1. Re: "Recognize text using OCR" is greyed out
ravishar Apr 19, 2011 4:32 AM (in response to bnoof)If I understand your issue correctly, what you are seeing is:
- Recognize Text is disabled
- OCR on multiple files is enabled
The only situations when that can happen are:
- When you don't have any document open in Acrobat.
- When the open document is a protected so that you don't have rights to modify the document. In this case, you can go to Document Properties (Ctrl+D) and change security.
Please let me know if your case is neither of the two above.
-Ravish
2. Re: "Recognize text using OCR" is greyed out
bnoof Apr 19, 2011 6:28 AM (in response to ravishar)It must be password protected by the originator then. At least that tells me where to go to get the protection removed. Thanks for your help!
3. Re: "Recognize text using OCR" is greyed out
Phillip Jones Apr 19, 2011 7:57 AM (in response to bnoof)Another Possibility is that the document was a scanned image and not actually a text document. OCR would be unavailble.
However you seemed to have found the problem. Still being an scanned image is a Possibility for OCR not to work.
