30 Replies Latest reply on Oct 14, 2006 3:07 PM by Deaf Web Designer
    OT: Help with XSLT!
    Level 7
      Can anyone more experienced with these things help me understand why this
      page is not displaying as I wanted it to! 8)
      http://www.practicalcomponents.com/Local/drMLF.xsl
      Murray --- ICQ 71997575
      Adobe Community Expert
      (If you *MUST* email me, don't LAUGH when you do so!)
      http://www.dreamweavermx-templates.com - Template Triage!
      http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
      http://www.dwfaq.com - DW FAQs, Tutorials & Resources
      http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
        • 1. Re: Help with XSLT!
          Level 7
          did you try validating it?
          THis is what I get when I run it through
          The HTTP Content-Type header (text/xml) sent by your web server
          (Apache/1.3.26 (Unix) mod_perl/1.26 mod_throttle/2.11 PHP/4.1.0
          FrontPage/4.0.4.3 mod_ssl/2.8.9 OpenSSL/0.9.6f) did not contain a "charset"
          parameter, but the Content-Type was one of the XML text/* sub-types.
          The relevant specification (RFC 3023) specifies a strong default of
          "us-ascii" for such documents so we will use this value regardless of any
          encoding you may have indicated elsewhere.
          If you would like to use a different encoding, you should arrange to have
          your server send this new encoding information.
          Note: The Validator XML support has some limitations.
          http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.practicalcomponents.com%2FLoc al%2FdrMLF.xsl
          "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
          news:egltei$2ss$1@forums.macromedia.com...
          • 2. Re: Help with XSLT!
            Level 7
            The one above is an XSLT template, a browser can't render it.
            Are you trying to use XSLT client-side or leveraging a server-side language?
            I would guess you would like to format the data contained below using the
            XSLT template above:
            http://www.practicalcomponents.com/Local/ResultsReport-DRMLF.xml
            In such a case you should declare the XSLT inside the XML using something
            like:
            <?xml-stylesheet type="text/xsl" href="drMLF.xsl"?>
            To see something like this in action look at:
            http://localhost/massimocorner/rss/news.xml
            I am not sure I am being helpful, but I need more info.
            Massimo Foti
            Tools for ColdFusion and Dreamweaver developers:
            http://www.massimocorner.com
            • 3. Re: Help with XSLT!
              Level 7
              BTW This XML file seems to suffer from some bad encoding problem:
              Massimo
              • 4. Re: OT: Help with XSLT!
                Level 1
                Murray, I haven't really getting my hands dirty under the hood of XSLT at this point, I have meant to learn how it works, but I have put it off a bit.
                It looks like it is a good time for me to learn and analyze what went wrong.
                Say, Murray, did you take a look at sample Cafe Townsend as part of DW8 tutoring sample. Take a look inside some of the XSLT structure and the XML/XSL related topics as part of Cafe Townsend sample for people like you or me to play with and do some trail and error learning steps to make it work.
                What task are you trying to achieve this with your XSLT coding?
                • 5. Re: Help with XSLT!
                  Level 7
                  Ugh. Thanks, Massimo - what problems do you see there? It's a site search
                  result from DW.
                  "Massimo Foti" <massimo@massimocorner.com> wrote in message
                  news:eglvcd$56h$1@forums.macromedia.com...
                  > Massimo
                  • 6. Re: Help with XSLT!
                    Level 7
                    > language?
                    I'm trying to display an XML file from the server.
                    So - just put this line inside the XML file?
                    news:eglusq$4k2$1@forums.macromedia.com...
                    > language?
                    > like:
                    > Massimo Foti
                    • 7. Re: Help with XSLT!
                      Level 7
                      news:egm5g9$cig$1@forums.macromedia.com...
                      > search result from DW.
                      The strings inside <mm_displaystr> appears broken. It looks like an encoding
                      problem. Do you see them okay in a browser?
                      Massimo
                      • 8. Re: OT: Help with XSLT!
                        Level 7
                        I'm trying to display the results of a saved sitewide search in DW. It's
                        saved as an XML file, and I thought it'd be fun to be able to display that
                        to the client from the web.
