4 Replies Latest reply on Mar 9, 2011 5:14 AM by broconne
    localToGlobal
    broconne
      I am having a lot of trouble making sense of the local to global function in flex.
      Essentially, I want to determine the distance between two objects in flex and then I am going to animate some text moving between the objects.
      Both objects are located within the same container, a VBox, that is inside of a Panel.
      I do the following:
      var object1Point:Point = object1.localToGlobal(new Point(0,0));
      var object2Point:Point = object2.localToGlobal(new Point(0,0));
      Then I trace those values.
      I get:
      object1Point.x = 863
      object1Point.y = 124
      object2Point.x = 753
      object2point.y = 699
      When I grab a screen capture, crop out the browser portion and examine pixel locations with GIMP I note that the X locations seem to be relativly accurate.  However, the y locations seem to be nowhere near accurate..  There is a maximum 200 pixel difference in y starting position...
      Any suggestions on what could cause this discrepancy?
