1 Reply Latest reply on Mar 8, 2011 8:35 AM by Chris W. Griffith
    Autoplay timing with play and pause
    Dishkauu
      Is there a way in Flash Catalyst CS5 where the slideshow can auto play images besides user having control of next and previous? It's more like having the Auto image rotator functionality. Please help!
      Rohit
        • 1. Re: Autoplay timing with play and pause
          Chris W. Griffith Adobe Community Professional
          Without knowing the design of your project, it is hard say which solution might be the best fit. You might want to look at the On Application Start interaction if your slideshow can be triggered as the project is first running. Another solution might be to trigger an Action Sequence. This might work if there is a starting event, and you do not need it to loop.
          There are some solutions that use other parts of the Flash Platform. You could build the slideshow in Flash Professional and bring the swf into Flash Catalyst. Or you could use Flash Builder to add some ActionScript to programmatically do your slideshow.
          I know this doesn't give you a direct solution, but hopefully some initial pointers for you to explore.
          Chris
