3 Replies Latest reply on Mar 9, 2011 1:06 PM by prodigalmaster
    for loop not working
    prodigalmaster Level 2
      player_mc.onEnterFrame = function(){
      for (i=0; i<4; i++) {
                if (_root["icetw"+i].hitTest(this)) {
                     friction = 0.98;
                } else {
                     friction = 0.92;
      There are 4 movieclips with instance names icetw0, icetw1, icetw2, icetw3.
      The code above is correct? but it only works for icetw3. EDIT: Oh wait now it seems to work on none of the movieclips now I add a trace.
      Help??what could possibly be wrong with that code? I have other working for loops but this one just doesnt work properly it is so frustrating im thinking its a bug!
        • 1. Re: for loop not working
          1.  are trying to test for a hitTest between player_mc and _root.icetw0, _root.icetw1 etc?
          2.  would you notice if and when friction changes by .06?
          • 2. Re: for loop not working
            I decided I'd wait to see what you had to say for this one after seeing I got the same results and couldn't find a way around it... the increment (i) gets stuck at 3
            • 3. Re: for loop not working
              1. yes
              2. yes but it only for the final movieclip.
              hmm I add a trace if hit and it works for all 4 movieclips but changing a variable (friction) only works for the last movieclip (icetw3).
              if (onIce == true) {
                        friction = 0.98;
                   } else {
                        friction = 0.92;
                        if (_root["ice2_"+i].hitTest(this)) {
                             trace("hit");
                             onIce = true;
                        } else {
                             onIce = false;
                   trace(onIce);
              I have restarted the code so icetw = ice2_
              This code outputs false until player_mc and ice2_3 are touching. Yet it traces 'hit' if player_mc is touching any of the 4 mc's.
              I got it to work I realised it was the else in the hitTest not working so here is the new code:
                        friction = 0.98;
                   } else {
                        friction = 0.92;
                   onIce = false;
                             trace("hit");
                             onIce = true;
              Thanks anyway
