)  <63C87CF7-56B3-4038-8136-8C26E96AD42F>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
           0x7fffffe00000 -     0x7fffffe01fff  libSystem.B.dylib ??? (???)  <71E6D4C9-F945-6EC2-998C-D61AD590DAB6> /usr/lib/libSystem.B.dylib
      RAM: 8192MB
      Machine: i386
      Model: MacBookPro6,1
      CPU * Core count: 4
      CPU Frequency: 2660MHz
      Bus Frequency: 4800MHz
      Open GL Renderer: NVIDIA GeForce GT 330M OpenGL Engine
      Open GL Version: 2.1 NVIDIA-1.6.26
      Open GL Vendor: NVIDIA Corporation
      Open GL Extensions: L_ARB_transpose_matrix, GL_ARB_vertex_program,  GL_ARB_vertex_blend, GL_ARB_window_pos, GL_ARB_shader_objects,  GL_ARB_vertex_shader, GL_ARB_shading_language_100,  GL_EXT_multi_draw_arrays, GL_EXT_clip_volume_hint,  GL_EXT_rescale_normal, GL_EXT_draw_range_elements, GL_EXT_fog_coord,  GL_EXT_gpu_program_parameters, GL_EXT_geometry_shader4,  GL_EXT_transform_feedback, GL_APPLE_client_storage,  GL_APPLE_specular_vector, GL_APPLE_transform_hint,  GL_APPLE_packed_pixels, GL_APPLE_fence, GL_APPLE_vertex_array_object,  GL_APPLE_vertex_program_evaluators, GL_APPLE_element_array,  GL_APPLE_flush_render, GL_APPLE_aux_depth_stencil,  GL_NV_texgen_reflection, GL_NV_light_max_exponent,  GL_IBM_rasterpos_clip, GL_SGIS_generate_mipmap, GL_ARB_imaging,  GL_ARB_point_parameters, GL_ARB_texture_env_crossbar,  GL_ARB_texture_border_clamp, GL_ARB_multitexture,  GL_ARB_texture_env_add, GL_ARB_texture_cube_map,  GL_ARB_texture_env_dot3, GL_ARB_multisample, GL_ARB_texture_env_combine,  GL_ARB_texture_compression, GL_ARB_texture_mirrored_repeat,  GL_ARB_shadow, GL_ARB_depth_texture, GL_ARB_fragment_program,  GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,  GL_ARB_occlusion_query, GL_ARB_point_sprite,  GL_ARB_texture_non_power_of_two, GL_ARB_vertex_buffer_object,  GL_ARB_pixel_buffer_object, GL_ARB_draw_buffers,  GL_ARB_shader_texture_lod, GL_ARB_color_buffer_float,  GL_ARB_half_float_vertex, GL_ARB_texture_rg,  GL_ARB_texture_compression_rgtc, GL_ARB_framebuffer_object,  GL_EXT_compiled_vertex_array, GL_EXT_draw_buffers2,  GL_EXT_framebuffer_object, GL_EXT_framebuffer_blit,  GL_EXT_framebuffer_multisample, GL_EXT_texture_rectangle,  GL_ARB_texture_rectangle, GL_EXT_texture_env_add, GL_EXT_blend_color,  GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_lod_bias,  GL_EXT_abgr, GL_EXT_bgra, GL_EXT_stencil_wrap,  GL_EXT_texture_filter_anisotropic, GL_EXT_secondary_color,  GL_EXT_blend_func_separate, GL_EXT_shadow_funcs,  GL_EXT_stencil_two_side, GL_EXT_depth_bounds_test,  GL_EXT_texture_compression_s3tc, GL_EXT_texture_compression_dxt1,  GL_EXT_texture_sRGB, GL_EXT_blend_equation_separate,  GL_EXT_texture_mirror_clamp, GL_EXT_packed_depth_stencil,  GL_EXT_bindable_uniform, GL_EXT_texture_integer, GL_EXT_gpu_shader4,  GL_EXT_framebuffer_sRGB, GL_EXT_provoking_vertex,  GL_APPLE_flush_buffer_range, GL_APPLE_ycbcr_422, GL_APPLE_rgb_422,  GL_APPLE_vertex_array_range, GL_APPLE_texture_range,  GL_APPLE_float_pixels, GL_ATI_texture_float, GL_ARB_texture_float,  GL_ARB_half_float_pixel, GL_APPLE_pixel_buffer,  GL_APPLE_object_purgeable, GL_NV_point_sprite, GL_NV_blend_square,  GL_NV_fog_distance, GL_NV_depth_clamp, GL_NV_multisample_filter_hint,  GL_NV_fragment_program_option, GL_NV_fragment_program2,  GL_NV_vertex_program2_option, GL_NV_vertex_program3,  GL_NV_conditional_render, GL_ATI_texture_mirror_once,  GL_ATI_texture_env_combine3, GL_ATI_separate_stencil,  GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_EXT_texture_array,  GL_EXT_vertex_array_bgra, GL_ARB_instanced_arrays,  GL_ARB_depth_buffer_float, GL_EXT_packed_float,  GL_EXT_texture_shared_exponent
      User GUID: 08EF2AE7-B010-4086-9905-62E31073C046
      Crash GUID: 9C7B4F3A-2AF8-436F-BAFF-E0D164F64E84
      Process:         After Effects [2850]
      Path:            /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/MacOS/After Effects
      Identifier:      com.adobe.AfterEffects
      Version:         10.0.1 (10.0)
      Code Type:       X86-64 (Native)
      Parent Process:  launchd [233]
      Date/Time:       2011-03-03 13:17:42.585 +0000
      OS Version:      Mac OS X 10.6.6 (10J567)
      Report Version:  6
      Exception Type:  EXC_BAD_ACCESS (SIGABRT)
      Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Application Specific Information:
      abort() called
      Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
      0   libSystem.B.dylib                 0x00007fff80be9616 __kill + 10
      1   libSystem.B.dylib                 0x00007fff80c89cca abort + 83
      2   U.dylib                           0x0000000102a89867 U_LoadFrameworkBundle + 695
      3   libSystem.B.dylib                 0x00007fff80bfb67a _sigtramp + 26
      4   ???                               0x00007fff5fbfdf50 0 + 140734799798096
      5   ...e.AfterEffectsLib.framework    0x0000000100b51982 CRQRenderSettings::SetRS_FromPref(int) + 61698
      6   ...e.AfterEffectsLib.framework    0x0000000100b529a4 CRQRenderSettings::SetRS_FromPref(int) + 65828
      7   ...e.AfterEffectsLib.framework    0x0000000100b5a20b CRQRenderSettings::SetRS_FromPref(int) + 96651
      8   ...e.AfterEffectsLib.framework    0x0000000100b498f9 CRQRenderSettings::SetRS_FromPref(int) + 28793
      9   ...e.AfterEffectsLib.framework    0x0000000100a1d7e3 COutlineDir::GetOutlinePano() + 23411
      10  ...e.AfterEffectsLib.framework    0x0000000100a1ff45 COutlineDir::GetOutlinePano() + 33493
      11  ...e.AfterEffectsLib.framework    0x0000000100af0811 CTLOutlinePano::CenterCurrentTimeIfNecessary() + 8865
      12  ...e.AfterEffectsLib.framework    0x00000001006d4679 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 393
      13  ...e.AfterEffectsLib.framework    0x00000001006d4594 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 164
      14  ...e.AfterEffectsLib.framework    0x00000001006d4594 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 164
      15  ...e.AfterEffectsLib.framework    0x0000000100702ad8  dvacore::utility::SearchLiveHelp(std::basic_string<unsigned short,  std::char_traits<unsigned short>, std::allocator<unsigned  short> >) + 7480
      16  ...e.AfterEffectsLib.framework    0x0000000100a17c0e GetCEffects(BEE_Layer*) + 67326
      17  com.adobe.dvaui.framework         0x00000001031d9822  dvaui::ui::UI_Node::UI_DispatchMouseEventToLeaf(dvaui::ui::UI_Node*,  dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&) + 146
      18  com.adobe.dvaui.framework         0x00000001031dc7d5  dvaui::ui::UI_Node::DispatchMouseEvent::operator()(dvaui::ui::UI_Node*,  dvaui::ui::UI_Node*, dvacore::geom::PointT<float> const&)  const + 165
      19  com.adobe.dvaui.framework         0x00000001031e6243  std::pair<bool, dvaui::ui::UI_Node*>  dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeafT<dvaui::ui::UI_Node::DispatchMouseEv ent>(dvaui::ui::UI_Node::DispatchMouseEvent&,  dvacore::geom::PointT<float> const&, bool) + 131
      20  com.adobe.dvaui.framework         0x00000001031e0613  dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeaf(dvaui::ui::MouseEvent  const&, bool) + 83
      21  com.adobe.dvaui.framework         0x00000001031e1dcf  dvaui::ui::UI_Node::UI_DispatchMouseEventToTarget(dvaui::ui::UI_Node*,  dvaui::ui::MouseEvent const&, bool) + 159
      22  com.adobe.dvaui.framework         0x00000001031e1eb4  dvaui::ui::UI_Node::UI_DispatchMouseEvent(dvaui::ui::MouseEvent  const&, bool) + 68
      23  com.adobe.dvaui.framework         0x0000000103255433  dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent  const&, bool) + 595
      24  com.adobe.dvaui.framework         0x0000000103251249  dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_Event  const&) + 313
      25  com.adobe.dvaui.framework         0x00000001032578a2 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 450
      26  com.adobe.dvaui.framework         0x000000010324238f dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 31
      27  com.adobe.dvaui.framework         0x000000010324808b dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 59
      28  com.adobe.dvacore.framework       0x0000000102d4de16 int  dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*,  void*) + 38
      29  ...e.AfterEffectsLib.framework    0x0000000100663396 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5382
      30  ...e.AfterEffectsLib.framework    0x00000001006634c1 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5681
      31  com.adobe.dvacore.framework       0x0000000102d4ccf5 void  dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>,  bool*) + 197
      32  com.adobe.dvacore.framework       0x0000000102d4ec83 void  dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>,  bool*) + 99
      33  com.adobe.dvaui.framework         0x000000010324b34d -[DVAMacContainerView mouseDown:] + 253
      34  com.apple.AppKit                  0x00007fff882d934f -[NSWindow sendEvent:] + 5409
      35  com.apple.AppKit                  0x00007fff8820ea86 -[NSApplication sendEvent:] + 4719
      36  com.adobe.dvaui.framework         0x0000000103243d6f -[DVAMacApplication sendEvent:] + 223
      37  ...e.AfterEffectsLib.framework    0x0000000100470f73 0x10046a000 + 28531
      38  com.apple.AppKit                  0x00007fff881a54da -[NSApplication run] + 474
      39  ...e.AfterEffectsLib.framework    0x00000001006b74a2  PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char  const*, char const*, PT_TrackerEntryPoints const*) + 16386
      40  ...e.AfterEffectsLib.framework    0x000000010066181c SetAPETerminateFunc(boost::function<void ()()> const&) + 1308
      41  ...e.AfterEffectsLib.framework    0x0000000100661ee4 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 84
      42  com.adobe.AfterEffects            0x00000001000043b8 main + 1144
      43  com.adobe.AfterEffects            0x0000000100003895 _start + 227
      44  com.adobe.AfterEffects            0x00000001000037b1 start + 33
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib                 0x00007fff80bb416a kevent + 10
      1   libSystem.B.dylib                 0x00007fff80bb603d _dispatch_mgr_invoke + 154
      2   libSystem.B.dylib                 0x00007fff80bb5d14 _dispatch_queue_invoke + 185
      3   libSystem.B.dylib                 0x00007fff80bb583e _dispatch_worker_thread2 + 252
      4   libSystem.B.dylib                 0x00007fff80bb5168 _pthread_wqthread + 353
      5   libSystem.B.dylib                 0x00007fff80bb5005 start_wqthread + 13
      Thread 2:
      0   libSystem.B.dylib                 0x00007fff80bd5fca __semwait_signal + 10
      1   libSystem.B.dylib                 0x00007fff80bd9de1 _pthread_cond_wait + 1286
      2   com.adobe.amt.services            0x000000010dd23c53 AMTConditionLock::LockWhenCondition(int) + 37
      3   com.adobe.amt.services            0x000000010dd1ccce _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 92
      4   com.adobe.amt.services            0x000000010dd23cbe AMTThread::Worker(void*) + 28
      5   libSystem.B.dylib                 0x00007fff80bd4536 _pthread_start + 331
      6   libSystem.B.dylib                 0x00007fff80bd43e9 thread_start + 13
      Thread 3:
      2   ...ple.CoreServices.CarbonCore    0x00007fff8291ce27 TSWaitOnCondition + 118
      3   ...ple.CoreServices.CarbonCore    0x00007fff8288c310 TSWaitOnConditionTimedRelative + 177
      4   ...ple.CoreServices.CarbonCore    0x00007fff8288621b MPWaitOnQueue + 215
      5   ...e.Frameworks.ASL.Foundation    0x0000000104dc2080 ASL::(anonymous namespace)::TaskProc(void*) + 96
      6   ...ple.CoreServices.CarbonCore    0x00007fff8285e411 PrivateMPEntryPoint + 63
      7   libSystem.B.dylib                 0x00007fff80bd4536 _pthread_start + 331
      8   libSystem.B.dylib                 0x00007fff80bd43e9 thread_start + 13
      Thread 4:
      5   AdobeACE                          0x0000000108eff18d 0x108ec5000 + 237965
      6   AdobeACE                          0x0000000108efeb3a 0x108ec5000 + 236346
      7   ...ple.CoreServices.CarbonCore    0x00007fff8285e411 PrivateMPEntryPoint + 63
