2 Replies Latest reply on Jul 2, 2011 1:15 AM by duvy06
    Generated super class
    duvy06
      Hi all,
      Still with the memory problem (see : http://forums.adobe.com/thread/798092?tstart=0) I find a working version on a Web server from testdrive_deploy-app (employee used in tutorials)
      I notice a quite big difference within the 2 generated super class.
      Here is the start from employee
      * This is a generated class and is not intended for modfication.  To customize behavior
      * of this service wrapper you may modify the generated sub-class of this class - EmployeeService.as.
      package services.employeeservice
      import com.adobe.fiber.core.model_internal;
      import com.adobe.fiber.services.wrapper.RemoteObjectServiceWrapper;
      import com.adobe.serializers.utility.TypeUtility;
      import mx.rpc.AbstractOperation;
      import mx.rpc.AsyncToken;
      import mx.rpc.remoting.Operation;
      import mx.rpc.remoting.RemoteObject;
      import valueObjects.Department;
      import valueObjects.Employee;
      import mx.collections.ItemResponder;
      import com.adobe.fiber.valueobjects.AvailablePropertyIterator;
      [ExcludeClass]
      internal class _Super_EmployeeService extends com.adobe.fiber.services.wrapper.RemoteObjectServiceWrapper
          // Constructor
          public function _Super_EmployeeService()
      And here is the newly generated class
      * of this service wrapper you may modify the generated sub-class of this class - SitecarsService.as.
      package services.sitecarsservice
      import mx.data.ItemReference;
      import mx.data.ManagedAssociation;
      import mx.data.ManagedOperation;
      import mx.data.ManagedQuery;
      import mx.data.RPCDataManager;
      import valueObjects.Site_cars;
      [ExcludeClass]
      internal class _Super_SitecarsService extends com.adobe.fiber.services.wrapper.RemoteObjectServiceWrapper
          private var _site_carsRPCDataManager : mx.data.RPCDataManager;
          private var managersArray : Array = new Array();
          public const DATA_MANAGER_SITE_CARS : String = "Site_cars";
          public function getDataManager(dataManagerName:String) : mx.data.RPCDataManager
              switch (dataManagerName)
                   case (DATA_MANAGER_SITE_CARS):
                      return _site_carsRPCDataManager;
                  default:
                      return null;
           * Commit all of the pending changes for this DataService, as well as all of the pending changes of all DataServices
           * sharing the same DataStore.  By default, a DataService shares the same DataStore with other DataServices if they have
           * managed association properties and share the same set of channels.
           * @see mx.data.DataManager
           * @see mx.data.DataStore
           * @param itemsOrCollections:Array This is an optional parameter which defaults to null when
           *  you want to commit all pending changes.  If you want to commit a subset of the pending
           *  changes use this argument to specify a list of managed ListCollectionView instances
           *  and/or managed items.  ListCollectionView objects are most typically ArrayCollections
           *  you have provided to your fill method.  The items appropriate for this method are
           *  any managed version of the item.  These are any items you retrieve from getItem, createItem
           *  or using the getItemAt method from a managed collection.  Only changes for the
           *  items defined by any of the values in this array will be committed.
           * @param cascadeCommit if true, also commit changes made to any associated
           *  items supplied in this list.
           *  @return AsyncToken that is returned in <code>call</code> property of
           *  either the <code>ResultEvent.RESULT</code> or in the
           *  <code>FaultEvent.FAULT</code>.
           *  Custom data can be attached to this object and inspected later
           *  during the event handling phase.  If no changes have been made
           *  to the relevant items, null is returned instead of an AsyncToken.
          public function commit(itemsOrCollections:Array=null, cascadeCommit:Boolean=false):mx.rpc.AsyncToken
               return _site_carsRPCDataManager.dataStore.commit(itemsOrCollections, cascadeCommit);
           *  Reverts all pending (uncommitted) changes for this DataService, as well as all of the pending changes of all DataServics
           *  @return true if any changes were reverted.
          public function revertChanges():Boolean
              return _site_carsRPCDataManager.dataStore.revertChanges();
          // Constructor
          public function _Super_SitecarsService()
      Super class in my application as a lot more feature compared to the emmployee one. My knowledge of Flex are not far enough to identifiy the consequences of thoses differences :-((
      Questions :
      1. Is it possible that it cause a big memory allocation request ?
      2. Does it means I activate new feature or default build options has been changed from the time employee was build.
      Thanks for your help
        • 1. Re: Generated super class
          bibiki
          hey there. I c none has answer yet. I was wondering if you found any solution to the problem you had? I am having the same issue, perhaps, if you've solved your problem you could help me too. thanks.
          • 2. Re: Generated super class
            duvy06 Level 1
            Hi bibiki,
            Yes I solve my problem and in my case I should adjust table/fields definition : only text or varchar and no blob of any kind.
            Apparently, when blob is used, allocation of memory is going bad.
            Hope it help ;-)
            Message was edited by: duvy06
