2 Replies Latest reply on Mar 14, 2011 3:35 AM by MartinOOE
    Adobe Reader X deletes Signature
    MartinOOE
      Hello,
      from an online-application pdf-files are opened. Then in Reader 9 the function "Save a Copy" is used. The saved file is a exact copy of the original.
      In Reader X the function is calles "Save as". The saved file is smaller then the original. The signature is lost
      www.signaturpruefung.at/en/
      Test of Example.pdf
      Test of ExampleSavedbyReaderX.pdf
      Does anybody know why Reader X delets the signature
      Regards martin
        • 1. Re: Adobe Reader X deletes Signature
          ManishPali Adobe Employee
          Could you please try turning off reader X protected mode and check if you continue to see the problem? You could turn off protected mode using following steps:
          1. Launch Reader X and select Edit->Preferences...
          2. Select General from left navigation
          3. Under application startup uncheck "Enable Protected Mode at Startup"
          Note: You should switch "ON" protected mode after verifying the problem. Purpose of Reader X Protected Mode is to keep your system safe from PDF based exploits and keeping protected mode OFF will leave your system vulnerable.
          • 2. Re: Adobe Reader X deletes Signature
            MartinOOE Level 1
            Thank You.
            To disable the protected mode does not change anything. The signature is still deleted after saving the PDF.
            Regards martin
