11 Replies Latest reply on Mar 9, 2011 2:28 PM by KeelyL
    Formatting Custom Calculated Field
    KeelyL
      I have a form that uses custom calculation scripts on a number of fields and I have noticed that when I apply formatting, using the Text Field Properties Formatting tab, it doesn't affect the fields. I need to apply number formatting, with commas, for some and currency formatting for others. Any suggestions?
      Thanks!
        • 1. Re: Formatting Custom Calculated Field
          George_Johnson MVP & Adobe Community Professional
          How have you set up the calculation?
          • 2. Re: Formatting Custom Calculated Field
            KeelyL Level 1
            The calculation is set up in the Calculate tab of the Text Field Properties menu. I'm using the Custom Calculation Script option.
            • 3. Re: Formatting Custom Calculated Field
              The datails of the script might be important. Can you post it?
              • 4. Re: Formatting Custom Calculated Field
                KeelyL Level 1
                Here are two examples of the calculations.
                _______________________________________
                var ngper = this.getField('NGper').value;
                var base = this.getField('TFkbtu60').value;
                event.value = Math.round(base*ngper)
                ________________________________________
                var base = this.getField('sebase').value;
                var est = this.getField('sekbtu').value;
                if(base <= est){
                event.value = 0;
                }else{
                event.value = base - est}
                • 5. Re: Formatting Custom Calculated Field
                  Those look fine. Some things to check are:
                  1. Change the value of one or more of the fields that are involved in the calculation and see what happens. Does the value get recalculated correctly, but without the formatting?
                  2. Check that the formatting is still set to what you want.
                  3. Check for errors in the JavaScript console: Ctrl+J
                  4. Check that JavaScript is enabled (Edit > Preferenced > JavaScript)
                  5. Check that automatic calculations are enabled (Edit > Preferences > Forms)
                  6. Close and restart Acrobat
                  7. Reboot
                  If none of that helps, can you post a sample somewhere?
                  • 6. Re: Formatting Custom Calculated Field
                    KeelyL Level 1
                    Hi George,
                    Thanks for your suggestions. I haven't been able to resolve the issue yet, though I did find some messages in the JavaScript Debugger but I'm not really sure what they mean.
                    • 7. Re: Formatting Custom Calculated Field
                      Can you post what the messages are?
                      • 8. Re: Formatting Custom Calculated Field
                        KeelyL Level 1
                        InitializeFormsTrackerJS is not defined
                        1:App:Init
                        undefined is not a function
                        InitializeMultimediaJS is not defined
                        1:App:Init
                        AFDate_FormatEx is not defined
                        1:Field:Format
                        AFNumber_Format is not defined
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        AFSpecial_Format is not defined
                        1:Field:Format
                        1:Field:Format
                        AFPercent_Format is not defined
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        AFNumber_Keystroke is not defined
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Format
                        AFPercent_Keystroke is not defined
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        this.getField("sngkbtu") has no properties
                        4:Field:Calculate
                        1:Field:Keystroke
                        4:Field:Calculate
                        4:Field:Calculate
                        1:Field:Keystroke
                        4:Field:Calculate
                        4:Field:Calculate
                        this.getField("sekbtu") has no properties
                        1:Field:Calculate
                        1:Field:Format
                        1:Field:Keystroke
                        4:Field:Calculate
                        4:Field:Calculate
                        2:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        this.getField("ESavings") has no properties
                        6:Field:Calculate
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        this.getField("NGSavings") has no properties
                        6:Field:Calculate
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        this.getField("Rincentive") has no properties
                        2:Field:Calculate
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        this.getField("gUtility") has no properties
                        2:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        this.getField("eUtility") has no properties
                        2:Field:Calculate
                        1:Field:Format
                        2:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        2:Field:Calculate
                        1:Field:Format
                        2:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        2:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        even is not defined
                        6:Field:Calculate
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Keystroke
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        1:Field:Format
                        undefined is not a functionCannot continue printing to the console.
                        • 9. Re: Formatting Custom Calculated Field
                          That's not normal and would tend to indicate there's something wrong with your installation. I would do a repair of Acrobat, and if that doesn't work, reinstall Acrobat.
                          • 10. Re: Formatting Custom Calculated Field
                            Actually, I'd first reboot your machine, or at least restart Acrobat, before anything else.
                            • 11. Re: Formatting Custom Calculated Field
                              KeelyL Level 1
                              I reinstalled Acrobat and it corrected the issue! Thank you!
