9 Replies Latest reply on Mar 19, 2011 4:26 PM by panorama333333333
    pre vers 7 now crashes at splash screen... when it says Loading CompilerVfw.prm
    panorama333333333
      when it says "Loading CompilerVfw.prm"
      Here is the error log:
      Log Name:      Application
      Source:        Application Error
      Date:          3/7/2011 10:10:33 AM
      Event ID:      1000
      Task Category: (100)
      Level:         Error
      Keywords:      Classic
      User:          N/A
      Computer:      SStudio
      Description:
      Faulting application name: Adobe Premiere Elements.exe, version: 7.0.1.0, time stamp: 0x494ac29e
      Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
      Exception code: 0xc0000005
      Fault offset: 0x06351d20
      Faulting process id: 0x133c
      Faulting application start time: 0x01cbdcf2f13aa7cc
      Faulting application path: C:\Program Files (x86)\Adobe\Adobe Premiere Elements 7.0\Adobe Premiere Elements.exe
      Faulting module path: unknown
      Report Id: 312023aa-48e6-11e0-b6cc-0021705e7b98
      Event Xml:
      <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
        <System>
          <Provider Name="Application Error" />
          <EventID Qualifiers="0">1000</EventID>
          <Level>2</Level>
          <Task>100</Task>
          <Keywords>0x80000000000000</Keywords>
          <TimeCreated SystemTime="2011-03-07T18:10:33.000000000Z" />
          <EventRecordID>42358</EventRecordID>
          <Channel>Application</Channel>
          <Computer>SStudio</Computer>
          <Security />
        </System>
        <EventData>
          <Data>Adobe Premiere Elements.exe</Data>
          <Data>7.0.1.0</Data>
          <Data>494ac29e</Data>
          <Data>unknown</Data>
          <Data>0.0.0.0</Data>
          <Data>00000000</Data>
          <Data>c0000005</Data>
          <Data>06351d20</Data>
          <Data>133c</Data>
          <Data>01cbdcf2f13aa7cc</Data>
          <Data>C:\Program Files (x86)\Adobe\Adobe Premiere Elements 7.0\Adobe Premiere Elements.exe</Data>
          <Data>312023aa-48e6-11e0-b6cc-0021705e7b98</Data>
        </EventData>
      </Event>
      For the past 3 days I have tried everything?... Updates, drivers, patch, re-install, move previous associated folders... Any suggestions?  Corrupt codec?
      Also when I use G-Spot it says:
      Warning: DirectShow crashed while GSpot was attempting to obtain information about a codec.
      This is usually due to damaged, misconfigured, conflicting, or poorly written codec drivers.  It is possible, perhaps even likely, that other media players will crash when they attempt to play this file as well, as most of them will also use DirectShow.  GSpot was able to intercept the crash, and has attempted to identify the codec or filter involved; uninstalling or reinstalling this codec or filter may solve the problem.
      The codec was tentatively identified as:
      Unknown video codec #10
      Thank you.
      I noticed one of my other video editors is non-functional now too.
        • 1. Re: pre vers 7 now crashes at splash screen... when it says Loading CompilerVfw.prm
          What operating system are you using? Have you manually gone to Windows Update and ensured you have even the non-critical updates? Have you gone to Apple.com and ensured you have the latest version of Quicktime?
          How fast is your processor? How much RAM do you have and how much free, clean, freshly defragmented space is on your C drive?
          • 2. Re: pre vers 7 now crashes at splash screen... when it says Loading CompilerVfw.prm
            panorama333333333 Level 1
            I got the updates for windows & quicktime.  Here's my info:
            Windows 7 Home Premium SP1
            Intel Core 2 Quad Q8300 2.50GHz
            8 GB RAM
            64-bit OS
            C: free space 500 GB
            3 other HDs
            Hey Steve I have uninstalled & re-installed a few times... same thing happens...
            maybe...
            do I have to remove "Adobe Photoshop Elements".
            I have discs for both programs... maybe the 2 are connected?  I read in the manual: When uninstalling, remove all subsets of "the program" as well.
            ps.............. Sony Vegas crashes at the "splash screen" now too.  It was fine before.
            • 3. Re: pre vers 7 now crashes at splash screen... when it says Loading CompilerVfw.prm
              It might be worth contacting Adobe Tech Support about this.
              Assuming your drives are clean of tmp files and freshly defragmented, you certainly should have no problems.