      8   libSystem.B.dylib                 0x00007fff80bd4536 _pthread_start + 331
      9   libSystem.B.dylib                 0x00007fff80bd43e9 thread_start + 13
      Thread 5:
      Thread 6:
      Thread 7:
      5   com.adobe.dvacore.framework       0x0000000102db5a1f  dvacore::threads::(anonymous  namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue>  const&, boost::shared_ptr<dvacore::threads::Gate> const&)  + 143
      6   com.adobe.dvacore.framework       0x0000000102d4ed5e boost::function0<void>::operator()() const + 46
      7   com.adobe.dvacore.framework       0x0000000102dade53  dvacore::threads::(anonymous namespace)::LaunchThread(std::string  const&, boost::function0<void> const&,  dvacore::threads::ThreadPriority, boost::function<void ()()>  const&, boost::function<void ()()> const&) + 99
      8   ...obe.boost_threads.framework    0x0000000107fd4ac4 thread_proxy + 132
      9   libSystem.B.dylib                 0x00007fff80bd4536 _pthread_start + 331
      10  libSystem.B.dylib                 0x00007fff80bd43e9 thread_start + 13
      Thread 8:
      Thread 9:
      Thread 10:
      Thread 11:
      Thread 12:
      Thread 13:
      Thread 14:
      1   ...dobe.dvatransport.framework    0x0000000107d2ec4e boost::asio::detail::kqueue_reactor<false>::run(bool) + 478
      2   ...dobe.dvatransport.framework    0x0000000107d2fd05  boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false>  >::run(boost::system::error_code&) + 517
      3   ...dobe.dvatransport.framework    0x0000000107d0d8cc SkyConnectionEnv::MainLoop() + 76
      4   ...dobe.dvatransport.framework    0x0000000107d0d939 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
      5   ...obe.boost_threads.framework    0x0000000107fd4ac4 thread_proxy + 132
      6   libSystem.B.dylib                 0x00007fff80bd4536 _pthread_start + 331
      7   libSystem.B.dylib                 0x00007fff80bd43e9 thread_start + 13
      Thread 15:
      2   ...dobe.dvatransport.framework    0x0000000107d2fe3f  boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false>  >::run(boost::system::error_code&) + 831
      3   ...dobe.dvatransport.framework    0x0000000107d30a35  boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service<boost::asio ::ip::tcp>::work_io_service_runner>::run()  + 53
      4   ...dobe.dvatransport.framework    0x0000000107d15c79 asio_detail_posix_thread_function + 25
      Thread 16:
      Thread 17:
      Thread 18:
      Thread 19:
      2   com.adobe.AfterEffects.MThread    0x00000001282fea8f main + 20783
      3   com.adobe.dvacore.framework       0x0000000102d4ed5e boost::function0<void>::operator()() const + 46
      4   com.adobe.dvacore.framework       0x0000000102dade53  dvacore::threads::(anonymous namespace)::LaunchThread(std::string  const&, boost::function0<void> const&,  dvacore::threads::ThreadPriority, boost::function<void ()()>  const&, boost::function<void ()()> const&) + 99
      Thread 20:
      Thread 21:
      Thread 22:
      Thread 23:
      Thread 24:
      2   com.adobe.AfterEffects.OpenEXR    0x000000012a0814c6 IlmThread::Semaphore::wait() + 70
      3   com.adobe.AfterEffects.OpenEXR    0x000000012a08033c IlmThread::(anonymous namespace)::WorkerThread::run() + 188
      4   libSystem.B.dylib                 0x00007fff80bd4536 _pthread_start + 331
      5   libSystem.B.dylib                 0x00007fff80bd43e9 thread_start + 13
      Thread 25:
      Thread 26:
      Thread 27:
      Thread 28:
      1   libSystem.B.dylib                 0x00007fff80bd5e59 nanosleep + 148
      2   ...dobe.AfterEffects.Scripting    0x000000012ab08c7b zcfree + 197989
      3   ...dobe.AfterEffects.Scripting    0x000000012aaebc93 zcfree + 79229
      4   ...dobe.AfterEffects.Scripting    0x000000012ab08d76 zcfree + 198240
      Thread 29:
      2   com.adobe.adobeswfl               0x000000012b3da89d APXGetHostAPI + 2465805
      3   com.adobe.adobeswfl               0x000000012b1935e9 APXGetHostAPI + 77145
      4   com.adobe.adobeswfl               0x000000012b3da9b1 APXGetHostAPI + 2466081
      5   com.adobe.adobeswfl               0x000000012b3dad1a APXGetHostAPI + 2466954
      6   com.adobe.adobeswfl               0x000000012b3dae49 APXGetHostAPI + 2467257
      Thread 30:
      Thread 31:
      Thread 32:
      Thread 33:
      0   libSystem.B.dylib                 0x00007fff80b9b2da mach_msg_trap + 10
      1   libSystem.B.dylib                 0x00007fff80b9b94d mach_msg + 59
      2   com.apple.CoreFoundation          0x00007fff81c12932 __CFRunLoopRun + 1698
      3   com.apple.CoreFoundation          0x00007fff81c11dbf CFRunLoopRunSpecific + 575
      4   com.apple.CoreMediaIOServices     0x00007fff85e7b62b MIO::DAL::RunLoop::OwnThread(void*) + 147
      5   com.apple.CoreMediaIOServices     0x00007fff85e7d1f6 CAPThread::Entry(CAPThread*) + 140
      Thread 34:
      0   libSystem.B.dylib                 0x00007fff80b9b33a semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib                 0x00007fff80bd9cd2 _pthread_cond_wait + 1015
      2   com.adobe.adobeswfl               0x000000012b3da869 APXGetHostAPI + 2465753
      3   com.adobe.adobeswfl               0x000000012b3f70ec APXGetHostAPI + 2582620
      Thread 35:
      3   com.adobe.adobeswfl               0x000000012b574ef3 APXGetHostAPI + 4146787
      Thread 36:
      2   libtbb.dylib                      0x000000010001222c tbb::internal::GenericScheduler::wait_while_pool_is_empty() + 92
      3   libtbb.dylib                      0x000000010001cb84  tbb::internal::CustomScheduler<tbb::internal::IntelSchedulerTraits>::wait_for_all(tbb::ta sk&,  tbb::task*) + 1858
      4   libtbb.dylib                      0x0000000100014e3a tbb::internal::GenericScheduler::worker_routine(void*) + 632
      Thread 37:
      Thread 38:
      Thread 39:
      Thread 40:
      2   ...e.AfterEffectsLib.framework    0x00000001006a901e  ae::egg::KeyboardEvent::KeyboardEvent(dvaui::ui::KeyboardEvent  const&) + 40558
      3   ...e.AfterEffectsLib.framework    0x00000001006abe26  ae::egg::KeyboardEvent::KeyboardEvent(dvaui::ui::KeyboardEvent  const&) + 52342
      4   com.adobe.dvacore.framework       0x0000000102d4ed5e boost::function0<void>::operator()() const + 46
      5   com.adobe.dvacore.framework       0x0000000102dade53  dvacore::threads::(anonymous namespace)::LaunchThread(std::string  const&, boost::function0<void> const&,  dvacore::threads::ThreadPriority, boost::function<void ()()>  const&, boost::function<void ()()> const&) + 99
      6   ...obe.boost_threads.framework    0x0000000107fd4ac4 thread_proxy + 132
      Thread 41:
      0   libSystem.B.dylib                 0x00007fff80b9b32e semaphore_timedwait_trap + 10
      1   ...ple.CoreServices.CarbonCore    0x00007fff828f31f2 MPWaitOnSemaphore + 96
      2   MultiProcessor Support            0x0000000125ce7bd1 ThreadFunction(void*) + 69
      3   ...ple.CoreServices.CarbonCore    0x00007fff8285e411 PrivateMPEntryPoint + 63
      Thread 42:
      Thread 43:
      Thread 44:
      2   com.BorisFX.bcc_ae_8bit           0x00000001373b5563 XSyncEvent::WaitForEvent(int) + 131
      3   com.BorisFX.bcc_ae_8bit           0x00000001374ba94b OGL::Thread::Process() + 155
      4   com.BorisFX.bcc_ae_8bit           0x00000001373b5752 XSyncThreadTask(void*) + 18
      Thread 45:
      5   com.BorisFX.bcc_ae_8bit           0x0000000136a6be31 Queue::Wait(long*, Job**, int) + 17
      6   com.BorisFX.bcc_ae_8bit           0x0000000137184f3d BankQueue::DoMPTask(Task*) + 77
      7   com.BorisFX.bcc_ae_8bit           0x00000001371850a3 Task::MPTask(void*) + 19
      8   ...ple.CoreServices.CarbonCore    0x00007fff8285e411 PrivateMPEntryPoint + 63
      Thread 46:
      Thread 47:
      Thread 48:
      Thread 49:  com.apple.CFSocket.private
      0   libSystem.B.dylib                 0x00007fff80bdee92 select$DARWIN_EXTSN + 10
      1   com.apple.CoreFoundation          0x00007fff81c34498 __CFSocketManager + 824
      2   libSystem.B.dylib                 0x00007fff80bd4536 _pthread_start + 331
      3   libSystem.B.dylib                 0x00007fff80bd43e9 thread_start + 13
      Thread 50:
      Thread 51:
      2   com.apple.audio.CoreAudio         0x00007fff831b967c CAGuard::WaitFor(unsigned long long) + 168
      3   com.apple.audio.CoreAudio         0x00007fff831bbc0b CAGuard::WaitUntil(unsigned long long) + 185
      4   com.apple.audio.CoreAudio         0x00007fff831b9d75 HP_IOThread::WorkLoop() + 1369
      5   com.apple.audio.CoreAudio         0x00007fff831b9817 HP_IOThread::ThreadEntry(HP_IOThread*) + 9
      6   com.apple.audio.CoreAudio         0x00007fff831b9745 CAPThread::Entry(CAPThread*) + 125
      Thread 52:
      0   libSystem.B.dylib                 0x00007fff80bb4f8a __workq_kernreturn + 10
      1   libSystem.B.dylib                 0x00007fff80bb539c _pthread_wqthread + 917
      2   libSystem.B.dylib                 0x00007fff80bb5005 start_wqthread + 13
      Thread 53:
      Thread 54:
      Thread 0 crashed with X86 Thread State (64-bit):
         rax: 0x0000000000000000  rbx: 0x00007fff5fbfdab0  rcx: 0x00007fff5fbfda88  rdx: 0x0000000000000000
         rdi: 0x0000000000000b22  rsi: 0x0000000000000006  rbp: 0x00007fff5fbfdaa0  rsp: 0x00007fff5fbfda88
          r8: 0x0000000102a96760   r9: 0x0000000000000001  r10: 0x00007fff80be5656  r11: 0x0000000000000206
         r12: 0x00007fff5fbfdac0  r13: 0x00007fff5fbfe180  r14: 0x00000001b0f21c50  r15: 0x000000010eaa6410
         rip: 0x00007fff80be9616  rfl: 0x0000000000000206  cr2: 0x00007fff80c74436
      Binary Images:
              0x100000000 -        0x100004ff3 +com.adobe.AfterEffects 10.0.1  (10.0) <6B57EDE6-8898-E72E-05C0-D54EA9E78EF7> /Applications/Adobe  After Effects CS5/Adobe After Effects CS5.app/Contents/MacOS/After  Effects
              0x100009000 -        0x100022feb +libtbb.dylib ??? (???)  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/libtbb.dylib
              0x100033000 -        0x100039feb +libtbbmalloc.dylib ??? (???)  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/libtbbmalloc.dylib
              0x100040000 -        0x10004cff5  +com.adobe.boost_signals.framework boost_signals version 5.0.0  (5.0.0.213330) <7C5184BC-4FE9-56D9-CAE9-49D669C6108B>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
              0x10005e000 -        0x10005ffff  +com.adobe.boost_system.framework boost_system version 5.0.0  (5.0.0.213330) <5B2E6816-3C31-78F7-A163-368475286EDA>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
              0x100065000 -        0x10006cff3  +com.adobe.boost_date_time.framework boost_date_time version 5.0.0  (5.0.0.213330) <784431BB-1A4A-5F0F-4641-0541FE7F4430>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
              0x10007c000 -        0x100081ffd +com.adobe.AdobeCrashReporter  3.0 (3.0.20100302) <DFFB9A08-8369-D65F-161F-7C61D562E307>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
              0x100086000 -        0x1001c9fef +WRServices ??? (???)  <DD50D315-C0EC-C729-AC67-92588187E8C7> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
              0x100215000 -        0x100319fef +hydra_filters ??? (???)  <177463AB-3833-13B3-20B3-7B228BE9BC9C> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/hydra_filters.framework/Versions/A/hydra_filters
              0x10040e000 -        0x10042cfff +image_runtime ??? (???)  <5896DB90-E23E-5C6E-98E5-8E52698ACE61> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
              0x100466000 -        0x100467fff +ALOG.dylib ??? (???)  <247DF308-661D-FC7A-4A53-C8EA58CB478C> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ALOG.dylib
              0x10046a000 -        0x100e3efef  +com.adobe.AfterEffectsLib.framework AfterFXLib 1.0 (1.0)  <8B3C384E-FD17-7C25-FC5B-2D226C5A30DA> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AfterFXLib.framework/Versions/A/AfterFXLib
              0x101197000 -        0x101197ff7 +AEFX.dylib ??? (???)  <87957ABB-824B-D113-11F1-E9950FBC356E> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AEFX.dylib
