1 Reply Latest reply on Jun 20, 2007 3:30 PM by Tareq AlJaber
    XML flash instances
    jak9942 Level 1
      I have created an app with a menu bar component. i am using an XML file to load the menu labels. this works fine but i dont know how to specify an action or instance in the XML. I am using the following code. How do i add actions or instances in the XML? All help apreciated
        • 1. Re: XML flash instances
          Tareq AlJaber Employee Moderator
          I not sure i understand what you mean by "How do i add actions or instances in the XML?"
          But the structure for your code code be as this :
          1. Parse the XML into an Array or XMLList
          2. then run an Case statement on the different label that you have
          so for instance :
          case "Edit" :
          call your method"
          break;
