1 Reply Latest reply on Jun 16, 2007 1:32 PM by Chuck1411
    insert values in field database by check boxes
    silviasalsa Level 1
      I had a similar error and probem when using dropdown instead of a check box. It was resolved by putting SELECT name="CarMake in the drop down.
      But in the checkbox, I don’t know?
      I seems like the problem is the action page has the Form.carmake but the entry page does not. What am I missing and where do I put in the entry page below.
      The key goal is to have checkboxes checked to insert values into the database field carmake based on what is checked.
      If the checkbox Honda is checked then
      it inserts to the carmake field the value Honda.
      If the checkbox Toyota is checked then
      it inserts to the carmake field the value Toyota.
      If both are checked then 2 records are inserted both values
      Honda and Toyota.
      Same for the last option.
      Thanks for all your help
      Here is the error again
      error:
      Error Occurred While Processing Request
      Element CARMAKE is undefined in FORM.
      12:21:50.050 - Expression Exception - in C:\CFusionMX7\wwwroot\Author\CarAddAction.cfm : line 16
      line 16 is:
      '#Trim(Form.carmake)#',
      Attach Code
      <!------------here is the form------------>
      <html>
      <head>
      </head>
      <body>
      <h1> </h1>
      <table>
      <cfform action="CarAddAction.cfm" method="POST">
      <tr>
      <td>Honda:</td>
      <td><center><input type="checkbox" name="HONDA_MODEL" value="HONDA" checked></center></td>
      </tr>
      <tr>
      <td>Toyota:</td>
      <td><center><input type="checkbox" name="Toyota_MODEL" value="Toyota" Unchecked></center></td>
      </tr>
      <tr>
      <td>SUBARU:</td>
      <td><center><input type="checkbox" name="SUBARU_MODEL" value="SUBARU" unchecked></center></td>
      </tr>
      <tr><td>Honda Model</td>
      <td>
      <input type="Text"
      name="Honda_Model"
      Value=""
      size="22"
      maxlength="20">
      </td>
      <tr></tr>
      <tr><td>Toyota Model</td>
      <td>
      <input type="Text"
      name="Toyota_Model"
      Value=""
      size="22">
      </td>
      <tr></tr>
      <tr><td>Subaru Model</td>
      <td>
      <input type="Text"
      name="Subaru_Model"
      Value=""
      size="22">
      </td>
      <tr></tr>
      <td> </td>
      <td>
      <input type="submit" value="Add make to Database">
      </td>
      </tr>
      </cfform>
      </table>
      </body>
      </html>
      <!--------Action page
      <cfdump var = "#form#">
      <cfquery name="InsertCarInfo"
      datasource="#Request.MainDSN#">
      INSERT INTO Car_tab(
      car_Make,
      Honda_Model,
      Toyota_Model,
      Subaru_Model
      VALUES (
      '#Trim(Form.Honda_Model)#',
      '#Trim(Form.Toyota_Model)#',
      '#Trim(Form.Subaru_Model)#'
      </cfquery>