              0x10119a000 -        0x101555fe7 +BEE.dylib ??? (???)  <C494E8DB-1734-E409-6792-B49FD70F809F> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BEE.dylib
              0x10179e000 -        0x1017adff3 +BEZ.dylib ??? (???)  <D478437D-E3E9-DF6F-C269-E4786331B205> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BEZ.dylib
              0x1017b1000 -        0x1017bcff3 +BM.dylib ??? (???)  <C3D22738-E352-F136-7EFB-FCA84A8DF3F2> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BM.dylib
              0x1017c3000 -        0x1017fefff +COR.dylib ??? (???)  <82A66D1C-3411-28F7-55E4-44F5B23CD179> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/COR.dylib
              0x10181a000 -        0x10183aff7 +FILE.dylib ??? (???)  <8D94218F-3D12-5DD1-F7ED-995E32F320D7> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FILE.dylib
              0x101848000 -        0x101875fff +FLO.dylib ??? (???)  <5ADDC857-45E8-C8CD-38BC-9B1745179E60> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FLO.dylib
              0x10187b000 -        0x10193efff +FLT.dylib ??? (???)  <2902EB47-A004-31D1-DC5F-A0E2FF8FECE7> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FLT.dylib
              0x1019a1000 -        0x1019a8ff3 +LIST.dylib ??? (???)  <EBCE800F-92A6-6DE5-A588-25C7ABE134B1> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/LIST.dylib
              0x1019ac000 -        0x1019bffff +M.dylib ??? (???)  <9C5728D1-8641-C50C-65A8-B32357F2C3E6> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/M.dylib
              0x1019c4000 -        0x1019cdff7 +MC.dylib ??? (???)  <D14CEF04-2834-3D70-2EA8-80D122832D00> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MC.dylib
              0x1019d4000 -        0x101a34fff +MSK.dylib ??? (???)  <E7026CA5-C04F-79F5-FCBC-4EDD42404683> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MSK.dylib
              0x101a48000 -        0x101a5fff7 +OM.dylib ??? (???)  <24285638-08B3-5017-BB4C-C352BD01B3A6> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/OM.dylib
              0x101a67000 -        0x101a89ff7 +P.dylib ??? (???)  <3ADABBEF-01A7-DC39-A53D-BA41C3FA402D> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/P.dylib
              0x101a92000 -        0x101ddbfff +PF.dylib ??? (???)  <F5764ECA-0A0D-468F-3320-CDF9E32862F2> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PF.dylib
              0x101e17000 -        0x102020fef +PIN.dylib ??? (???)  <0C3F81B8-33B7-D233-3296-1BF9B878761D> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PIN.dylib
              0x1020a1000 -        0x1020bbfff +PLUG.dylib ??? (???)  <C4AAFD62-C761-417D-2E19-1282372830A3> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PLUG.dylib
              0x1020c6000 -        0x1020d9fff +PR.dylib ??? (???)  <80E85C07-A375-A91F-8062-88AA924AE278> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PR.dylib
              0x1020e0000 -        0x1020e6fff +PREF.dylib ??? (???)  <86484BE5-76F4-4732-7131-8B22A4AB6B47> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PREF.dylib
              0x1020ea000 -        0x102102fff +RG.dylib ??? (???)  <73804179-7CFE-B9EB-FE60-28386D472CC3> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RG.dylib
              0x10210b000 -        0x10210dff7 +RI.dylib ??? (???)  <A4E4E647-4A64-F605-00DD-40954ED0AA00> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RI.dylib
              0x102110000 -        0x102111fff +RND.dylib ??? (???)  <CFA19218-EE1C-869B-CB20-A2AC8875CD94> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RND.dylib
              0x102118000 -        0x102177ff7 +SLU.dylib ??? (???)  <AD49A5CA-0E54-5427-850E-7C1F6CE19A8D> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SLU.dylib
              0x10219d000 -        0x1021b9ffd +SND.dylib ??? (???)  <A030E529-FE40-6952-0E2F-116BB4896D6C> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SND.dylib
              0x1021c1000 -        0x1021c4ff1 +STR.dylib ??? (???)  <6AEB75A1-DC87-589A-9260-B8F8D0FF0186> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/STR.dylib
              0x1021c8000 -        0x1021cbfff +T.dylib ??? (???)  <56B3122B-B555-5DE2-578C-28E07782987E> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/T.dylib
              0x1021ce000 -        0x10220bff5 +TDB.dylib ??? (???)  <F9C692F8-04DE-AF9B-1043-6ED200788D4A> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/TDB.dylib
              0x10221f000 -        0x1028cafe5 +TXT.dylib ??? (???)  <2406D646-4453-6A1E-E760-9259539A793D> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/TXT.dylib
              0x102a69000 -        0x102aa5ff1 +U.dylib ??? (???)  <F11F145C-1AF8-9E01-6BA9-CC2914BB8F64> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/U.dylib
              0x102ab9000 -        0x102abdfff +VAL.dylib ??? (???)  <643F797E-4BA9-7A56-AD6D-30213837097D> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VAL.dylib
              0x102ac0000 -        0x102b70fff +com.adobe.exo.framework exo  version 5.0.0 (5.0.0.213330)  <E4327151-F451-DD21-0696-CC980D027822> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/exo.framework/Versions/A/exo
              0x102c77000 -        0x102c9dff3 +PREM.dylib ??? (???)  <FF94B54D-43D7-D3C8-D9CA-CF3C27E676E0> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PREM.dylib
              0x102cb1000 -        0x102d0afff +FRP.dylib ??? (???)  <590CA539-77C5-3671-821F-EE1A4B1DF5C5> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FRP.dylib
              0x102d27000 -        0x102e85ff7 +com.adobe.dvacore.framework  dvacore version 5.0.0 (5.0.0.213330)  <2ED41E92-CA4E-F981-0A73-EECDD22BAE5D> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
              0x102ff9000 -        0x103340ff7 +com.adobe.dvaui.framework dvaui  version 5.0.0 (5.0.0.213330)  <26699551-C5FE-77C5-D6B9-0C6034B41E3F> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
              0x103701000 -        0x1037affff  +com.adobe.dvaworkspace.framework dvaworkspace version 5.0.0  (5.0.0.213330) <705E0390-9563-FA39-9AD1-4328B2C9E1C0>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
              0x10388b000 -        0x1038abfef  +com.adobe.dvaunittesting.framework dvaunittesting version 5.0.0  (5.0.0.213330) <7ADEF3C2-30B8-547F-3E1D-BB80B4D6509A>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
              0x1038d4000 -        0x1038e4ff8 +com.adobe.ahclientframework  1.5.0.30 (1.5.0.30) <5D6FFC4E-7B81-3E8C-F0D4-66A3FA94A837>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
              0x1038ef000 -        0x103967fef +com.adobe.adobe_caps adobe_caps  3.0.116.0 (3.0.116.0) <4A355686-1451-B19A-0C55-DFE49FD2539E>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
              0x10397d000 -        0x1039e2fff +aif_core ??? (???)  <568D781D-2C64-2929-2D54-4D5ED733BA5A> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
              0x103a24000 -        0x103c53fff +aif_ogl ??? (???)  <8B39A818-2295-27C0-C7CC-23205863A910> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
              0x103e17000 -        0x103e2dfff +data_flow ??? (???)  <773FBF60-436C-D83C-70C3-DF184CE733AE> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
              0x103e60000 -        0x104355fef +image_compiler ??? (???)  <B5099546-A56B-24C4-F073-37A7AE81AA24> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/image_compiler.framework/Versions/A/image_compiler
              0x104895000 -        0x10492bfff +image_flow ??? (???)  <2752F430-8256-E728-D11B-5F0734CD3D0D> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
              0x104a11000 -        0x104a50ff7  +com.adobe.dynamiclinkui.framework dynamiclinkui version 5.0.0  (5.0.0.213330) <BD01B92F-BA04-F1A9-6155-1B42C24C4526>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
              0x104aa6000 -        0x104c6ffff +com.adobe.dynamiclink.framework  dynamiclink version 5.0.0 (5.0.0.213330)  <B56BCABE-8A7D-DFC3-F188-63102A103BEA> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
              0x104d8d000 -        0x104defff5  +com.adobe.MediaCore.Frameworks.ASL.Foundation 1.0 (1.0)  <8A37AB47-7613-9C3E-227F-7D9B7BC874E9> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
              0x104ed6000 -        0x104eecfff +ASLMessaging ??? (???)  <FF6E2081-5AFD-3A38-E302-E59229FD8C1D> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
              0x104f0b000 -        0x104f1cffe +ASLUnitTesting ??? (???)  <B08CF505-E518-72F2-6BD3-2F8220F4A9D8> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
              0x104f34000 -        0x104f4eff3  +com.adobe.MediaCore.Frameworks.AudioFilterHost 1.0 (1.0)  <77D98EE7-4093-301B-31C8-6304642AC4DE> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
              0x104f76000 -        0x104faefff  +com.adobe.MediaCore.Frameworks.AudioFilters ??? (1.0)  <78471468-4C7F-0CF6-140D-798FCAF1AECB> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
              0x105019000 -        0x105091fe3  +com.adobe.MediaCore.Frameworks.AudioRenderer ??? (1.0)  <D121C229-4251-5D3A-595F-650A02AE5B90> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
              0x10512c000 -        0x10516afe1  +com.adobe.MediaCore.Frameworks.AudioSupport 1.0 (1.0)  <B082D5D2-92C2-4038-3583-6E624C2A0533> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
              0x1051b3000 -        0x105c24fef  +com.adobe.MediaCore.Frameworks.Backend ??? (1.0)  <0BB48068-8E97-BF23-C679-6AE5DFDCD49B> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
              0x10694b000 -        0x106aefff3  +com.adobe.MediaCore.Frameworks.ImageRenderer ??? (1.0)  <B4CCC972-CADD-7751-7F46-7F28674F4DBF> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
              0x106c1f000 -        0x106da9ff7  +com.adobe.MediaCore.Frameworks.ImporterHost 1.0 (1.0)  <F34576C9-5DF6-9085-4804-8C5A074A512E> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
              0x106f6b000 -        0x106f9ffff +com.adobe.MediaFoundation ???  (1.0) <2237E626-39E2-4FC7-0886-7385E9A0D827> /Applications/Adobe  After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
              0x106fe2000 -        0x106fe5fff  +com.adobe.MediaCore.Frameworks.MediaUtils 1.0 (1.0)  <DE5FE590-E42C-70DA-0872-6FB725861729> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
              0x106fea000 -        0x106febfff  +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0)  <E6A57F34-8922-5D13-B6BE-1D53C0675555> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
              0x106ff0000 -        0x10702bfff  +com.adobe.MediaCore.Frameworks.MLFoundation 1.0 (1.0)  <F9C61C12-0EA0-EA53-5AF0-81381E8C782B> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
              0x10707b000 -        0x1070adfff  +com.adobe.MediaCore.Frameworks.PluginSupport 1.0 (1.0)  <D60E282B-70B2-2A0F-AFAE-EC4C84AE27CB> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
              0x1070ec000 -        0x1070edfff +PRM ??? (???)  <BDF8EC3E-8EA0-FCB1-8A7B-38CEF4020BE1> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
              0x1070f1000 -        0x107129fff  +com.adobe.MediaCore.Frameworks.SweetPeaSupport 1.0 (1.0)  <CD2EBF6A-F10E-2B20-9F57-D6F49E5883B0> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
              0x10717a000 -        0x1071c3fff +com.adobe.MediaCore.VideoFrame  1.0 (1.0) <271EA98F-DEB4-932F-3F78-1E76BFE5B8F1>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
              0x107211000 -        0x10732dfff  +com.adobe.MediaCore.Frameworks.VideoRenderer 1.0 (1.0)  <3DA8F0D4-6E35-7EE4-EA45-E31F3B4D34FB> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
              0x107497000 -        0x10753ffe1 +com.adobe.dvaeve.framework  dvaeve version 5.0.0 (5.0.0.213330)  <3320F862-69F9-91B9-77B3-58638E9A5F57> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
              0x10763c000 -        0x1076affff  +com.adobe.MediaCore.Frameworks.PlayerHost 1.0 (1.0)  <B285C74F-2478-5536-7936-CD061F43A182> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
