2 Replies Latest reply on Mar 9, 2011 7:35 AM by elasota
    Embedded JPEG Extended images corrupted in Reader X, but not 9.4
    elasota
      We're experiencing an issue where JPEG images embedded in PDFs display properly with Reader 9.4.2 and with third-party readers such as FoxIt, but experience color corruption when displayed with Reader 10.0.1.  Adjusting display settings has not helped.
      This only affects JPEG Extended images, i.e. non-progressive with a 16-bit quantization table, which quite a few pieces of software will produce at low quality settings.  JPEGs with 8-bit quantization tables, i.e. basically everything saved at higher quality levels, are not affected.
      I can provide a sample PDF if needed.
      Screenshot of the problematic PDF below.  The two images should look the same (though at different scales).  The first is a JPEG Extended image that displays properly in other PDF viewers and in 9.4.2, the second is the same image resaved at a higher quality level, and is what the first one should look like.
      Please advise on potential workarounds, or if this is a known issue.
