4 Replies Latest reply on Mar 8, 2011 5:29 AM by Hodmi
    Looping through records in XML Variable !!
    Abhinav Sharma Level 2
      I am getting no way how to do this. I am getting the below XML from a custom DSC component. Now I need to process it.
      <root>
          <records total_records="4">
              <record>
                  <jobno>1122</jobno>
                  <cust_name>Abhinav</cust_name>
                  <email>abhinavs@plabs.com</email>
                  <stat>1</stat>
              </record>
              <record>
                  <jobno>2233</jobno>
                  <cust_name>Doctor Dhober</cust_name>
                  <stat>0</stat>
              </record>
              <record>
                  <jobno>4666</jobno>
                  <cust_name>Vinau Dubey</cust_name>
                  <stat>1</stat>
              </record>
              <record>
                  <jobno>7677</jobno>
                  <cust_name>Nelesh Poda</cust_name>
                  <stat>0</stat>
              </record>
          </records>
      </root>
      Now I need to loop through every record & do some stuff for each one. In my process I have to send a mail to each of the user in the XML file. I tried it using SET VALUE's Node Set Functions, but not successful. Any help.
      Thanks.
      Abhinav
        • 1. Re: Looping through records in XML Variable !!
          I tried in set value opr:
          /process_data/@strEmail
          Expression: myXML is XML var in process
          /process_data/myXML/records/record[1]/@email
          Result expected
          strEmail = 'abhinavs@plabs.com'
          But didn't getting it. Pls help.
          Thanks.
          Abhinav
          • 2. Re: Looping through records in XML Variable !!
            MarcelBoucher Adobe Employee
            In your xml document, email is a node - not an attribute.
            The xPath expression should be:
            /process_data/myXML/records/record[1]/email
            The location uses the @strEmail notation because as an LC process variable, it's a simple value (String) and treated as an attribute of the process.
            • 3. Re: Looping through records in XML Variable !!
              Thanks Marcel for your response. I tried the way you told, but still I am not getting the node value from xml.
              Expression: /process_data/myXML/records/record[1]/email
              strEmail is still null/blank. I checked myXML variable, it holds the proper XML as above.
              I am stucked in it, help!!.
              Abhinav
              • 4. Re: Looping through records in XML Variable !!
                Hodmi Level 4
                Your xpath doesn't match your XML - you are missing the root node in your xpath expression:
                should be:
                           /process_data/myXML/root/records/record[1]/email
                When you build your loop there is one other thing to be careful of.  If you evaluate an xpath variable inside of another xpath expression, it gets inserted as a string.  This happens even if the variable is an integer.  For example:  If I have an integer variable counter which is set to 3 and evaluate:
                     /process_data/myXML/root/records/record[/process_data/@counter]/email    The xpath expression will insert "3" (a string) and not an integer as you would expect.  The result will not be the third node. This can be a source of frustration and its hard to debug.
                Instead, use the number function inside the expression:
                  /process_data/myXML/root/records/record[number(/process_data/@counter)]/email
                I've attached a sample process that shows this.