              0x10774a000 -        0x10781cfff  +com.adobe.MediaCore.Frameworks.VideoFilterHost 1.0 (1.0)  <6A71B201-FF19-4B17-E188-48B7AE5F3A3E> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
              0x1078df000 -        0x107949ff7 +com.adobe.amtlib amtlib  3.0.0.64 (3.0.0.64) <6B2F73C2-10AB-08B3-4AB0-A31C83D1E5E0>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
              0x10797c000 -        0x107a1aff2 +libicucnv.dylib.36.0 36.0.0  (compatibility 36.0.0) <5651FB7C-24ED-8CC8-2ADE-A5CB7CA493C3>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
              0x107a3a000 -        0x107a55fff +libicudata.dylib.36.0 36.0.0  (compatibility 36.0.0) <FEF83A1C-8D48-66B4-BED6-B91835D1AA68>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
              0x107a58000 -        0x107ab2fff +com.adobe.dvametadata.framework  dvametadata version 5.0.0 (5.0.0.213330)  <18F7D94A-F4DB-1721-FBDF-1ED970BCF942> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
              0x107b34000 -        0x107bb8fff  +com.adobe.dvametadataUI.framework dvametadataUI version 5.0.0  (5.0.0.213330) <73A09435-12CC-3B38-8681-B72FED6E4D9D>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
              0x107c4f000 -        0x107c93ff7  +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 5.0.0  (5.0.0.213330) <83DDA3DF-57A0-AEDF-2793-685ABA6E8CCE>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
              0x107cb3000 -        0x107cccfff  +com.adobe.dvamediatypes.framework dvamediatypes version 5.0.0  (5.0.0.213330) <5859F2A1-3BFC-8EAD-F008-AF0333FF44B8>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
              0x107ceb000 -        0x107d61ff7  +com.adobe.dvatransport.framework dvatransport version 5.0.0  (5.0.0.213330) <DA8FFA3F-BD11-2EE7-A974-228F49E1652D>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
              0x107de4000 -        0x107e20ff3 +com.adobe.dvamarshal.framework  dvamarshal version 5.0.0 (5.0.0.213330)  <625FCBA1-47B3-DAD5-C15B-78E572F6717A> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
              0x107e8c000 -        0x107e9afff  +com.adobe.MediaCore.Frameworks.ProjectSupport 1.0 (1.0)  <57A965FC-3754-BFB3-A1D0-253D5B39E901> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
              0x107eae000 -        0x107ef1fff +DynamicLinkMedia ??? (???)  <FF94B2FF-93A5-623E-04A6-125572A95FE3> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
              0x107f5e000 -        0x107f5eff7  libmx.A.dylib 315.0.0  (compatibility 1.0.0) <B146C134-CE18-EC95-12F8-E5C2BCB43A6B>  /usr/lib/libmx.A.dylib
              0x107f61000 -        0x107f8cff6 +AdobeAXE8SharedExpat ??? (???)  <F5C1010B-CAFF-5290-8B55-6FEB3A287225> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
              0x107f9e000 -        0x107fa4ff7  com.apple.agl 3.0.12  (AGL-3.0.12) <1AB34F57-2E8D-42FB-A484-5CCB928CA456>  /System/Library/Frameworks/AGL.framework/Versions/A/AGL
              0x107fab000 -        0x107fc8fff +AdobeBIB ??? (???)  <3FF7BFF2-52DF-046A-A081-2BDB1055A1B4> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
              0x107fd2000 -        0x107fdaff3  +com.adobe.boost_threads.framework boost_threads version 5.0.0  (5.0.0.213330) <50E5F61F-42D9-1F4D-EBF7-47BE6A864A73>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
              0x107fe9000 -        0x10803ffeb  +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011)  <03B80698-2C3B-A232-F15F-8F08F8963A19> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
              0x108084000 -        0x108142ffb +filter_graph ??? (???)  <3C2316AB-7ACF-A257-97EF-33E00FD5AC67> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/filter_graph.framework/Versions/A/filter_graph
              0x10826a000 -        0x1082c8ffd +AdobeXMP ??? (???)  <29839F01-4A21-5B72-FF9A-E030D214F5E2> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
              0x1082d6000 -        0x108362fe3 +AdobeXMPFiles ??? (???)  <C4531436-CA4F-8A06-0481-CD1648C20C48> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
              0x10839a000 -        0x10843afef +com.adobe.AdobeScCore ScCore  4.1.25 (4.1.25.10116) <2049AC79-9EFA-1D8B-C577-174B36569A29>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
              0x108480000 -        0x108524ffb +com.adobe.AdobeExtendScript  ExtendScript 4.1.25 (4.1.25.10116)  <B2464DBF-230E-3187-6004-F8A804ED24A3> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
              0x108586000 -        0x108664fef +AdobeAXEDOMCore ??? (???)  <8D4592B8-5DA1-D957-B1BA-FB20116514DD> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
              0x1086dc000 -        0x108a0dfe7 +AdobeCoolType ??? (???)  <C93152AA-AC85-5157-0B28-AFE1D6CAA31F> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
              0x108aa9000 -        0x108df3fe7 +AdobeAGM ??? (???)  <E48474D7-E499-6F7A-9F2A-E9A82D075405> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
              0x108ec5000 -        0x108fdafff +AdobeACE ??? (???)  <0A896D92-86A5-D870-9BE0-755ADD1B1A33> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
              0x108fff000 -        0x109020fff +AdobeBIBUtils ??? (???)  <1468CBC0-B799-0808-91D1-78BAD0320F99> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
              0x10902d000 -        0x109100ffb +AdobeJP2K ??? (???)  <8571D9BA-44F9-92A3-0444-5FFAC2994B88> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
              0x109120000 -        0x109161ff7 +AdobeARE ??? (???)  <CE1A57E7-5175-C3A7-B644-94B4D149ED13> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
              0x10916b000 -        0x1097c3fef +AdobePDFL ??? (???)  <45AA7483-10A6-2DAB-1FF8-62C9E615039E> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
              0x109912000 -        0x109e23fff +AdobeMPS ??? (???)  <10C4E979-45F3-A7C6-0438-262CE5F595B9> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
              0x109ef9000 -        0x109f24fef +AdobeAXE16SharedExpat ??? (???)  <F5E56D3B-AE0E-245C-E706-DFA630D6771C> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedEx pat
              0x109f36000 -        0x10acf9fff +com.adobe.psl AdobePSL  12.0.0.7667 (12.0.0.7667) <F1C9409D-033E-58D0-B902-6422BC488AA5>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
              0x10b069000 -        0x10b114feb  +com.adobe.MediaCore.Frameworks.ExporterHost 1.0 (1.0)  <6F779FBA-40D3-16A5-D7EC-609CF6450518> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
              0x10b228000 -        0x10b248feb +SegMatServices.dylib ??? (???)  <FBBD1251-FEF4-80E8-57EC-919B332187D5> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/SegMatServices.dylib
              0x10b255000 -        0x10b255ff7 +SAM.dylib ??? (???)  <4502C9CF-D856-7BC4-E22A-9BEB4119B2AD> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SAM.dylib
              0x10b258000 -        0x10b33efe7  libcrypto.0.9.7.dylib 0.9.7  (compatibility 0.9.7) <BA5E5276-8696-906D-0A37-0FFEF022B482>  /usr/lib/libcrypto.0.9.7.dylib
              0x10b396000 -        0x10b66efe6 +libxerces-c-3.0.dylib ??? (???)  <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/libxerces-c-3.0.dylib
              0x10b7e8000 -        0x10b7feff6  +com.adobe.AMEAppFoundation.framework ??? (1.0)  <14C553BC-BF4B-C2F1-51E3-0E318D7E727A> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
              0x10b81f000 -        0x10b842ff1  +com.adobe.PostEncodeHost.framework ??? (1.0)  <45EEDD75-E549-F676-2A8E-B3EEA45FC1D8> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
              0x10b870000 -        0x10b92cff7 +AMEWrapper ??? (???)  <21631AD0-2C5F-B73D-22AA-D6712710D6E3> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
              0x10b9eb000 -        0x10baf2fff +com.adobe.EncoderHost.framework  ??? (1.0) <C7488EFE-B96F-8FD9-5CE5-4EF91C6E0E38>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
              0x10bbf7000 -        0x10bdc4fff +com.adobe.SettingsUI.framework  ??? (1.0) <089295DC-226C-B898-9FB7-BA037FE2F56A>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
              0x10c021000 -        0x10c07fff7  +com.adobe.MediaCore.Frameworks.Utilities.QT32Client 1.0 (1.0)  <93CFE7E1-52A1-95A0-1126-B8CB1304D81F> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
              0x10c0ed000 -        0x10c118fff   com.apple.carbonframeworktemplate 1.0 (1.0)  <71D2D8B4-2E61-C6D7-B134-5116431765BE> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
              0x10c152000 -        0x10c17bfff +ameproperties ??? (???)  <64AA3464-459A-77A6-C400-3D5B957161D4> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
              0x10c1be000 -        0x10c1c2ff2 +com.adobe.AppServices.framework  ??? (1.0) <AA9FAEBA-4D36-1F43-7AE7-F19593D57964>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServices
              0x10c680000 -        0x10c6c2fff  +com.adobe.MediaCore.ImporterQuickTime 1.0 (1.0)  <7A2D8B05-C5A9-E892-CB39-8E69E60390D5> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(MediaCore)/ImporterQuickTime.bundle/Contents/MacOS/ImporterQui ckTime
              0x10c703000 -        0x10c705fef  com.apple.textencoding.unicode  2.3 (2.3) <B254327D-2C4A-3296-5812-6F74C7FFECD9>  /System/Library/TextEncodings/Unicode  Encodings.bundle/Contents/MacOS/Unicode Encodings
              0x10da3a000 -        0x10da64ff1 +com.mainconcept.mc_dec_dv 8.5  (8.5.0.14572) <CFF0820D-B6C1-0DB8-43DE-35169748FD94>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/mc_dec_dv.framework/mc_dec_dv
              0x10dac7000 -        0x10dacffff +com.adobe.asneu.framework asneu  version 1.7.0.1 (1.7.0.1) <3D59CB21-F5C7-4232-AB00-DFEB04206024>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
              0x10dd00000 -        0x10dd70ff6 +com.adobe.amt.services  AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010  21:49:00) (3.0.0.64) <52FF1F9B-9991-ECE2-C7E3-09DA1B368CBE>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
              0x10dfe7000 -        0x10dfebfff +com.adobe.AfterEffects.EasyEase  ??? (???) <BABE30E9-6001-5F0D-8083-6540AAD2DA61>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/EasyEase.plugin/Contents/MacOS/EasyEase
              0x10dfee000 -        0x10dff2ff7 +com.adobe.AfterEffects.ExpScale  ??? (???) <5A75FEEA-77D5-EC6F-0EC5-DDA8BD78F058>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/ExpScale.plugin/Contents/MacOS/ExpScale
              0x10dff5000 -        0x10dff9ff7  libFontRegistryUI.dylib ???  (???) <763B8E8F-8602-2096-7CC8-CEE1F4248028>  /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
              0x11fffd000 -        0x120004ff7  +com.adobe.MediaCore.ImporterWave 1.0 (1.0)  <1AE53963-D095-02D6-15AB-308126B926E3> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(MediaCore)/ImporterWave.bundle/Contents/MacOS/ImporterWave
              0x1202c6000 -        0x1202c7fff  libCyrillicConverter.dylib  49.0.0 (compatibility 1.0.0)  <0739FD38-CF46-0ECC-517C-E187C5A3B8D6>  /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
              0x1202cc000 -        0x1202cdfff +com.BorisFX.BCC Lightning X 7 .  0 . 2, 16 bit (111) <624CEB8E-74CE-31BE-7D41-107306A54CD2>  /Library/Application Support/Adobe/Common/Plug-ins/CS5/MediaCore/Boris  Continuum Complete 7.0/BCC Lightning X 64Bit.bundle/Contents/MacOS/BCC  Lightning X 64Bit
              0x1202d4000 -        0x1202d5fff +com.BorisFX.BCC Particle System  X 7 . 0 . 2, 16 bit (111) <E6F9A998-F4F3-44BB-F237-E018C66D0971>  /Library/Application Support/Adobe/Common/Plug-ins/CS5/MediaCore/Boris  Continuum Complete 7.0/BCC Particle System X  64Bit.bundle/Contents/MacOS/BCC Particle System X 64Bit
              0x120303000 -        0x120304ff7 +com.adobe.AfterEffects.Paint  ??? (???) <EED2E53D-7D8A-80A0-6C09-2EF2B94076EF>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Paint.plugin/Contents/MacOS/Paint
              0x120307000 -        0x120316fff +com.adobe.AfterEffects.FreePin  ??? (???) <34D09883-0648-CEB6-4100-DDCDB8B8B8D4>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Puppet.plugin/Contents/MacOS/FreePin