                        "Deaf Web Designer" <webforumsuser@macromedia.com> wrote in message
                        news:egm2du$8n6$1@forums.macromedia.com...
                        > this
                        > wrong.
                        > XML/XSL
                        > to
                        • 9. Re: Help with XSLT!
                          Level 7
                          news:egm5j3$ckp$1@forums.macromedia.com...
                          >> language?
                          But who is supposed to perform the XSL trasformation, the browser or the
                          server? It looks like you would like to let the browser do the job, but I am
                          not sure
                          The line above is an instruction that sort of tell the browser: "Apply the
                          XSL transformation defined inside drMLF.xsl to the current XML file".
                          Massimo
                          • 10. Re: Help with XSLT!
                            Level 7
                            > am not sure
                            Heh - how would I know? I suppose I want the browser to do it.
                            news:egm5ua$d0l$1@forums.macromedia.com...
                            >>> language?
                            > am not sure
                            > Massimo
                            • 11. Re: Help with XSLT!
                              Level 7
                              Ahh - note that those are utf-8-type strings. They are from Japanese and
                              Chinese pages. Is that what you mean?
                              news:egm5o6$cq7$1@forums.macromedia.com...
                              > encoding problem. Do you see them okay in a browser?
                              > Massimo
                              • 12. Re: Help with XSLT!
                                Level 7
                                news:egm6n7$e1d$1@forums.macromedia.com...
                                XML assumes utf-8 by default (unless otherwise stated), on my PC both IE and
                                FF tried to display those string using utf-8 and failed. Do you see them
                                okay?
                                Massimo
                                • 13. Re: Help with XSLT!
                                  Level 7
                                  news:egm6k2$dr9$1@forums.macromedia.com...
                                  >> am not sure
                                  I see you are diving head first into this :-)
                                  Yes, you better let the browser do it
                                  Massimo
                                  • 14. Re: Help with XSLT!
                                    Level 7
                                    Then would I browse to the xml file or the xsl file?
                                    > language?
                                    > like:
                                    > Massimo Foti
                                    • 15. Re: Help with XSLT!
                                      Level 7
                                      Not when I open the page with Notepad, no.
                                      news:egm71c$ecl$1@forums.macromedia.com...
                                      > and FF tried to display those string using utf-8 and failed. Do you see
                                      > them okay?
                                      > Massimo
                                      • 16. Re: Help with XSLT!
                                        Level 7
                                        Actually, it's more of a cannoball....
                                        OK - I'm hoping the browser knows how to do this. 8)
                                        news:egm71d$ecl$2@forums.macromedia.com...
                                        >>> I
                                        >>> am not sure
                                        > Massimo
                                        • 17. Re: Help with XSLT!
                                          Level 7
                                          I do if I browse here -
                                          > them okay?
                                          > Massimo
                                          • 18. Re: Help with XSLT!
                                            Level 7
                                            news:egm7af$eq1$1@forums.macromedia.com...
                                            I just downloaded both the xml and xsl files, added this to the xml:
                                            Then opened the xml in a browser. You get something that start looking like
                                            an HTML page. Sure, the layout may get some improvements, but it's a
                                            starting point.
                                            Massimo
                                            • 19. Re: Help with XSLT!
                                              Level 7
                                              news:egm73f$eev$1@forums.macromedia.com...
                                              The xml one
                                              Massimo
                                              • 20. Re: Help with XSLT!
                                                Level 7
                                                news:egm7c7$erd$1@forums.macromedia.com...
                                                I don't, but maybe I am just missing the proper typefaces.
                                                Massimo
                                                • 21. Re: Help with XSLT!
                                                  Level 7
                                                  That's possible. I did install a few extra fonts to see it. This is
                                                  strictly for the client's information - not public. You won't reveal the
                                                  link, will you? 8)
                                                  If you browse there now, you will see an ugly display of the search results.
                                                  Thanks so much for your help!
                                                  news:egm7k8$f3i$1@forums.macromedia.com...
                                                  > Massimo
                                                  • 22. Re: Help with XSLT!
