2 Replies Latest reply on Mar 10, 2011 6:10 PM by Nuwan,Chamara
    Dynamic objects
    Maximist Level 1
      Hallo. I have created 2 objects: myObjectOne and myObjectTwo. Now I have an object which can use only 1 of those 2 objects depending from a variable in setData. if this var which is named objectType is "One", i will create the first object. if this var is "Two", i will create the second object.
      What i want to do is:
      var myObject:myObjectOne = new myObjectOne();   // but only if objectType= "One", so i tried:
      var myObject:myObject[objectType] = new myObject[objectType]();    // but this doesn't work
      What i want to do is to replace One in the word myObjectOne with my var (objectType) but i don't know how to do it.
      I hope you understood.
      Thx
      Max
        • 1. Re: Dynamic objects
          UbuntuPenguin Level 4
          Why don't you just make the objects and pass them to a function.  Observe...
          private function useDifferentObjects( object:Object ):void
            if( object is InstanceOfObjectOne )
            else
          • 2. Re: Dynamic objects
            Nuwan,Chamara Level 1
            I think instead of replacing the "objectType" property, you can delete that property using
            delete keyword and then add the new property "One" to the object.
            if(objectType == "One"){
                 var objectTypePropVal:Object = myObject["objectType"];
                 delete myObject.objectType;
                 myObject["One"] = myObject["objectTypePropVal"];