              0x12031a000 -        0x120334fff +com.adobe.pip ??? (5.0.0.2021)  <47380937-5088-41F7-50FA-ADAC9B15C783> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
              0x120368000 -        0x120371fff +FastCore ??? (???)  <4A676BFE-2C56-9651-EFF7-E804EC45C87F> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/FastCore.plugin/Contents/MacOS/FastCore
              0x1206be000 -        0x1206e4fff  GLRendererFloat ??? (???)  <8256EA93-A236-8B55-F214-65896DDB7A0E>  /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
              0x1206fc000 -        0x1206fdfff +com.BorisFX.BCC 3DExt Img  Shatter X 7 . 0 . 2, 16 bit (111)  <6704052D-7DF1-1A25-28A5-B9F463BB0770> /Library/Application  Support/Adobe/Common/Plug-ins/CS5/MediaCore/Boris Continuum Complete  7.0/BCC 3DExt Img Shatter X 64Bit.bundle/Contents/MacOS/BCC 3DExt Img  Shatter X 64Bit
              0x120883000 -        0x120a14fef  GLEngine ??? (???)  <AE898A2A-1C12-9FDB-455F-32601F030904>  /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
              0x120a45000 -        0x120e68fef  libclh.dylib 3.1.1 C  (3.1.1)  <66455CD1-8C09-4A8F-EDA1-D4F2F30663F1>  /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
              0x120e96000 -        0x121d4ffe7   com.apple.driver.AppleIntelHDGraphicsGLDriver 1.6.26 (6.2.6)  <27B7C1AF-1188-249F-840D-D32CF71F9E4B>  /System/Library/Extensions/AppleIntelHDGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelH DGraphicsGLDriver
              0x1225e0000 -        0x1225e1fff  ATSHI.dylib ??? (???)  <F6C4F446-7AC4-7A17-9302-C38A016322B6>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
              0x1245ec000 -        0x1245f0fff  com.apple.audio.AudioIPCPlugIn  1.1.6 (1.1.6) <F99C2FBC-103D-DB2D-8D53-CFB8CEFA90F8>  /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
              0x1245f5000 -        0x1245fbfff   com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12)  <933CA4C6-F428-0E2E-DCBE-FA0284914092>  /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
              0x125bfc000 -        0x125c2aff3 +MMXCore ??? (???)  <0E398A83-FEBA-9272-4A07-04055F56EF16> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/MMXCore.plugin/Contents/MacOS/MMXCore
              0x125cb2000 -        0x125d1dff0 +MultiProcessor Support ???  (???) <101FF20A-2063-75D7-76FC-56974AFBAABE> /Applications/Adobe  After Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/MultiProcessor  Support.plugin/Contents/MacOS/MultiProcessor Support
              0x125d8f000 -        0x125d91fff +com.adobe.AfterEffects.Write_on  ??? (???) <D14890E8-B675-DA80-399A-3E49F96BE1D9>  /Applications/Adobe After Effects  CS5/Plug-ins/Effects/Write_on.plugin/Contents/MacOS/Write_on
              0x12654f000 -        0x126576ff1 +com.mainconcept.mc_enc_dv 8.5  (8.5.0.14572) <46AB8404-6892-F7BF-150E-D8249ECFD0B8>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
              0x126796000 -        0x12679bfff  +com.adobe.MediaCore.ExporterCoreAudio 1.0 (1.0)  <C1A74B80-D569-C330-D735-448B4FAC782F> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(MediaCore)/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCor eAudio
              0x1267a2000 -        0x1267b1fe7  +com.adobe.MediaCore.Frameworks.AudioConverter 1.0 (1.0)  <CCA6D5A2-0C71-5323-7B1C-E072DCE41C2B> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/AudioConverter.framework/Versions/A/AudioConverter
              0x1267e9000 -        0x1269d3fef   com.apple.audio.codecs.Components 2.0.2 (2.0.2)  <CC28CC1B-ACD4-151F-BC5B-E842AC7F075F>  /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
              0x126a3f000 -        0x126a65ff3  +com.adobe.MediaCore.ExporterQuickTimeHost 1.0 (1.0)  <DCE19C8F-D9C7-0272-0EB2-FC8C2DF63485> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(MediaCore)/ExporterQuickTimeHost.bundle/Contents/MacOS/Exporte rQuickTimeHost
              0x126a95000 -        0x126aadff3  +com.adobe.MediaCore.Frameworks.QTParser 1.0 (1.0)  <514A4B12-E7B0-7C96-DBF2-C07C3026B87B> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
              0x126af7000 -        0x126afbfff +com.adobe.AfterEffects.TRKeys  ??? (???) <FF272930-752F-FB11-E057-09DFDCCAB3A8>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/TRKeys.plugin/Contents/MacOS/TRKeys
              0x1278ef000 -        0x1278f0fff +com.BorisFX.BCC Drop Shadow X 7  . 0 . 2, 16 bit (111) <6FE37743-3CAD-D63C-A66D-6499B6F112A1>  /Library/Application Support/Adobe/Common/Plug-ins/CS5/MediaCore/Boris  Continuum Complete 7.0/BCC Drop Shadow X 64Bit.bundle/Contents/MacOS/BCC  Drop Shadow X 64Bit
              0x1278f9000 -        0x1278fcff7 +com.adobe.AfterEffects.Durer  ??? (???) <41DC9F1C-A47C-DBD2-2982-ABEEA82D1568>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Standard3D.plugin/Contents/MacOS/Durer
              0x127a00000 -        0x127ad0ff7  +com.adobe.MediaCore.IPPMPEGDecoder 1.0 (1.0)  <AE3B4FE4-2BD1-FFE3-3657-390214479EF8> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/IPPMPEGDecoder.framework/IPPMPEGDecoder
              0x127b15000 -        0x127cdcfef +com.adobe.MediaCore.ImporterRED  1.01 (1.0) <3381CDA1-F8D1-D2D1-E93E-C1B0C82364CE>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(MediaCore)/ImporterRED.bundle/Contents/MacOS/ImporterRED
              0x1282c8000 -        0x1282c9fff +com.BorisFX.BCC Colorize Glow X  7 . 0 . 2, 16 bit (111) <DE78DA93-0E24-7E08-DAE6-C2D1A19CCEB0>  /Library/Application Support/Adobe/Common/Plug-ins/CS5/MediaCore/Boris  Continuum Complete 7.0/BCC Colorize Glow X  64Bit.bundle/Contents/MacOS/BCC Colorize Glow X 64Bit
              0x1282f4000 -        0x128300fff +com.adobe.AfterEffects.MThread  ??? (???) <E50EF468-274F-D3A0-15A3-B9CB3B9AAF7D>  /Applications/Adobe After Effects  CS5/Plug-ins/Extensions/Mthread.plugin/Contents/MacOS/MThread
              0x128490000 -        0x128511fff  +com.adobe.AfterEffects.AEGPDriver ??? (???)  <C7F9ADE5-79D2-A88E-953D-E1AE3B1F0BDC> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Required/AEGPDriver.plugin/Contents/MacOS/AEGPDriver
              0x128549000 -        0x12855ffe7  +com.adobe.AfterEffects.PS3Export ??? (???)  <1444127E-DF55-B376-ACE5-DDA0C2F3CF54> /Applications/Adobe After  Effects CS5/Plug-ins/Format/PS Layer  Export.plugin/Contents/MacOS/PS3Export
              0x12856b000 -        0x12858dff3  +com.adobe.AfterEffects.PS3Import ??? (???)  <79DCB388-3CC8-D018-DF14-A3C0F3E7C7D9> /Applications/Adobe After  Effects CS5/Plug-ins/Format/PS Layer  Import.plugin/Contents/MacOS/PS3Import
              0x12859e000 -        0x1285a4ff7 +com.adobe.AfterEffects.Sequence  ??? (???) <160CE07F-F2DF-CB1D-A013-D556E4D3AB41>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/Sequence.plugin/Contents/MacOS/Sequence
              0x1285a9000 -        0x1285c6fff +com.adobe.AfterEffects.AudioPal  ??? (???) <B8A77B49-F592-27C7-000A-9DBA0B1435EA>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Audio Palette.plugin/Contents/MacOS/AudioPal
              0x1285d8000 -        0x1285e4ff7  +com.adobe.AfterEffects.LocalizePresets ??? (???)  <38093080-3398-168D-C9AA-11F046EA3ED2> /Applications/Adobe After  Effects  CS5/Plug-ins/Extensions/LocalizePresets.plugin/Contents/MacOS/LocalizePresets
              0x1285ed000 -        0x1285f8fff +com.adobe.AfterEffects.Analyzer  ??? (???) <12EF3B3B-A7E5-9413-6DBB-16DC078B0A58>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/Analyzer.plugin/Contents/MacOS/Analyzer
              0x128700000 -        0x128776fff +com.adobe.AfterEffects.Escher  ??? (???) <6DE5ADDB-608B-DC6B-F45D-1D7A81B03B26>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Advanced3D.plugin/Contents/MacOS/Escher
              0x128783000 -        0x128801ff3  +com.adobe.AfterEffects.AEDynamicLinkServer ??? (???)  <E47693B4-C03B-5DE6-F4D6-C905E1BB7008> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Required/AEDynamicLinkServer.plugin/Contents/MacOS/AEDynamicLinkServer
              0x12893b000 -        0x128978feb  +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications  1.0.0.64 (1.0.0.64) <CD8BD7C7-0F66-29B6-C158-A6EF8DF69996>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
              0x1289b4000 -        0x1289b8fff +com.adobe.AfterEffects.Echo ???  (???) <8C4418C7-0C23-BFBA-16C2-CAA1CF1CE24D> /Applications/Adobe  After Effects CS5/Plug-ins/Effects/Echo.plugin/Contents/MacOS/Echo
              0x1289be000 -        0x1289edffb +com.adobe.AfterEffects.BrushPal  ??? (???) <92CBF24B-AF40-3506-61F4-019C623477EA>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Brush Palette.plugin/Contents/MacOS/BrushPal
              0x128a05000 -        0x128a45ff7 +com.adobe.AfterEffects.CharPal  ??? (???) <394E75A6-99E0-2866-3E70-8CBD4D4DB82B>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Character  Palette.plugin/Contents/MacOS/CharPal
              0x128a66000 -        0x128a88fff +com.adobe.AfterEffects.InfoPal  ??? (???) <99F70291-C93F-D95A-30FF-4E7871A7ADFD>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Info Palette.plugin/Contents/MacOS/InfoPal
              0x128a9c000 -        0x128ac8ffb +com.adobe.AfterEffects.PaintPal  ??? (???) <F7F81EDD-5E6B-B38C-56B9-D71768D31A5B>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Paint Palette.plugin/Contents/MacOS/PaintPal
              0x128ae0000 -        0x128b01ff7 +com.adobe.AfterEffects.ParaPal  ??? (???) <38D78DA1-664C-EEA6-703C-2A110897B406>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Paragraph  Palette.plugin/Contents/MacOS/ParaPal
              0x128b15000 -        0x128cacfff +com.adobe.AfterEffects.SnapCut  ??? (???) <D3827117-B036-C6B8-8A22-C207C78044DC>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Roto Brush.plugin/Contents/MacOS/SnapCut
              0x128cdb000 -        0x128cfdfff +com.adobe.AfterEffects.TimePal  ??? (???) <9D721EAD-2BA9-9BDC-6E1B-42BBBFDF7D77>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Time Palette.plugin/Contents/MacOS/TimePal
              0x128d13000 -        0x128d56fff +com.adobe.AfterEffects.ToolPal  ??? (???) <CA44FE3D-6552-5F3D-A1AE-B71EC5A264EA>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Required/Tool Palette.plugin/Contents/MacOS/ToolPal
              0x128d77000 -        0x128d97ffb  +com.adobe.AfterEffects.TrackerPal ??? (???)  <C7DB4C26-39A7-5F9B-2E47-6520A00BF339> /Applications/Adobe After  Effects CS5/Adobe After Effects CS5.app/Contents/Required/Tracker  Palette.plugin/Contents/MacOS/TrackerPal
              0x128da9000 -        0x129b7bff7  +com.ImagineerSystems.mochashapeconverter4ae 1 (1.0.0)  <3C1F5D08-D515-9E24-35ED-CC76FCCA9675> /Applications/Adobe After  Effects CS5/Plug-ins/Effects/Imagineer/mocha shape converter for  AE.plugin/Contents/MacOS/mochashapeconverter4ae
              0x129d48000 -        0x129daefff  +com.adobe.AfterEffects.AE_OpenGL ??? (???)  <76576A65-32D6-7092-59E3-F6A20F48A617> /Applications/Adobe After  Effects  CS5/Plug-ins/Extensions/AE_OpenGL.plugin/Contents/MacOS/AE_OpenGL
              0x129fc2000 -        0x12a044fe3  +com.adobe.AfterEffects.FlashExporter ??? (???)  <4DCFBC46-FCA2-D963-4979-E0FB994F5108> /Applications/Adobe After  Effects  CS5/Plug-ins/Format/FlashExporter.plugin/Contents/MacOS/FlashExporter
              0x12a071000 -        0x12a1c2feb +com.adobe.AfterEffects.OpenEXR  ??? (???) <E570DDA8-8CD5-5C4B-A8EA-38B63E89231A>  /Applications/Adobe After Effects  CS5/Plug-ins/Format/OpenEXR.plugin/Contents/MacOS/OpenEXR
              0x12a41f000 -        0x12a44ffff +com.adobe.AfterEffects.PNGIO  ??? (???) <DC8B178A-5AF7-6219-CDC2-4F757FC0DAAF>  /Applications/Adobe After Effects  CS5/Plug-ins/Format/PNGIO.plugin/Contents/MacOS/PNGIO
              0x12a45b000 -        0x12a510fff  +com.adobe.AfterEffects.PremiereProImport ??? (???)  <F1237486-5CCC-04C4-98F8-78449851498D> /Applications/Adobe After  Effects  CS5/Plug-ins/Format/PremiereProImport/PremiereProImport.plugin/Contents/MacOS/PremierePro Import
              0x12a53d000 -        0x12a5abfff  +com.adobe.MediaCore.Frameworks.UI 1.0 (1.0)  <E878778B-7ACB-28FA-2535-D2852B4CE1D2> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