                                                    Level 7
                                                    news:egm7nm$f7p$1@forums.macromedia.com...
                                                    > link, will you? 8)
                                                    Okay, I will keep it for me, but drinks are on you next time we meet :-)
                                                    BTW I just noticed that you have this line at the top of your XSLT:
                                                    <xsl:output method="html" encoding="iso-8859-1"
                                                    You may try changing the encoding to utf-8, since your are feeding the XSLT
                                                    template with utf-8 data.
                                                    > results.
                                                    The Webdevelopers Toolbar for Firefox has a "View generated source" that can
                                                    help making the output less ugly.
                                                    A good resouce for XSLT beginners is:
                                                    http://www.w3schools.com/xsl/default.asp
                                                    You earned so much good karma helping people here along the years, you
                                                    deserve all the help and much, much more.
                                                    Massimo
                                                    • 23. Re: Help with XSLT!
                                                      Level 7
                                                      Perhaps something special from Lindt? 8)
                                                      > XSLT template with utf-8 data.
                                                      Well, that would only be sensible!
                                                      > can help making the output less ugly.
                                                      Have that and didn't even think to use it.
                                                      news:egm888$fr2$1@forums.macromedia.com...
                                                      >> link, will you? 8)
                                                      >> results.
                                                      > Massimo
                                                      • 24. Re: Help with XSLT!
                                                        Level 7
                                                        news:egm992$h6q$1@forums.macromedia.com...
                                                        http://www.lindt.com/
                                                        Troubleshooting XSLT can be quite a pain, that tool often help
                                                        Massimo
                                                        • 25. Re: Help with XSLT!
                                                          Level 1
                                                          Hi Massimo Foti,
                                                          As for your statement quoted as follows below:
                                                          > "...The Webdevelopers Toolbar for Firefox has a "View generated source" that can help making the output less ugly."
                                                          Agreed!
                                                          I am jotting down on my notepad regarding helpful resoure about XSLT stuff at W3C org site. Thanks for heads up, Massimo.
                                                          OT, are you Italian? I am half Italiano and half french-canadian, btw. :)
                                                          Ciao, DWD
                                                          • 26. Re: Help with XSLT!
                                                            Level 7
                                                            news:egma1o$i2d$1@forums.macromedia.com...
                                                            Yes, I am italian, but I live and work in Switzerland. You can find
                                                            additional info on my website.
                                                            BTW In my humble opinion XSLT is overrated and XSLT programming can be
                                                            pretty hard and unnatural. I still have to met one single programmer that
                                                            really enjoy XSLT developing :-)
                                                            If you are loking to expand your knowledge there may better look elsewhere
                                                            first
                                                            Massimo Foti
                                                            • 27. OT: Help with XSLT!
                                                              Level 1
                                                              Bonjour Massimo,
                                                              I always enjoyed my trips to Switzerland in the past. I am very fond of it! Three cousins and I did a skydiving a couple years ago in Switzerland. Boy, it was rather thrilling epxerience, but I wouldn't want to do skydiving again, though. However, I am glad that I did. I thought that I was having major heart attack. LOL But I never forget the majesty view of sky, mountains and fresh air!!!
                                                              • 28. Re: Help with XSLT!
        Level 7
        >> link, will you? 8)
        Forget the drinks! Who's bringing the *good* chocolate?
        Bonnie
        in California
        8 ^ )
        • 29. Re: Help with XSLT!
        Level 7
        "Bonnie" <kroko@pixel[occam]plum.com> wrote in message
        news:egpk8n$ju7$2@forums.macromedia.com...
        Traditionally I am the one taking care of that.But it has been a while since
        last time I crossed the ocean and met Murray.
        BTW A few hours ago, coming back from my trip to Dubendorf, I stopped in
        Zurich here:
        http://www.spruengli.ch/
        And took a few of these:
        http://www.spruengli.ch/Shop/geschenkideen-katalog.php?catalog=1001
        Massimo Foti
        • 30. Re: Help with XSLT!
        Level 1
        My goodness. That is my weakness with chocolates! So is coffee. :)
        Zurich here:
        Massimo Foti