              One last ditch thing to try in the meantime. In Photo Elements or the Organizer (or any Adobe product, even Reader) go to the Help menu and select Check for Updates. This will update every Adobe product on your system.
              Also, you don't say what graphics card you have, but go to the ATI or nVidia site and get the latest firmware for it from there. You'd be surprised how much difference even a slightly outdated graphics driver can make!
              • 4. Re: pre vers 7 now crashes at splash screen... when it says Loading CompilerVfw.prm
                the_wine_snob Level 9
                It sounds like you have FFDShow installed on your computer. Did you install anything like the K-Lite CODEC pack?
                FFDShow has been known to severely affect many Adobe programs, and especially the NLE programs. I recommend staying very far away from that.
                • 5. Re: pre vers 7 now crashes at splash screen... when it says Loading CompilerVfw.prm
                  I haven't installed any codec packs.
                  When I use G Spot the BLACK SCREEN CRASH BOX comes up and states:
                  How to I figure out what video codec #10 is?
                  ps... both of you... Thank You so much for your help.  I still need more .
                  • 6. Re: pre vers 7 now crashes at splash screen... when it says Loading CompilerVfw.prm
                    How do I know if I have FFDShow installed?
                    and...
                    If I do in fact have that beastie in there...
                    I have seen "FFDShow decoder" & fixes all over the web... Should I try using that?  Not good?
                    DivX and xVid ... culprits?
                    • 7. Re: pre vers 7 now crashes at splash screen... when it says Loading CompilerVfw.prm
                      Normally, if things are working OK with FFDShow, when you play an AV file in say Windows Media Player, you will see a little FFDShow icon in the taskbar.
                      You should also be able to track FFDShow in Task Manager Processes. Open an AV file in WMP and then open Task Manager, and check for FFDShow.
                      • 8. Re: pre vers 7 now crashes at splash screen... when it says Loading CompilerVfw.prm
                        It's a problem with the Direct Show "Qcap.dll" file.
                        How do I fix this?
                        Oh, and since the last post, I have spent hours & hours doing every possible fix & my eyes are burnt from over-reading...
                        ouch.
                        help?
                        • 9. Re: pre vers 7 now crashes at splash screen... when it says Loading CompilerVfw.prm
                          Below is the properties info:
                          And below is the "Direct Show" dxDiag error log:
                          How do I fix this?
                          ouch.
                          help?
                          System Information
                          Time of this report: 3/17/2011, 12:30:40
                                 Machine name: SSTUDIO
                             Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_rtm.101119-1850)
                                     Language: English (Regional Setting: English)
                          System Manufacturer: Dell Inc.
                                 System Model: Studio 540
                                         BIOS: BIOS Date: 08/25/09 12:43:46 Ver: 0.0.1
                                    Processor: Intel(R) Core(TM)2 Quad CPU    Q8300  @ 2.50GHz (4 CPUs), ~2.5GHz
                                       Memory: 8192MB RAM
                          Available OS Memory: 8192MB RAM
                                    Page File: 2011MB used, 14369MB available
                                  Windows Dir: C:\Windows
                              DirectX Version: DirectX 11
                          DX Setup Parameters: Not found
                             User DPI Setting: 134 DPI (139 percent)
                          System DPI Setting: 96 DPI (100 percent)
                              DWM DPI Scaling: Disabled
                               DxDiag Version: 6.01.7601.17514 64bit Unicode
                          DxDiag Notes
                                Display Tab 1: No problems found.
                                  Sound Tab 1: No problems found.
                                    Input Tab: No problems found.