              0x12a61c000 -        0x12a678fff +com.adobe.AfterEffects.TIFFIO  ??? (???) <9CF4A767-872F-0D4D-8A6C-AEEE4019B2B9>  /Applications/Adobe After Effects  CS5/Plug-ins/Format/TIFF.plugin/Contents/MacOS/TIFFIO
              0x12a688000 -        0x12a74cfeb +com.adobe.AfterEffects.Vic ???  (???) <6FFC5C50-4976-9665-3D39-EEE7438A7CB1> /Applications/Adobe  After Effects CS5/Plug-ins/Format/Vector  Output.plugin/Contents/MacOS/Vic
              0x12a7a3000 -        0x12a7bcff3 +com.adobe.AfterEffects.Align  ??? (???) <249E6544-947A-121D-46A7-1061A4B3A088>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/Align.plugin/Contents/MacOS/Align
              0x12a7cb000 -        0x12a7dbfff  +com.adobe.AfterEffects.MayaImport ??? (???)  <6E4E0B7B-3551-90E3-CEB3-FAC2125876E9> /Applications/Adobe After  Effects  CS5/Plug-ins/Keyframe/MayaImport.plugin/Contents/MacOS/MayaImport
              0x12a7de000 -        0x12a7f5ff7 +com.adobe.AfterEffects.MetaPal  ??? (???) <4CE0F462-1B67-3A32-C24F-A7921D090017>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/MetaPal.plugin/Contents/MacOS/MetaPal
              0x12a806000 -        0x12a830fff +com.adobe.AfterEffects.Moka ???  (???) <8E21D291-BF16-644F-4526-D3256CDBDF21> /Applications/Adobe  After Effects CS5/Plug-ins/Keyframe/Moka.plugin/Contents/MacOS/Moka
              0x12a841000 -        0x12a855ffb  +com.adobe.AfterEffects.MotionSketch ??? (???)  <F4C3B429-E11E-C7EF-E9F1-6FAA97F274D3> /Applications/Adobe After  Effects  CS5/Plug-ins/Keyframe/MotionSketch.plugin/Contents/MacOS/MotionSketch
              0x12a863000 -        0x12a867ff7  +com.adobe.AfterEffects.RPFImport ??? (???)  <E30E57A5-1DFE-915C-EB88-B33CE9F6E05E> /Applications/Adobe After  Effects CS5/Plug-ins/Keyframe/RPFImport.plugin/Contents/MacOS/RPFImport
              0x12a86a000 -        0x12acbefff  +com.adobe.AfterEffects.Scripting ??? (???)  <5C90290F-9EBA-D6B1-D6CB-08E4757E5AA9> /Applications/Adobe After  Effects CS5/Plug-ins/Keyframe/Scripting.plugin/Contents/MacOS/Scripting
              0x12ae4a000 -        0x12ae4eff8 +com.adobe.ape.shim adbeape  version 3.1.65.7508 (3.1.65.7508)  <0C380604-C686-C2E4-0535-C1FAB230187E> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
              0x12ae52000 -        0x12ae72ffb +com.adobe.ape adbeapecore  version 3.1.70.10055 (3.1.70.10055)  <66373ADB-0865-ECDB-D3D0-B3373FC43919> /Library/Application  Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
              0x12b153000 -        0x12bfbbff3 +com.adobe.adobeswfl ???  (2.0.0.10053) <ADE7E8AA-80B6-7BAC-8205-13D7A0E89DF8>  /Library/Application  Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/Ado beSWFL
              0x12d3c9000 -        0x12d407ff7  com.apple.DP.ScreenInputDevice  13.0 (13.0) <22174597-D163-7A20-C82A-C00C2CA19640>  /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/AppleScreenInpu tDevice.plugin/Contents/MacOS/AppleScreenInputDevice
              0x12d879000 -        0x12d8a1fff  com.apple.mio.DAL.VDC_4 134.0  (1160) <B7B57FA5-1C74-149A-43D1-51DE9479B521>  /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/VDC.plugin/Cont ents/MacOS/VDC
              0x12db4e000 -        0x12db65fe7  libJapaneseConverter.dylib  49.0.0 (compatibility 1.0.0)  <5C25B45F-7A9E-3259-0532-E13B34B5398A>  /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
              0x12db69000 -        0x12db78fe7   libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0)  <50541300-118F-BE28-86DB-0F42738A9338>  /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
              0x12db7c000 -        0x12db8efff   libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0)  <CC30A563-5E4C-7ACE-3B73-90E8F582171A>  /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
              0x12db92000 -        0x12dbb3fef  libKoreanConverter.dylib 49.0.0  (compatibility 1.0.0) <1CC25A05-9E4C-ACBE-546E-34063A4CEB09>  /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
              0x12dfd1000 -        0x12dfe0ff7 +com.adobe.AfterEffects.Curves  ??? (???) <C75D1DDD-841D-427F-BD81-914294939D50>  /Applications/Adobe After Effects  CS5/Plug-ins/Effects/Curves.plugin/Contents/MacOS/Curves
              0x12dff9000 -        0x12e002fff +com.adobe.AfterEffects.Exposure  ??? (???) <ABCFB92B-BCEF-E03B-FE46-4D45679D2F5A>  /Applications/Adobe After Effects  CS5/Plug-ins/Effects/Exposure.plugin/Contents/MacOS/Exposure
              0x12e005000 -        0x12e00fff7 +com.adobe.AfterEffects.Glow ???  (???) <05AF0BF4-EE7E-CF3A-8399-65DBA65D4A5D> /Applications/Adobe  After Effects CS5/Plug-ins/Effects/Glow.plugin/Contents/MacOS/Glow
              0x12e043000 -        0x12e057ffb +com.adobe.AfterEffects.Smoother  ??? (???) <A59E60FC-9404-BC72-E08B-FD37A9FF887C>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/Smoother.plugin/Contents/MacOS/Smoother
              0x12e065000 -        0x12e07bff3 +com.adobe.AfterEffects.Wiggler  ??? (???) <FD0E7F65-6500-B0D9-CE8D-B3E43ACC4E73>  /Applications/Adobe After Effects  CS5/Plug-ins/Keyframe/Wiggler.plugin/Contents/MacOS/Wiggler
              0x12e0fc000 -        0x12e0fdff7  +com.adobe.AfterEffects.Strobe_Light ??? (???)  <1AA8BFB0-C183-68D5-6C5D-D7EDD2C93176> /Applications/Adobe After  Effects  CS5/Plug-ins/Effects/Strobe_Light.plugin/Contents/MacOS/Strobe_Light
              0x12e4c2000 -        0x12e4c7ff7  +com.adobe.AfterEffects.Transform ??? (???)  <19C41586-1A01-D301-EB21-DFC8D71B174D> /Applications/Adobe After  Effects CS5/Plug-ins/Effects/Transform.plugin/Contents/MacOS/Transform
              0x12e4f6000 -        0x12e4f9fff  +com.adobe.AfterEffects.DirectionalBlur ??? (???)  <6334C5FD-3922-2D86-D5A0-EF0B8770BA85> /Applications/Adobe After  Effects  CS5/Plug-ins/Effects/DirectionalBlur.plugin/Contents/MacOS/DirectionalBlur
              0x12f1a0000 -        0x12f29dfff  +com.adobe.AfterEffects.RefineMatte ??? (???)  <E75264FC-E965-9BE7-F268-DA8B88A0A2FA> /Applications/Adobe After  Effects CS5/Adobe After Effects  CS5.app/Contents/Required/RefineMatte.plugin/Contents/MacOS/RefineMatte
              0x134ed9000 -        0x134ee5fff  +com.cycoresystems.CCfx.MrMercury 1.0 (???)  <FDC7EE23-2DDB-239D-1919-7B54676CE29E> /Applications/Adobe After  Effects  CS5/Plug-ins/Effects/CycoreFX/MrMercury.plugin/Contents/MacOS/MrMercury
              0x134eea000 -        0x134eeeff7  +com.adobe.AfterEffects.RoughenEdges ??? (???)  <25E3B30B-6C72-5A08-D4FD-9624A001E250> /Applications/Adobe After  Effects  CS5/Plug-ins/Effects/RoughenEdges.plugin/Contents/MacOS/RoughenEdges
              0x135000000 -        0x135e9dff7 +com.BorisFX.bcc_ae_16bit 7 . 0 .  2, 16 bit (111) <52C4E80A-21FA-240F-EF8C-00445B98990E>  /Library/Application  Support/BorisFX/Lib/BCC7BitDepthSupport/BCC7_AE_16Bit_64.bundle/Contents/MacOS/BCC7_AE_16 Bit_64
              0x1368d8000 -        0x137761fef +com.BorisFX.bcc_ae_8bit 7 . 0 .  2, 8 bit (111) <A2E2AA43-2DF7-89C3-31CC-3BE5B212D277>  /Library/Application  Support/BorisFX/Lib/BCC7BitDepthSupport/BCC7_AE_8Bit_64.bundle/Contents/MacOS/BCC7_AE_8Bi t_64
              0x13819a000 -        0x1381a6fff  +com.adobe.AfterEffects.atg_extract ??? (???)  <1A512551-CA7C-FC14-CB74-F8D9C997CB2B> /Applications/Adobe After  Effects  CS5/Plug-ins/Effects/Inner-Outer-Key.plugin/Contents/MacOS/atg_extract
              0x13857a000 -        0x1385c5ff7  +com.adobe.AfterEffects.Scribble_Fill ??? (???)  <422D22AD-626A-ECD3-5EE1-950C10DD257A> /Applications/Adobe After  Effects  CS5/Plug-ins/Effects/Scribble.plugin/Contents/MacOS/Scribble_Fill
              0x16fafd000 -        0x16fb00fef  libLatinSuppConverter.dylib  49.0.0 (compatibility 1.0.0)  <227677D0-9CF3-E007-E4C0-8DCECDA1AE9B>  /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
              0x1827b9000 -        0x18281efff +com.adobe.MediaCore.ImporterMp3  1.0 (1.0) <71F80DA9-0E3B-5333-B0BF-5F333A260E0C>  /Applications/Adobe After Effects CS5/Adobe After Effects  CS5.app/Contents/Plug-ins/(MediaCore)/ImporterMP3.bundle/Contents/MacOS/ImporterMp3
              0x1b32b0000 -        0x1b32b7fff  com.apple.URLMount.AFPPlugin  3.2.1 (3.2.1) <4A425908-9801-14B3-DAB5-46165B89DF93>  /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp
              0x200000000 -        0x200787fef  com.apple.GeForceGLDriver  1.6.26 (6.2.6) <BAAEDD99-82FA-2C7F-CD66-E0977C670CC5>  /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
              0x283700000 -        0x28374afff  com.apple.AppleShareClientCore  2.0 (2.0) <C8193C5A-CDEE-39E5-1BEF-174D29678E6C>  /System/Library/Frameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore
           0x7fff5fc00000 -     0x7fff5fc3bdef  dyld 132.1 (???) <B536F2F1-9DF1-3B6C-1C2C-9075EA219A06> /usr/lib/dyld
           0x7fff80003000 -     0x7fff80004ff7  com.apple.TrustEvaluationAgent  1.1 (1) <306FD9EE-A301-41D5-EBDE-2FC52F28229C>  /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
           0x7fff80051000 -     0x7fff80082fff  libGLImage.dylib ??? (???)  <1A8E58CF-FA2F-14F7-A097-D34EEA8A7D03>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
           0x7fff80083000 -     0x7fff80091ff7  libkxld.dylib ??? (???)  <4016E9E6-0645-5384-A697-2775B5228113>  /usr/lib/system/libkxld.dylib
           0x7fff80092000 -     0x7fff800e1ff7   com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0)  <17EFD646-6F53-36E9-56BF-5A339E83EFFC>  /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
           0x7fff800e2000 -     0x7fff80153ff7  com.apple.AppleVAFramework  4.10.12 (4.10.12) <1B68BE43-4C54-87F5-0723-0B0A14CD21E8>  /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
           0x7fff80154000 -     0x7fff803befef  com.apple.QuartzComposer 4.2  ({156.28}) <7586E7BD-D3BD-0EAC-5AC9-0BFA3679017C>  /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
           0x7fff803bf000 -     0x7fff80402fef  libtidy.A.dylib ??? (???)  <2F4273D3-418B-668C-F488-7E659D3A8C23> /usr/lib/libtidy.A.dylib
           0x7fff80403000 -     0x7fff80493fff  com.apple.SearchKit 1.3.0  (1.3.0) <3403E658-A54E-A79A-12EB-E090E8743984>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
           0x7fff8057e000 -     0x7fff805bbff7  libFontRegistry.dylib ??? (???)  <8C69F685-3507-1B8F-51AD-6183D5E88979>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
           0x7fff8075b000 -     0x7fff807a5ff7  com.apple.Metadata 10.6.3  (507.15) <5170FCE0-ED6C-2E3E-AB28-1DDE3F628FC5>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
           0x7fff80821000 -     0x7fff80827fff  libCGXCoreImage.A.dylib 545.0.0  (compatibility 64.0.0) <4EE16374-A094-D542-5BC5-7E846D0CE56E>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
           0x7fff80828000 -     0x7fff80828ff7  com.apple.vecLib 3.6 (vecLib  3.6) <08D3D45D-908B-B86A-00BA-0F978D2702A7>  /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
           0x7fff80862000 -     0x7fff80979fef  libxml2.2.dylib 10.3.0  (compatibility 10.0.0) <7DC5239F-CD6A-820C-7C66-C528D7E27649>  /usr/lib/libxml2.2.dylib
           0x7fff8097a000 -     0x7fff80a2ffe7  com.apple.ink.framework 1.3.3  (107) <D76C7591-B060-E2DE-6634-968FDABD87EF>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
           0x7fff80a30000 -     0x7fff80a41ff7  libz.1.dylib 1.2.3  (compatibility 1.0.0) <FB5EE53A-0534-0FFA-B2ED-486609433717>  /usr/lib/libz.1.dylib
           0x7fff80a42000 -     0x7fff80ae2fff  com.apple.LaunchServices 362.2  (362.2) <A8EDC37C-1D40-5ED0-49BE-90EF110A6B3A>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
           0x7fff80b9a000 -     0x7fff80d5bfff  libSystem.B.dylib 125.2.1  (compatibility 1.0.0) <71E6D4C9-F945-6EC2-998C-D61AD590DAB6>  /usr/lib/libSystem.B.dylib
           0x7fff80dd9000 -     0x7fff80ddeff7  com.apple.CommonPanels 1.2.4  (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
           0x7fff80ddf000 -     0x7fff80e20fff  com.apple.SystemConfiguration  1.10.5 (1.10.2) <FB39F09C-57BB-D8CC-348D-93E00C602F7D>  /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
