3 Replies Latest reply on Mar 10, 2011 1:01 AM by snkd
    flex spring security
    FlexSpring Level 1
      hi,
      I need to know permision based security framwork called chimp in flex.I am using spring in backend.Any ideas?
        • 1. Re: flex spring security
          snkd Level 1
          ok.
          you can use spring security as your server side security framwork. In spring there are two way security
          1. URL blocking
          2. method level security
          As you know Chimp is a permision based security framwork.
          and you can mention the
          you can decelare the activities for paticular role as follows
              <!--Meta Data here-->
              <fx:Metadata>
                  [Protected(permissions="admin",inPermissionAction="visible",componentId="btnAdd")]
                  [Protected(permissions="admin",inPermissionAction="visible",componentId="fmAdmin")]
                  [Protected(permissions="user",notInPermissionAction="enable",componentId="btnDelete")]
                  [Protected(permissions="user",notInPermissionAction="removeChild",componentId="btnList")]
                  [Protected(permissions="user",notInPermissionAction="removeFromLayout",componentId="btnFi nd")]
              </fx:Metadata>
          you can load chimp security as follows
          do this initialy
                      private function create():void {
                          //load the chimp
                           var perms:ArrayCollection = new ArrayCollection();
                          perms.addItem("user");//load role
                          perms.addItem("update");
                          Chimp.load(perms);
          do this when role change add/remove/override
                      private function addPerm(event:Event):void {
                          Chimp.addPerm(cmbRole.selectedItem);
                      private function removePerm(event:Event):void {
                          Chimp.removePerm(cmbRole.selectedItem);
                      private function overwritePerms(event:Event):void {
                          perms.addItem(cmbRole.selectedItem);
                          Chimp.updatePerms(perms);
          For spring security use the link
          http://www.springbyexample.org/examples/simple-spring-security-webapp-spring-config.html
          thnx
          • 2. Re: flex spring security
            snkd Level 1
            ok i missed one thing
            [Protected(permissions="admin",inPermissionAction="visible",component Id="btnAdd")]
            permissions-admin mean your role
            inPermissionAction- mean if that role has permision the what ?
            notInPermissionAction- mean if that role dont has permision the what ?
            component Id -mean what is the component you gonna restrict,simple give the id as string variable
            thnx
            • 3. Re: flex spring security
              snkd Level 1
              and you cando the following actions in chimp
              Possible actions as inPermissionAction/notInPermissionAction:
            • removeChild: Removes the component completely, by calling ‘comp.parent.removeChild()”
            • removeFromLayout: Use the includeInLayout property to remove components
            • invisible: Sets the comp.visible property to false
            • visable: Sets the comp.visible property to true
            • disable: Sets the comp.enable property to false
            • enable: Sets the comp.enable property to true
            • reference from http://code.google.com/p/flexible-chimp/
              thnx
