2 Replies Latest reply on Mar 10, 2011 12:22 PM by ninjatogo
    Simple math problems
    ninjatogo
      I am having trouble with an app I'm trying to develop. Problem is that I have created many text boxes, some will be used for input of integers (no decimal) and the others will be used for numbers with decimals.
      What I want to do is,
      change the text on a label
            that displays the value of the numbers in the two text boxes (decimal and non-decimal)
                 multiplied together
                     and added to another set of similar numbers.
      How do I do this?
      I am pretty new to programming in general, any help appreciated.
        • 1. Re: Simple math problems
          Rahul7777
          In flex Number represents decimal, and int represent integers so while getting the TextInput.text typecast those to required once.
          var x:int = int(tiInteger.text);    //this is integer
          var y:Number = Number(tiNumber.text);
          var z:Number = x * y;
          I created a small demo let me know if you struck.
                         xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
              <fx:Script>
                  <![CDATA[
                      protected function tiNumber_clickHandler(event:MouseEvent):void
                          tiNumber.text ="";
                      protected function tiInteger_clickHandler(event:MouseEvent):void
                          tiInteger.text ="";
                      protected function button1_clickHandler(event:MouseEvent):void
                          var x:Number=Number(tiNumber.text);
                          var y:int  = int(tiInteger.text);
                          var z:Number = x* y;
                          textLabel.text = String(z);
              </fx:Script>
              <fx:Declarations>
                  <!-- Place non-visual elements (e.g., services, value objects) here -->
              </fx:Declarations>
              <mx:TextInput id="tiNumber" text="Number" click="tiNumber_clickHandler(event)" x="40" y="33"/>
              <mx:TextInput id="tiInteger" text="Integer" click="tiInteger_clickHandler(event)" x="323" y="32"/>
              <mx:Button click="button1_clickHandler(event)" label="multiply" x="214" y="113"/>
              <mx:Text id="textLabel"/>
          </s:Application>
          • 2. Re: Simple math problems
            ninjatogo Level 1
            Thanks alot, really appreciate the help!
            Just to let you in on what I'm making, it's a wish list calculator for the Blackberry Playbook.