           0x7fff80e21000 -     0x7fff80edeff7   com.apple.CoreServices.OSServices 357 (357)  <718F0719-DC9F-E392-7C64-9D7DFE3D02E2>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
           0x7fff80edf000 -     0x7fff80eeefff  com.apple.NetFS 3.2.1 (3.2.1)  <3FC302C9-A5C6-A9CA-08CE-435AD05499F1>  /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
           0x7fff80eef000 -     0x7fff81175fff  com.apple.security 6.1.1  (37594) <1B4E1ABD-1BB3-DA49-F574-0EEB23E73C6A>  /System/Library/Frameworks/Security.framework/Versions/A/Security
           0x7fff81176000 -     0x7fff81241fe7  ColorSyncDeprecated.dylib 4.6.0  (compatibility 1.0.0) <3C223A94-EF14-28C5-844B-C25DFC87FB42>  /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
           0x7fff81242000 -     0x7fff812acfe7  libvMisc.dylib 268.0.1  (compatibility 1.0.0) <7D8B6D68-7E70-2AF2-BF9F-2CD56145909C>  /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
           0x7fff812ad000 -     0x7fff812b2fff  libGFXShared.dylib ??? (???)  <991F8197-FD06-2AF1-F99B-E448ED4FB2AC>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
           0x7fff812bb000 -     0x7fff812d0ff7  com.apple.LangAnalysis 1.6.6  (1.6.6) <DC999B32-BF41-94C8-0583-27D9AB463E8B>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
           0x7fff81332000 -     0x7fff81384ff7  com.apple.HIServices 1.8.2  (???) <7C91D07D-FA20-0882-632F-0CAE4FAC2B79>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
           0x7fff81385000 -     0x7fff813e7fe7  com.apple.datadetectorscore 2.0  (80.7) <5F0F865C-A80F-FE7F-7DF8-894A4A99EACA>  /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
           0x7fff813e8000 -     0x7fff81421fef  libcups.2.dylib 2.8.0  (compatibility 2.0.0) <561D0DCB-47AD-A12C-9066-70E4CBAD331C>  /usr/lib/libcups.2.dylib
           0x7fff814bb000 -     0x7fff81502fff  com.apple.QuickLookFramework  2.3 (327.6) <11DFB135-24A6-C0BC-5B97-ECE352A4B488>  /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
           0x7fff8155d000 -     0x7fff81642fef  com.apple.DesktopServices 1.5.9  (1.5.9) <27890B2C-0CD2-7C27-9D0C-D5952C5E8438>  /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
           0x7fff81643000 -     0x7fff817fafef  com.apple.ImageIO.framework  3.0.4 (3.0.4) <2CB9997A-A28D-80BC-5921-E7D50BBCACA7>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
           0x7fff817fb000 -     0x7fff81800fff  libGIF.dylib ??? (???)  <9A2723D8-61F9-6D65-D254-4F9273CDA54A>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
           0x7fff81801000 -     0x7fff81b9efe7  com.apple.QuartzCore 1.6.3  (227.34) <215222AF-B30A-7CE5-C46C-1A766C1D1D2E>  /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
           0x7fff81b9f000 -     0x7fff81bc5fe7  libJPEG.dylib ??? (???)  <6690F15D-E970-2678-430E-590A94F5C8E9>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
           0x7fff81bc6000 -     0x7fff81d3dfe7  com.apple.CoreFoundation 6.6.4  (550.42) <770C572A-CF70-168F-F43C-242B9114FCB5>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
           0x7fff81d8e000 -     0x7fff81fc9fef  com.apple.imageKit 2.0.3 (1.0)  <5D18C246-303A-6580-9DC9-79BE79467C95>  /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
           0x7fff81ffa000 -     0x7fff820b0fff  libobjc.A.dylib 227.0.0  (compatibility 1.0.0) <B1F5CDC0-96BD-C7C0-BEAA-1E2259DDE067>  /usr/lib/libobjc.A.dylib
           0x7fff820b1000 -     0x7fff8216afff  libsqlite3.dylib 9.6.0  (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150>  /usr/lib/libsqlite3.dylib
           0x7fff8216b000 -     0x7fff821b2ff7  com.apple.coreui 2 (114)  <BB09E685-1F5D-0676-1A0E-295610B387A8>  /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
           0x7fff821b3000 -     0x7fff821b9ff7  IOSurface ??? (???)  <04EDCEDE-E36F-15F8-DC67-E61E149D2C9A>  /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
           0x7fff821ba000 -     0x7fff821e5ff7  libxslt.1.dylib 3.24.0  (compatibility 3.0.0) <87A0B228-B24A-C426-C3FB-B40D7258DD49>  /usr/lib/libxslt.1.dylib
           0x7fff8221b000 -     0x7fff82287ff7  com.apple.CorePDF 1.3 (1.3)  <6770FFB0-DEA0-61E0-3520-4B95CCF5D1CF>  /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
           0x7fff82638000 -     0x7fff82687fef  libTIFF.dylib ??? (???)  <AE9DC484-1382-F7AD-FE25-C28082FCB5D9>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
           0x7fff8268d000 -     0x7fff82727fff   com.apple.ApplicationServices.ATS 4.4 (???)  <395849EE-244A-7323-6CBA-E71E3B722984>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
           0x7fff82728000 -     0x7fff82802ff7  com.apple.vImage 4.0 (4.0)  <354F34BF-B221-A3C9-2CA7-9BE5E14AD5AD>  /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
           0x7fff82826000 -     0x7fff82831ff7   com.apple.speech.recognition.framework 3.11.1 (3.11.1)  <60484D84-BA63-13DD-50E9-ABDA402C3C45>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
           0x7fff82857000 -     0x7fff82b8bfff   com.apple.CoreServices.CarbonCore 861.23 (861.23)  <08F360FA-1771-4F0B-F356-BEF68BB9D421>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
           0x7fff82b8c000 -     0x7fff82c41fe7  com.apple.ColorSync 4.6.3  (4.6.3) <AA93AD96-6974-9104-BF55-AF7A813C8A1B>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
           0x7fff82c42000 -     0x7fff82d6aff7  com.apple.MediaToolbox 0.484.20  (484.20) <628A7245-7ADE-AD47-3368-CF8EDCA6CC1C>  /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
           0x7fff82d83000 -     0x7fff82d83ff7  com.apple.ApplicationServices  38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
           0x7fff82ef6000 -     0x7fff82efcff7  com.apple.DiskArbitration 2.3  (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A>  /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
           0x7fff82efd000 -     0x7fff830e0fff  libType1Scaler.dylib ??? (???)  <3A1AFBA4-958E-DD07-297E-DF1FB2C96D7C>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
           0x7fff830e1000 -     0x7fff83136ff7   com.apple.framework.familycontrols 2.0.2 (2020)  <A3CFF697-B9DB-A7E5-3B39-9DA9B34F0595>  /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
           0x7fff83137000 -     0x7fff8317fff7  libvDSP.dylib 268.0.1  (compatibility 1.0.0) <170DE04F-89AB-E295-0880-D69CAFBD7979>  /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
           0x7fff83180000 -     0x7fff83183fff  com.apple.help 1.3.1 (41)  <E311A81E-9870-A430-1E16-AFF6C92CE6E5>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
           0x7fff83184000 -     0x7fff8319afe7   com.apple.MultitouchSupport.framework 207.10 (207.10)  <1828C264-A54A-7FDD-FE1B-49DDE3F50779>  /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
           0x7fff8319b000 -     0x7fff8321afe7  com.apple.audio.CoreAudio 3.2.6  (3.2.6) <1DD64A62-0DE4-223F-F781-B272FECF80F0>  /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
           0x7fff8321b000 -     0x7fff8365ffef  libLAPACK.dylib 219.0.0  (compatibility 1.0.0) <E14EC4C6-B055-A4AC-B971-42AB644E4A7C>  /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
           0x7fff83660000 -     0x7fff83699ff7  com.apple.MeshKit 1.1 (49.2)  <2860E92F-5B68-E8DD-0E8F-BF3DD6ACF330>  /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
           0x7fff838e4000 -     0x7fff838ffff7  com.apple.openscripting 1.3.1  (???) <5A6ECC32-04D0-9A62-635D-1DD03EC6E190>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
           0x7fff83918000 -     0x7fff83948fef  com.apple.shortcut 1.1 (1.1)  <A99C9D8E-290B-B1E4-FEA5-CC5F2FB9C18D>  /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
           0x7fff83949000 -     0x7fff83995fff  libauto.dylib ??? (???)  <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
           0x7fff83a8e000 -     0x7fff84298fe7  libBLAS.dylib 219.0.0  (compatibility 1.0.0) <EEE5CE62-9155-6559-2AEA-05CED0F5B0F1>  /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
           0x7fff842b2000 -     0x7fff842b2ff7  com.apple.Carbon 150 (152)  <19B37B7B-1594-AD0A-7F14-FA2F85AD7241>  /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
           0x7fff842b3000 -     0x7fff842b4fff  liblangid.dylib ??? (???)  <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
           0x7fff842b5000 -     0x7fff84538ff7  com.apple.Foundation 6.6.4  (751.42) <9A99D378-E97A-8C0F-3857-D0FAA30FCDD5>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
           0x7fff84539000 -     0x7fff84539ff7  com.apple.quartzframework 1.5  (1.5) <B182B579-BCCE-81BF-8DA2-9E0B7BDF8516>  /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
           0x7fff8453a000 -     0x7fff84644ff7  com.apple.MeshKitIO 1.1 (49.2)  <B9E2EB6C-66F6-CFAD-4530-DDA4355D7FBA>  /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
           0x7fff84645000 -     0x7fff84646ff7  com.apple.audio.units.AudioUnit  1.6.5 (1.6.5) <14F14B5E-9287-BC36-0C3F-6592E6696CD4>  /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
           0x7fff84647000 -     0x7fff847b6fe7  com.apple.QTKit 7.6.6 (1756)  <250AB242-816D-9F5D-94FB-18BF2AE9AAE7>  /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
           0x7fff847b7000 -     0x7fff847f8ff7  com.apple.CoreMedia 0.484.20  (484.20) <42F3B74A-F886-33A0-40EE-8399B12BD32A>  /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
           0x7fff847f9000 -     0x7fff84833fff  libssl.0.9.8.dylib 0.9.8  (compatibility 0.9.8) <C7153747-50E3-32DA-426F-CC4C505D1D6C>  /usr/lib/libssl.0.9.8.dylib
           0x7fff854a8000 -     0x7fff854aafff  com.apple.print.framework.Print  6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
           0x7fff854f2000 -     0x7fff85508fef  libbsm.0.dylib ??? (???)  <83676D2E-23CD-45CD-BE5C-35FCFFBBBDBB> /usr/lib/libbsm.0.dylib
           0x7fff85509000 -     0x7fff85509ff7  com.apple.Accelerate.vecLib 3.6  (vecLib 3.6) <DA9BFF01-40DF-EBD5-ABB7-787DAF2D77CF>  /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
           0x7fff8550a000 -     0x7fff85553ff7  com.apple.securityinterface  4.0.1 (40418) <E2DC796D-84EC-48F5-34A9-DF614573BE74>  /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
           0x7fff85570000 -     0x7fff855d8fff  com.apple.MeshKitRuntime 1.1  (49.2) <C57FDCEE-CED0-06A8-2890-A3F6BB851998>  /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
           0x7fff855d9000 -     0x7fff856fffff   com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5)  <B51023BB-A5C9-3C65-268B-6B86B901BB2C>  /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
           0x7fff85805000 -     0x7fff85926fe7  libcrypto.0.9.8.dylib 0.9.8  (compatibility 0.9.8) <48AEAFE1-21F4-B3C8-4199-35AD5E8D0613>  /usr/lib/libcrypto.0.9.8.dylib
           0x7fff8592d000 -     0x7fff8594dff7   com.apple.DirectoryService.Framework 3.6 (621.9)  <FF6567B5-56BD-F3EC-E59D-1EC583C3CF73>  /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
           0x7fff8594e000 -     0x7fff85c4cfe7  com.apple.HIToolbox 1.6.4 (???)  <263AD497-F4CC-9610-E7D3-B95CF6F02030>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
           0x7fff85c4d000 -     0x7fff85c66fff  com.apple.CFOpenDirectory 10.6  (10.6) <CCF79716-7CC6-2520-C6EB-A4F56AD0A207>  /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
           0x7fff85c67000 -     0x7fff85cf6fff  com.apple.PDFKit 2.5.1 (2.5.1)  <927B9F90-3EBE-768E-8B18-BE43B4B58190>  /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
           0x7fff85cf7000 -     0x7fff85e10fef  libGLProgrammability.dylib ???  (???) <4F2DC233-7DD2-1204-CAA5-3E6524F0AB75>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
           0x7fff85e11000 -     0x7fff85e2eff7  libPng.dylib ??? (???)  <14043CBC-329F-4009-299E-DEE411E16134>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
           0x7fff85e65000 -     0x7fff85e6cfff  com.apple.OpenDirectory 10.6  (10.6) <4200CFB0-DBA1-62B8-7C7C-91446D89551F>  /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
           0x7fff85e6d000 -     0x7fff85eb2fff  com.apple.CoreMediaIOServices  134.0 (1160) <033C41A6-EB9B-6B3B-781A-AF001A945C7A>  /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
