1. Re: relink html page to images & css
osgood_ Mar 8, 2011 10:27 AM (in response to rigoliarts)rigoliarts wrote:
I did this renaming in the file folder on the desktop (could that be the problem?).
Yes, this would be the problem. You should only ever work via the files panel>Window>Files. If you then make changes to a file or move it to a different location within the site root folder Dreamweaver will ask you if you want to update the links assocaiated with that file.
rigoliarts wrote:
Any ideas as to how I can reestablish the links?
Unless you have a back-up of the orginal file you may have to update the links manually. If you have the orginal file put it back in it's original location and then do any updates via the site panel.
2. Re: relink html page to images & css
rigoliarts Mar 8, 2011 7:56 PM (in response to osgood_)Thank you for your advice. Fortunately, I had saved the original file and was able to revise it within the files panel. God help me if I ever try to make a change outside the files panel ever again!
