1 Reply Latest reply on May 30, 2012 9:15 AM by graljackal
    Undo/Redo UndoManager
    dcurtino
      Guys,
      I am new to Flex and I need to implement Undo/Redo features. Following the example shown at http://blog.onebyonedesign.com/actionscript/playing-around-with-the-new-undomanager/ I tried to do it myself, but obviously something is not right as it is not working. I am tired and I believe that what is wrong is so obvious that someone else will find it in 3 min.
      What I tried to to is really simple: a have a panel, with one text input control and two buttons. When I click on the 1st button, I wanted it to change whatever text I have written in the text input control for "Trying undo". When I click on Undo, I expected it to put the text original text. But neither of those two actions is happening. I don't see the change to "Trying undo" and I doesn't come back to the original text either.
      I post the code to see if someone can give a hint of what I am doing wrong.
      Thanks in advance
      Adobe Window where the controls are
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
          <fx:Script>
              <![CDATA[
                  import flashx.undo.UndoManager;
                  import undo.ChangeControlText;
                  private var undoManager:UndoManager = new UndoManager();
                  protected function btnChangeText_clickHandler(event:MouseEvent):void
                      var newText : String = "Trying undo";
                      var operation : ChangeControlText = new ChangeControlText(txtInputText.text, newText, txtInputText);
                      undoManager.pushUndo(operation);
                  protected function btnUndo_clickHandler(event:MouseEvent):void
                      undoManager.undo();
          </fx:Script>
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <s:Panel x="132" y="38" width="321" height="249" title="Will undo work?">
              <s:Button x="31" y="160" label="Change" id="btnChangeText" click="btnChangeText_clickHandler(event)"/>
              <s:Button x="133" y="161" label="Undo" id="btnUndo" click="btnUndo_clickHandler(event)"/>
              <s:TextInput x="31" y="30" id="txtInputText" text="I'd like it to work" width="172"/>
          </s:Panel>
      </s:Application>
      Action Script class wheremy undo/redo functions are defined.
      package undo
          import flashx.undo.IOperation;
          import spark.components.TextInput;
          public class ChangeControlText implements IOperation
              private var previousText: String;
              private var currentText : String;
              private var textControl : TextInput;
              public function ChangeControlText(previousText:String, currentText:String, textControl:TextInput)
                  this.previousText = previousText;
                  this.currentText = currentText;
                  textControl = textControl;
              public function performUndo():void {
                  textControl.text = previousText;
              public function performRedo():void {
                  textControl.text = currentText;