                          DirectX Debug Levels
                          Direct3D:    0/4 (retail)
                          DirectDraw:  0/4 (retail)
                          DirectInput: 0/5 (retail)
                          DirectMusic: 0/5 (retail)
                          DirectPlay:  0/9 (retail)
                          DirectSound: 0/5 (retail)
                          DirectShow:  0/6 (retail)
                          Display Devices
                                    Card name: NVIDIA GeForce GTS 240
                                 Manufacturer: NVIDIA
                                    Chip type: GeForce GTS 240
                                     DAC type: Integrated RAMDAC
                                   Device Key: Enum\PCI\VEN_10DE&DEV_0607&SUBSYS_073610DE&REV_A2
                               Display Memory: 494 MB
                             Dedicated Memory: 1007 MB
                                Shared Memory: 3582 MB
                                 Current Mode: 1920 x 1080 (32 bit) (60Hz)
                                 Monitor Name: Dell_ST2310_Analog
                                Monitor Model: DELL ST2310
                                   Monitor Id: DELF01B
                                  Native Mode: 1920 x 1080(p) (60.000Hz)
                                  Output Type: HD15
                                  Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
                          Driver File Version: 8.15.0011.8627 (English)
                               Driver Version: 8.15.11.8627
                                  DDI Version: 10
                                 Driver Model: WDDM 1.1
                            Driver Attributes: Final Retail
                             Driver Date/Size: 6/26/2009 15:01:00, 9476608 bytes
                                  WHQL Logo'd: Yes
                              WHQL Date Stamp:
                            Device Identifier: {D7B71E3E-4547-11CF-DD52-3D2702C2C535}
                                    Vendor ID: 0x10DE
                                    Device ID: 0x0607
                                    SubSys ID: 0x073610DE
                                  Revision ID: 0x00A2
                          Driver Strong Name: oem23.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section013:8.15.11.8627:pci\ven_10de&dev_0607&s ubsys_073610de
                               Rank Of Driver: 00E60001
                                  Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
                             Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                               {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                               {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                               {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                               {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                               {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                               {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                               {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                               {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                 D3D9 Overlay: Supported
                                      DXVA-HD: Supported
                                 DDraw Status: Enabled
                                   D3D Status: Enabled
                                   AGP Status: Enabled
                          Sound Devices
                                      Description: Speakers (Sound Blaster X-Fi Xtreme Audio)
                          Default Sound Playback: Yes
                          Default Voice Playback: Yes
                                      Hardware ID: HDAUDIO\FUNC_01&VEN_1102&DEV_000A&SUBSYS_11021007&REV_1000
                                  Manufacturer ID: 1
                                       Product ID: 100
                                             Type: WDM
                                      Driver Name: t3.sys
                                   Driver Version: 6.10.0000.0209 (English)
                                      WHQL Logo'd: Yes
                                    Date and Size: 7/26/2009 23:50:06, 639512 bytes
                                      Other Files:
                                  Driver Provider: CREATIVE
                                   HW Accel Level: Basic
                                        Cap Flags: 0xF1F
                              Min/Max Sample Rate: 100, 200000
                          Static/Strm HW Mix Bufs: 1, 0
                          Static/Strm HW 3D Bufs: 0, 0
                                        HW Memory: 0
                                 Voice Management: No
                          EAX(tm) 2.0 Listen/Src: No, No
                             I3DL2(tm) Listen/Src: No, No
                          Sensaura(tm) ZoomFX(tm): No
                          Sound Capture Devices
                          DirectInput Devices
                                Device Name: Mouse
                                   Attached: 1
                              Controller ID: n/a
                          Vendor/Product ID: n/a
                                  FF Driver: n/a
                                Device Name: Keyboard
                                   Attached: 1
                              Controller ID: n/a
                                  FF Driver: n/a
                                Device Name: Saitek Eclipse II Keyboard
                                   Attached: 1
                              Controller ID: 0x0
                          Vendor/Product ID: 0x06A3, 0x8021
                                  FF Driver: n/a
                                   Attached: 1
                              Controller ID: 0x0
                                  FF Driver: n/a
                                   Attached: 1
                              Controller ID: 0x0
                                  FF Driver: n/a
                                   Attached: 1
                              Controller ID: 0x0
                                  FF Driver: n/a
                                Device Name: External HDD
                                   Attached: 1
                              Controller ID: 0x0
                          Vendor/Product ID: 0x1058, 0x0404
                                  FF Driver: n/a
                          Poll w/ Interrupt: No
                          USB Devices
                          + USB Root Hub
                          | Vendor/Product ID: 0x8086, 0x3A36
                          | Matching Device ID: usb\root_hub
                          | Service: usbhub
                          | Driver: usbhub.sys, 11/20/2010 03:44:30, 343040 bytes
                          | Driver: usbd.sys, 7/13/2009 17:06:23, 7936 bytes
                          Gameport Devices
                          PS/2 Devices
                          + HID Keyboard Device
                          | Matching Device ID: hid_device_system_keyboard
                          | Service: kbdhid
                          | Driver: kbdhid.sys, 11/20/2010 03:33:25, 33280 bytes
                          | Driver: kbdclass.sys, 7/13/2009 18:48:04, 50768 bytes
                          + Terminal Server Keyboard Driver
                          | Matching Device ID: root\rdp_kbd
                          | Upper Filters: kbdclass
                          | Service: TermDD
                          | Driver: i8042prt.sys, 7/13/2009 16:19:57, 105472 bytes
                          + HID-compliant mouse
                          | Vendor/Product ID: 0x046D, 0xC044
