I am using Flash Builder Burrito for Flex Mobile Project. I wanted to set up a chart and so added the required libraries( mx.swc and datavisualization.swc ) and added xml namespaces to include the components . I got the charts up and running also.
My only problem with the charts is Legends are not working..
Whenever I add it I get a red mark over the Project and the application fails to run.This is the same case with all chart types.
I do not get any red mark in the code , but only on my project icon .
Then I Opened the Problems Console . I found these errors
Description Resource Path Location Type
1120: Access of undefined property ButtonSkin. AllChartsDisplay line 82 Flex Problem
1120: Access of undefined property ContainerBorderSkin. AllChartsDisplay line 114 Flex Problem
1120: Access of undefined property DefaultButtonSkin. AllChartsDisplay line 79 Flex Problem
1120: Access of undefined property ScrollBarDownButtonSkin. AllChartsDisplay line 690 Flex Problem
1120: Access of undefined property ScrollBarThumbSkin. AllChartsDisplay line 694 Flex Problem
1120: Access of undefined property ScrollBarTrackSkin. AllChartsDisplay line 689 Flex Problem
1120: Access of undefined property ScrollBarUpButtonSkin. AllChartsDisplay line 691 Flex Problem
1172: Definition mx.skins.spark:ButtonSkin could not be found. AllChartsDisplay line 30 Flex Problem
1172: Definition mx.skins.spark:ContainerBorderSkin could not be found. AllChartsDisplay line 31 Flex Problem
1172: Definition mx.skins.spark:DefaultButtonSkin could not be found. AllChartsDisplay line 15 Flex Problem
1172: Definition mx.skins.spark:ScrollBarDownButtonSkin could not be found. AllChartsDisplay line 14 Flex Problem
1172: Definition mx.skins.spark:ScrollBarThumbSkin could not be found. AllChartsDisplay line 13 Flex Problem
1172: Definition mx.skins.spark:ScrollBarTrackSkin could not be found. AllChartsDisplay line 19 Flex Problem
1172: Definition mx.skins.spark:ScrollBarUpButtonSkin could not be found. AllChartsDisplay line 26 Flex Problem
AllChartsDisplay is the name of my Project
Please help me solve this problem...
I think you should remove the mx.swc and datavisualization.swc from the buildpath and just include charts.swc included in the Flex Hero SDK.
-Sunil
Hi sunil,
Thank you for the reply. I am using Adobe Flex Hero SDK. I could not find charts.swc file anywhere in my SDK.
I feel its a compatibility issue with the Flex Hero. In the older versions of the SDK , it is working fine.
Thanks.
