• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How To Display WebHelp In A Smaller Browser Window
New Here ,
Mar 07, 2011 Mar 07, 2011
I'm using RoboHelp 8 to develop a WebHelp for a Web-based application. When the help is launched from the application, it covers the entire screen.
How can I make it so the WebHelp only displays in a smaller browser window so it does not cover the entire screen?
Thanks in advance for your help 🙂
Views
612
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
I think that's controlled by the launching program - what method are you using to launch the help?
Votes
Translate
Translate
Report
Report
New Here ,
Mar 08, 2011 Mar 08, 2011
The Help is being called from a link on an ASP page. Do you know how to manage windows size for the help?
Thanks!
Votes
Translate
Translate
Report
Report
Guest
Mar 09, 2011 Mar 09, 2011
LATEST
An ASP page is essentially HTML, so you should be able to use JavaScript to do this.
You have 3 options for inserting the JavaScript in your page:
  1. Inline - insert the code directly where you need it. This is fine if you only have 1 or 2 links that will use it.
  2. In a "script" element. This is useful if you want to reuse the code multiple times on the page.
  3. External file - define the function in an internal file and import it into your page. This is useful when you want to reuse the JavaScript code on multiple pages...and you can change settings in one spot and have them applied everywhere (e.g. if you decide you want to adjust the dimensions).
Examples of each:
Example 1: Inline
Here's an example of an line usage on an <a> link. Replace "project_folder/file_to_launch.htm" with your own URL (either absolute: http://www... or relative: ../my_folder/my_project_launch_file.htm).
<a href="javascript:void('0')" onclick="window.open('project_folder/file_to_launch.htm','','height=500, width=800, left=100, top=100, toolbar=no, menubar=no, resizable=yes, scrollbars=yes')">My Project</a>
Example 2: In a <script> Element
I put this in the <head> of my page:
<script language="javascript">
function openWindow(filename){
  var filename = filename;
  myWindow=window.open(filename,"","height=500, width=800, left=100, top=100, toolbar=no, menubar=no, resizable=yes, scrollbars=yes");
</script>
Example 3: External File
The following line in the <head> of the page imports the script defined in the "../resources/launchWebhelp.js" file (obviously, your path and filename will differ).
<script language="javascript" src="../resources/launchWebhelp.js"></script>
The definition in the external file is the same as example 2, but without the <script> tags.
In both examples 2 and 3, I would call the openWindow( ) function the same way:
<a href="javascript:void('0')" onclick="openWindow('project_folder/file_to_launch.htm')">My Project</a>
I use this technique for a couple of reasons:
  • Launching the help in a separate window does not "hijack" the user's original session.
  • Opening it in a smaller window informs the user that a new window has been opened because it doesn't hide their original window (unless their original window is even smaller, which is unlikely).
  • It allows me to control the appearance of the new window (you can hide the toolbar and menu bar, for example).
I fully expect the user to resize or maximize the new window...my content is not optimized to appear within the confines of the smaller window.
This technique is using the open( ) method associated with the "window" object of the browser.  Here's a link with some information about this method:
http://www.w3schools.com/jsref/met_win_open.asp
I hope this helps you out.
Dave
Votes
Translate
Translate
Report
Report
Guest
I use a JavaScript function to accomplish something similar:
function launchWebhelp(filename){
The above opens a new browser window with the dimensions 500x800 and allows the user to resize it.
In my link, I call it like this:
<a href="javascript:void('0')"onclick="launchWebhelp('http://www.serverName.com/webhelp/project_name.htm')">Project Name</a>
with the URL pointing at the file used to launch the webhelp.  This exact approach may not work for your application (depending on how the help is launched), but hopefully it gives you (or your developer) an idea.
Dave
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