                          | Matching Device ID: hid_device_system_mouse
                          | Service: mouhid
                          | Driver: mouhid.sys, 7/13/2009 17:00:20, 31232 bytes
                          | Driver: mouclass.sys, 7/13/2009 18:48:27, 49216 bytes
                          + Terminal Server Mouse Driver
                          | Matching Device ID: root\rdp_mou
                          | Upper Filters: mouclass
                          | Service: TermDD
                          | Driver: termdd.sys, 11/20/2010 06:33:57, 63360 bytes
                          | Driver: sermouse.sys, 7/13/2009 17:00:20, 26624 bytes
                          Disk & DVD/CD-ROM Drives
                                Drive: C:
                          Free Space: 482.6 GB
                          Total Space: 703.5 GB
                          File System: NTFS
                                Model: ST3750528AS ATA Device
                                Drive: G:
                          Free Space: 156.6 GB
                          Total Space: 238.5 GB
                          File System: NTFS
                                Model: n/a
                                Drive: K:
                          Free Space: 651.5 GB
                          Total Space: 953.6 GB
                          File System: FAT32
                                Model: BUFFALO External HDD USB Device
                                Drive: L:
                          Free Space: 62.2 GB
                          Total Space: 152.6 GB
                          File System: NTFS
                                Model: WD 1600BB External USB Device
                                Drive: N:
                          Free Space: 318.3 GB
                          Total Space: 476.9 GB
                          File System: NTFS
                                Model: WD My Passport 0730 USB Device
                                Drive: D:
                                Model: CD-ROM Drive
                               Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/20/2010 02:19:21, 147456 bytes
                                Drive: E:
                                Model: Optiarc DVD+-RW AD-7230S ATA Device
                          System Devices
                               Name: Intel(R) ICH10 Family PCI Express Root Port 3 - 3A44
                          Device ID: PCI\VEN_8086&DEV_3A44&SUBSYS_02AC1028&REV_00\3&11583659&0&E2
                             Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/20/2010 06:33:48, 184704 bytes
                               Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A36
                          Device ID: PCI\VEN_8086&DEV_3A36&SUBSYS_02AC1028&REV_00\3&11583659&0&EA
                             Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7600.16385 (English), 7/13/2009 17:06:27, 30720 bytes
                             Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/13/2009 17:06:31, 324608 bytes
                             Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17514 (English), 11/20/2010 03:44:30, 343040 bytes
                               Name: Intel(R) 4 Series Chipset Processor to I/O Controller - 2E20
                          Device ID: PCI\VEN_8086&DEV_2E20&SUBSYS_02AC1028&REV_03\3&11583659&0&00
                             Driver: n/a
                               Name: Intel(R) ICH10 Family PCI Express Root Port 2 - 3A42
                          Device ID: PCI\VEN_8086&DEV_3A42&SUBSYS_02AC1028&REV_00\3&11583659&0&E1
                               Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A35
                          Device ID: PCI\VEN_8086&DEV_3A35&SUBSYS_02AC1028&REV_00\3&11583659&0&E9
                               Name: Intel(R) 82801 PCI Bridge - 244E
                          Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_02AC1028&REV_90\3&11583659&0&F0
                               Name: Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40
                          Device ID: PCI\VEN_8086&DEV_3A40&SUBSYS_02AC1028&REV_00\3&11583659&0&E0
                               Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A34
                          Device ID: PCI\VEN_8086&DEV_3A34&SUBSYS_02AC1028&REV_00\3&11583659&0&E8
                               Name: 1394 OHCI Compliant Host Controller
                          Device ID: PCI\VEN_197B&DEV_2380&SUBSYS_AC022810&REV_00\4&2B518A3E&0&00E2
                             Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7601.17514 (English), 11/20/2010 03:44:56, 229888 bytes
                               Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C
                          Device ID: PCI\VEN_8086&DEV_3A3C&SUBSYS_02AC1028&REV_00\3&11583659&0&D7
                             Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/13/2009 17:06:30, 51200 bytes
                               Name: Intel(R) ICH10 Family SMBus Controller - 3A30
                          Device ID: PCI\VEN_8086&DEV_3A30&SUBSYS_02AC1028&REV_00\3&11583659&0&FB
                             Driver: n/a
                               Name: PCI standard PCI Express to PCI/PCI-X Bridge
                          Device ID: PCI\VEN_1102&DEV_7006&SUBSYS_00101102&REV_00\4&1BBA29DE&0&00E1
                               Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A
                          Device ID: PCI\VEN_8086&DEV_3A3A&SUBSYS_02AC1028&REV_00\3&11583659&0&EF
                               Name: Standard Dual Channel PCI IDE Controller
                          Device ID: PCI\VEN_8086&DEV_3A26&SUBSYS_02AC1028&REV_00\3&11583659&0&FD
                             Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/13/2009 18:45:45, 12352 bytes
                             Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 18:45:46, 48720 bytes
                             Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 18:52:21, 24128 bytes
                             Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.17514 (English), 11/20/2010 06:32:46, 155520 bytes
                               Name: High Definition Audio Controller
                          Device ID: PCI\VEN_1102&DEV_0009&SUBSYS_00181102&REV_00\5&A51C214&0&0000E1
                             Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/20/2010 03:43:43, 122368 bytes
                               Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A39
                          Device ID: PCI\VEN_8086&DEV_3A39&SUBSYS_02AC1028&REV_00\3&11583659&0&D2
                          Device ID: PCI\VEN_8086&DEV_3A20&SUBSYS_02AC1028&REV_00\3&11583659&0&FA
                               Name: Realtek PCIe GBE Family Controller
                          Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_02AC1028&REV_02\00E04C680000000300
                             Driver: n/a
                               Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A38
                          Device ID: PCI\VEN_8086&DEV_3A38&SUBSYS_02AC1028&REV_00\3&11583659&0&D1
                               Name: Intel(R) ICH10R LPC Interface Controller - 3A16
                          Device ID: PCI\VEN_8086&DEV_3A16&SUBSYS_02AC1028&REV_00\3&11583659&0&F8
                             Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 18:48:27, 15424 bytes
                               Name: NVIDIA GeForce GTS 240
                          Device ID: PCI\VEN_10DE&DEV_0607&SUBSYS_073610DE&REV_A2\4&760E681&0&0008
                             Driver: C:\Windows\System32\DriverStore\FileRepository\nvdd.inf_amd64_neutral_2fada41de6a02590\Nv CplSetupInt.exe, 14.00.0000.0162 (English), 6/26/2009 15:01:00, 40150157 bytes