           0x7fff85eb3000 -     0x7fff85eb6ff7  libCoreVMClient.dylib ??? (???)  <609598E6-195D-E5D4-3B92-AE8D9768829C>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
           0x7fff85edf000 -     0x7fff865dc06f  com.apple.CoreGraphics 1.545.0  (???) <356D59D6-1DD1-8BFF-F9B3-1CE51D2F1EC7>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
           0x7fff865dd000 -     0x7fff865ecfff  com.apple.opengl 1.6.12  (1.6.12) <DE3F0528-7759-CDFD-A2CF-C51D3C9C8B39>  /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
           0x7fff865ed000 -     0x7fff865f1ff7  libCGXType.A.dylib 545.0.0  (compatibility 64.0.0) <63F77AC8-84CB-0C2F-8D2B-190EE5CCDB45>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
           0x7fff865f2000 -     0x7fff869fcfff  com.apple.RawCamera.bundle  3.5.0 (551) <FC906EA7-3E89-CA01-6D48-E157EF1E83F0>  /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
           0x7fff869fd000 -     0x7fff86a1efff  libresolv.9.dylib 41.0.0  (compatibility 1.0.0) <6993F348-428F-C97E-7A84-7BD2EDC46A62>  /usr/lib/libresolv.9.dylib
           0x7fff86a1f000 -     0x7fff86a25ff7  com.apple.CommerceCore 1.0 (6)  <E8A1144C-5666-9840-4729-256FE69CDBDB>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
           0x7fff86a26000 -     0x7fff86a26ff7  com.apple.Accelerate 1.6  (Accelerate 1.6) <2BB7D669-4B40-6A52-ADBD-DA4DB3BC0B1B>  /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
           0x7fff86ba1000 -     0x7fff86c01fe7  com.apple.framework.IOKit 2.0  (???) <D107CB8A-5182-3AC4-35D0-07068A695C05>  /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
           0x7fff86c2a000 -     0x7fff86c2bfff  com.apple.MonitorPanelFramework  1.3.0 (1.3.0) <5062DACE-FCE7-8E41-F5F6-58821778629C>  /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
           0x7fff86d6a000 -     0x7fff86dadff7  libRIP.A.dylib 545.0.0  (compatibility 64.0.0) <7E30B5F6-99FD-C716-8670-5DD4B4BAED72>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
           0x7fff86dae000 -     0x7fff86dc4fff  com.apple.ImageCapture 6.0.1  (6.0.1) <09ABF2E9-D110-71A9-4A6F-8A61B683E936>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
           0x7fff86dc5000 -     0x7fff86e0efef  libGLU.dylib ??? (???)  <CCE779A9-2467-A5AA-A558-691E43A1105F>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
           0x7fff86e0f000 -     0x7fff86e20fff   com.apple.DSObjCWrappers.Framework 10.6 (134)  <3C08225D-517E-2822-6152-F6EB13A4ADF9>  /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
           0x7fff86e21000 -     0x7fff86fdffff  libicucore.A.dylib 40.0.0  (compatibility 1.0.0) <781E7B63-2AD0-E9BA-927C-4521DB616D02>  /usr/lib/libicucore.A.dylib
           0x7fff86fe0000 -     0x7fff87008fff  com.apple.DictionaryServices  1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
           0x7fff87009000 -     0x7fff87014ff7  com.apple.HelpData 2.0.4 (34)  <0DA6CA96-4E7D-7B22-7E37-218AF084C493>  /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
           0x7fff87015000 -     0x7fff870e7fe7  com.apple.CFNetwork 454.11.5  (454.11.5) <B3E2BE12-D7AA-5940-632A-1E5E7BF8E6E3>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
           0x7fff870e8000 -     0x7fff875ecfe7  com.apple.VideoToolbox 0.484.20  (484.20) <8B6B82D2-350B-E9D3-5433-51453CDA65B4>  /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
           0x7fff875ff000 -     0x7fff87613fff  libGL.dylib ??? (???)  <1EB1BD0F-C17F-55DF-B8B4-8E9CF99359D4>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
           0x7fff87614000 -     0x7fff87803fe7  com.apple.JavaScriptCore  6533.19 (6533.19.1) <233B3E34-CDC4-668A-529A-7E61D510D991>  /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
           0x7fff87804000 -     0x7fff87807ff7  com.apple.securityhi 4.0  (36638) <38935851-09E4-DDAB-DB1D-30ADC39F7ED0>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
           0x7fff87838000 -     0x7fff87874fe7  libcurl.4.dylib 6.1.0  (compatibility 6.0.0) <1E041185-131C-C237-C250-38BE933A269A>  /usr/lib/libcurl.4.dylib
           0x7fff8796e000 -     0x7fff879a0fff  libTrueTypeScaler.dylib ???  (???) <B9ECE1BD-A716-9F65-6466-4444D641F584>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
           0x7fff879a1000 -     0x7fff87a1efef  libstdc++.6.dylib 7.9.0  (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C>  /usr/lib/libstdc++.6.dylib
           0x7fff87a1f000 -     0x7fff87a2cfe7  libCSync.A.dylib 545.0.0  (compatibility 64.0.0) <397B9057-5CDF-3B19-4E61-9DFD49369375>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
           0x7fff87a2d000 -     0x7fff87ab9fef  SecurityFoundation ??? (???)  <6860DE26-0D42-D1E8-CD7C-5B42D78C1E1D>  /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
           0x7fff87aba000 -     0x7fff87addfff  com.apple.opencl 12.3 (12.3)  <D30A45FC-4520-45AF-3CA5-092313DB5D54>  /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
           0x7fff87ade000 -     0x7fff87b5cfff  com.apple.CoreText 3.5.0 (???)  <4D5C7932-293B-17FF-7309-B580BB1953EA>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
           0x7fff87b5d000 -     0x7fff87b8cff7  com.apple.quartzfilters 1.6.0  (1.6.0) <9CECB4FC-1CCF-B8A2-B935-5888B21CBEEF>  /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
           0x7fff8809a000 -     0x7fff8809aff7  com.apple.Cocoa 6.6 (???)  <68B0BE46-6E24-C96F-B341-054CF9E8F3B6>  /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
           0x7fff8809b000 -     0x7fff880d8fff  com.apple.LDAPFramework 2.0  (120.1) <1683330C-2908-9A45-AFF1-2282792C2570>  /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
           0x7fff880d9000 -     0x7fff88188fff  edu.mit.Kerberos 6.5.10  (6.5.10) <F3F76EDF-5660-78F0-FE6E-33B6174F55A4>  /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
           0x7fff88189000 -     0x7fff8819bfe7  libsasl2.2.dylib 3.15.0  (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97>  /usr/lib/libsasl2.2.dylib
           0x7fff8819c000 -     0x7fff88b92fff  com.apple.AppKit 6.6.7  (1038.35) <9F4DF818-9DB9-98DA-490C-EF29EA757A97>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
           0x7fff88b93000 -     0x7fff88c54fe7  libFontParser.dylib ??? (???)  <8B12D37E-3A95-5A73-509C-3AA991E0C546>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
           0x7fff88c55000 -     0x7fff88d93fff  com.apple.CoreData 102.1 (251)  <782F29CA-ACC7-4A77-5772-52FBE2CEFB5E>  /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
           0x7fff88e09000 -     0x7fff88e2eff7  com.apple.CoreVideo 1.6.2  (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288>  /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
           0x7fff88e2f000 -     0x7fff88e70fef  com.apple.QD 3.36 (???)  <5DC41E81-32C9-65B2-5528-B33E934D5BB4>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
           0x7fff88e71000 -     0x7fff88eb5fe7  com.apple.ImageCaptureCore  1.0.3 (1.0.3) <913FFA89-0AC8-0A8D-CC2A-364CB0F303BA>  /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
           0x7fff88eb6000 -     0x7fff88eb6ff7  com.apple.CoreServices 44 (44)  <DC7400FB-851E-7B8A-5BF6-6F50094302FB>  /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
           0x7fff88edc000 -     0x7fff88f61ff7   com.apple.print.framework.PrintCore 6.3 (312.7)  <CDFE82DD-D811-A091-179F-6E76069B432D>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
           0x7fff88f6b000 -     0x7fff88fa6fff  com.apple.AE 496.4 (496.4)  <64C27EC8-FC7F-EA6B-9435-9A3452425915>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
           0x7fff88fa7000 -     0x7fff89029fff  com.apple.QuickLookUIFramework  2.3 (327.6) <9093682A-0E2D-7D27-5F22-C96FD00AE970>  /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
           0x7fff8902a000 -     0x7fff8902eff7  libmathCommon.A.dylib 315.0.0  (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5>  /usr/lib/system/libmathCommon.A.dylib
           0x7fff8902f000 -     0x7fff89038ff7  com.apple.DisplayServicesFW  2.3.0 (283) <3D05929C-AB17-B8A4-DC81-87C27C59E664>  /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
           0x7fff8913a000 -     0x7fff8913cfff  libRadiance.dylib ??? (???)  <76438F90-DD4B-9941-9367-F2DFDF927876>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
           0x7fff8913d000 -     0x7fff89151ff7   com.apple.speech.synthesis.framework 3.10.35 (3.10.35)  <63C87CF7-56B3-4038-8136-8C26E96AD42F>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
           0x7fffffe00000 -     0x7fffffe01fff  libSystem.B.dylib ??? (???)  <71E6D4C9-F945-6EC2-998C-D61AD590DAB6> /usr/lib/libSystem.B.dylib
      RAM: 8192MB
      Machine: i386
      Model: MacBookPro6,1
      CPU * Core count: 4
      CPU Frequency: 2660MHz
      Bus Frequency: 4800MHz
      Open GL Renderer: NVIDIA GeForce GT 330M OpenGL Engine
      Open GL Version: 2.1 NVIDIA-1.6.26
      Open GL Vendor: NVIDIA Corporation
      Open GL Extensions: L_ARB_transpose_matrix, GL_ARB_vertex_program,  GL_ARB_vertex_blend, GL_ARB_window_pos, GL_ARB_shader_objects,  GL_ARB_vertex_shader, GL_ARB_shading_language_100,  GL_EXT_multi_draw_arrays, GL_EXT_clip_volume_hint,  GL_EXT_rescale_normal, GL_EXT_draw_range_elements, GL_EXT_fog_coord,  GL_EXT_gpu_program_parameters, GL_EXT_geometry_shader4,  GL_EXT_transform_feedback, GL_APPLE_client_storage,  GL_APPLE_specular_vector, GL_APPLE_transform_hint,  GL_APPLE_packed_pixels, GL_APPLE_fence, GL_APPLE_vertex_array_object,  GL_APPLE_vertex_program_evaluators, GL_APPLE_element_array,  GL_APPLE_flush_render, GL_APPLE_aux_depth_stencil,  GL_NV_texgen_reflection, GL_NV_light_max_exponent,  GL_IBM_rasterpos_clip, GL_SGIS_generate_mipmap, GL_ARB_imaging,  GL_ARB_point_parameters, GL_ARB_texture_env_crossbar,  GL_ARB_texture_border_clamp, GL_ARB_multitexture,  GL_ARB_texture_env_add, GL_ARB_texture_cube_map,  GL_ARB_texture_env_dot3, GL_ARB_multisample, GL_ARB_texture_env_combine,  GL_ARB_texture_compression, GL_ARB_texture_mirrored_repeat,  GL_ARB_shadow, GL_ARB_depth_texture, GL_ARB_fragment_program,  GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,  GL_ARB_occlusion_query, GL_ARB_point_sprite,  GL_ARB_texture_non_power_of_two, GL_ARB_vertex_buffer_object,  GL_ARB_pixel_buffer_object, GL_ARB_draw_buffers,  GL_ARB_shader_texture_lod, GL_ARB_color_buffer_float,  GL_ARB_half_float_vertex, GL_ARB_texture_rg,  GL_ARB_texture_compression_rgtc, GL_ARB_framebuffer_object,  GL_EXT_compiled_vertex_array, GL_EXT_draw_buffers2,  GL_EXT_framebuffer_object, GL_EXT_framebuffer_blit,  GL_EXT_framebuffer_multisample, GL_EXT_texture_rectangle,  GL_ARB_texture_rectangle, GL_EXT_texture_env_add, GL_EXT_blend_color,  GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_lod_bias,  GL_EXT_abgr, GL_EXT_bgra, GL_EXT_stencil_wrap,  GL_EXT_texture_filter_anisotropic, GL_EXT_secondary_color,  GL_EXT_blend_func_separate, GL_EXT_shadow_funcs,  GL_EXT_stencil_two_side, GL_EXT_depth_bounds_test,  GL_EXT_texture_compression_s3tc, GL_EXT_texture_compression_dxt1,  GL_EXT_texture_sRGB, GL_EXT_blend_equation_separate,  GL_EXT_texture_mirror_clamp, GL_EXT_packed_depth_stencil,  GL_EXT_bindable_uniform, GL_EXT_texture_integer, GL_EXT_gpu_shader4,  GL_EXT_framebuffer_sRGB, GL_EXT_provoking_vertex,  GL_APPLE_flush_buffer_range, GL_APPLE_ycbcr_422, GL_APPLE_rgb_422,  GL_APPLE_vertex_array_range, GL_APPLE_texture_range,  GL_APPLE_float_pixels, GL_ATI_texture_float, GL_ARB_texture_float,  GL_ARB_half_float_pixel, GL_APPLE_pixel_buffer,  GL_APPLE_object_purgeable, GL_NV_point_sprite, GL_NV_blend_square,  GL_NV_fog_distance, GL_NV_depth_clamp, GL_NV_multisample_filter_hint,  GL_NV_fragment_program_option, GL_NV_fragment_program2,  GL_NV_vertex_program2_option, GL_NV_vertex_program3,  GL_NV_conditional_render, GL_ATI_texture_mirror_once,  GL_ATI_texture_env_combine3, GL_ATI_separate_stencil,  GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_EXT_texture_array,  GL_EXT_vertex_array_bgra, GL_ARB_instanced_arrays,  GL_ARB_depth_buffer_float, GL_EXT_packed_float,  GL_EXT_texture_shared_exponent
      User GUID: 08EF2AE7-B010-4086-9905-62E31073C046
      Crash GUID: 9C7B4F3A-2AF8-436F-BAFF-E0D164F64E84