                             Driver: C:\Windows\system32\DRIVERS\nvBridge.kmd, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 11168 bytes
                             Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 11515808 bytes
                             Driver: C:\Windows\system32\dpinst.exe, 2.01.0000.0000 (English), 6/26/2009 15:01:00, 930272 bytes
                             Driver: C:\Windows\system32\nvapi64.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 1228800 bytes
                             Driver: C:\Windows\system32\nvcuda.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 2304000 bytes
                             Driver: C:\Windows\system32\nvcuvid.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 733728 bytes
                             Driver: C:\Windows\system32\nvd3dumx.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 9476608 bytes
                             Driver: C:\Windows\system32\nvdecodemft.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 322080 bytes
                             Driver: C:\Windows\system32\nvdisp.nvu, 6/26/2009 15:01:00, 10161 bytes
                             Driver: C:\Windows\system32\nvoglv64.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 14289920 bytes
                             Driver: C:\Windows\system32\nvudisp.exe, 1.04.0032.0010 (English), 6/26/2009 15:01:00, 539168 bytes
                             Driver: C:\Windows\system32\nvwgf2umx.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 4363264 bytes
                             Driver: C:\Windows\SysWow64\nvapi.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 991232 bytes
                             Driver: C:\Windows\SysWow64\nvcuda.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 1705984 bytes
                             Driver: C:\Windows\SysWow64\nvcuvenc.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 1317408 bytes
                             Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 678432 bytes
                             Driver: C:\Windows\SysWow64\nvd3dum.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 7620608 bytes
                             Driver: C:\Windows\SysWow64\nvdecodemft.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 256544 bytes
                             Driver: C:\Windows\SysWow64\nvencodemft.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 1530400 bytes
                             Driver: C:\Windows\SysWow64\nvoglv32.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 10383360 bytes
                             Driver: C:\Windows\SysWow64\nvwgf2um.dll, 8.15.0011.8627 (English), 6/26/2009 15:01:00, 3155456 bytes
                             Driver: C:\Windows\system32\nvcod.dll, 1.05.0006.0051 (English), 6/26/2009 15:01:00, 167936 bytes
                             Driver: C:\Windows\system32\nvcod156.dll, 1.05.0006.0051 (English), 6/26/2009 15:01:00, 167936 bytes
                               Name: Intel(R) ICH10 Family PCI Express Root Port 6 - 3A4A
                          Device ID: PCI\VEN_8086&DEV_3A4A&SUBSYS_02AC1028&REV_00\3&11583659&0&E5
                               Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A37
                          Device ID: PCI\VEN_8086&DEV_3A37&SUBSYS_02AC1028&REV_00\3&11583659&0&D0
                               Name: Intel(R) 4 Series Chipset PCI Express Root Port - 2E21
                          Device ID: PCI\VEN_8086&DEV_2E21&SUBSYS_02AC1028&REV_03\3&11583659&0&08
                          DirectShow Filters
                          DirectShow Filters:
                          WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
                          WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
                          WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
                          Canon G.726 DMO Decoder,0x00000000,1,1,CANONG~2.DLL,1.00.0000.0003
                          MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
                          Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
                          WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
                          WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
                          Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
                          Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
                          DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
                          Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17514
                          WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
                          Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
                          AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17514
                          VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17514
                          SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
                          Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
                          AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
                          StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
                          Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17514
                          MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514
                          CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
                          MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17514
                          SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
                          VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
                          MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
                          Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
                          SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
                          Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
                          Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514
                          MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17514
                          DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
                          Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17514
                          Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
                          ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17514
                          Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514
                          MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
                          Line 21 Decoder,0x00600000,1,1,,
                          Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17514
                          Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17514
                          DivX Decoder Filter,0x00800000,1,1,DivXDec.ax,
                          VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
                          WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
                          VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
                          File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
                          iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
                          iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
                          DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17514
                          Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17514
                          Overlay Mixer2,0x00200000,1,1,,
                          RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
                          Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
                          WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
                          MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
                          DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
                          SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
                          Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
                          MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
                          Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
                          StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
                          Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
                          Overlay Mixer,0x00200000,0,0,,
                          AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514
                          NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
                          AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17514
                          Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
                          MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
                          Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
                          File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17514
                          Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
                          StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
                          AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
                          Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17514
                          File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17514
                          File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17514
                          Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
                          AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
                          AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
                          SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
                          Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
                          Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
                          BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17514
                          MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17514
                          WDM Streaming Tee/Splitter Devices:
                          Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                          Video Compressors:
                          WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
                          WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
                          MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
                          DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
                          MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17514
                          Audio Compressors:
                          WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
                          WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
                          IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514
                          Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514
                          GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17514
                          CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514
                          CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514
                          MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17514
                          PBDA CP Filters:
                          PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
                          PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
                          PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
                          Midi Renderers:
                          Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17514
                          Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17514
                          WDM Streaming Capture Devices:
                          Sound Blaster X-Fi Xtreme Audio S/PDIF-In,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                          ,0x00000000,0,0,,
                          Sound Blaster X-Fi Xtreme Audio Mic-In,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                          ,0x00000000,0,0,,
                          WDM Streaming Rendering Devices:
                          ,0x00000000,0,0,,
                          Sound Blaster X-Fi Xtreme Audio S/PDIF-Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                          ,0x00000000,0,0,,
                          ,0x00000000,0,0,,
                          Sound Blaster X-Fi Xtreme Audio Line-Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                          BDA Network Providers:
                          Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                          Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                          Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                          Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                          Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
                          Multi-Instance Capable VBI Codecs:
                          BDA Transport Information Renderers:
                          BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17514
                          MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
                          BDA CP/CA Filters:
                          Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17528
                          Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17528
                          PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17528
                          XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17528
                          WDM Streaming Communication Transforms:
                          Audio Renderers:
                          Speakers (Sound Blaster X-Fi Xt,0x00200000,1,0,quartz.dll,6.06.7601.17514
                          Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17514
                          Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17514
                          DirectSound: Speakers (Sound Blaster X-Fi Xtreme Audio),0x00200000,1,0,quartz.dll,6.06.7601.17514
                          EVR Power Information
                          Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
                            Quality Flags: 2576
                              Enabled:
                              Force throttling
                              Allow half deinterlace
                              Allow scaling
                              Decode Power Usage: 100
                            Balanced Flags: 1424
                              Enabled:
                              Force throttling
                              Allow batching
                              Force half deinterlace
                              Force scaling
                              Decode Power Usage: 50
                            PowerFlags: 1424
                              Enabled:
                              Force throttling
                              Allow batching
                              Force scaling
                              Decode Power Usage: 0
