5 Replies Latest reply on Mar 14, 2011 4:57 AM by JJMack
    How to get the foreground/background color in photoshop.
    manish.mishra
      I want to get the foreground or background color at runtime ( by any action ) in photoshop.
      What steps should I follow.
        • 1. Re: How to get the foreground/background color in photoshop.
          c.pfaffenbichler Level 9
          What do you want to use that color-data for exactly?
          #target photoshop
          var foregroundColor = app.foregroundColor;
          var backgroundColor = app.backgroundColor;
          alert ("foregroundcolor\n"+foregroundColor.rgb.red+"\n"+foregroundColor.rgb.green+"\n"+foregroundColor.rgb.blue);
          alert ("backgroundcolor\n"+backgroundColor.rgb.red+"\n"+backgroundColor.rgb.green+"\n"+backgroundColor.rgb.blue);
          • 2. Re: How to get the foreground/background color in photoshop.
            Michael L Hale Level 5
            There is a start application event you can use to script tasks at runtime. You can set it up with the Scripts Event Manager found under File-Scripts menu.
            But as c.pfaffenbichler pointed out a script that just gets the colors is not very useful. Unless the script takes some action based on the colors found or stores the data somewhere like customOptions or to a file all the data in a script is removed from memory when the script ends.
            • 3. Re: How to get the foreground/background color in photoshop.
              For example here is a script I use within Photoshop Actions to save and restore the users foreground and background colors so the action can mess with Photoshops foreground and background colors during its processing.
              SaveAndRestoreColors.jsx
              // 2009  John J. McAssey (JJMack)  http://www.mouseprints.net/
              // This script is supplied as is. It is provided as freeware.
              // The author accepts no liability for any problems arising from its use.
              // This script is designed to be used by a Photoshop Action twice
              // A good pratice to use when creating an actions that use this scipt is for the action
              // not to do a save or play some other action between its two useages of this Script.
              // The first time this script is used by an action Photoshops Current Forground
              // and Background Colors are saved into the document's meta-data Info Instructions field.
              // The second time this script used by the action the script retreives what was
              // saved in the meta-data during the first usage and these colors are set.
              // and the saved data is removed from the document's meta-data Info Instructions field.
              <javascriptresource>
              <about>$$$/JavaScripts/SaveAndRestoreColors/About=JJMack's SaveAndRestoreColors.^r^rCopyright 2009 Mouseprints.^r^rRun twice script utility for action.^rNOTE:Don't play other actions between runs!^r^rFirst Run records Photoshops foreground and background swatch colors.^rSecond Run restores the recorded colors and removes the recording.</about>
              <category>JJMack's Action Run Twice Utility</category>
              </javascriptresource>
              if (app.documents.length > 0) {
              if (app.activeDocument.info.instructions.indexOf("<Colorf>") == -1 ){ // no footprint fisrt useage
              //alert("first");
              // Retreive Document information for Foot Print
              saveforeColor = new SolidColor;
              saveforeColor.rgb.red = app.foregroundColor.rgb.red;
              saveforeColor.rgb.green = app.foregroundColor.rgb.green;
              saveforeColor.rgb.blue = app.foregroundColor.rgb.blue;
              savebackColor = new SolidColor;
              savebackColor.rgb.red = app.backgroundColor.rgb.red;
              savebackColor.rgb.green = app.backgroundColor.rgb.green;
              savebackColor.rgb.blue = app.backgroundColor.rgb.blue;
              // put footprint in metadata info instructions
              app.activeDocument.info.instructions = app.activeDocument.info.instructions + "<Colorf>" + saveforeColor.rgb.red + "," + saveforeColor.rgb.green + "," + saveforeColor.rgb.blue + "</Colorf>" + "<Colorb>" + savebackColor.rgb.red + "," + savebackColor.rgb.green + "," + savebackColor.rgb.blue + "</Colorb>";
              //alert( "Saved ="  + "<Colorf>" + saveforeColor.rgb.red + "," + saveforeColor.rgb.green + "," + saveforeColor.rgb.blue + "</Colorf>" + "<Colorb>" + savebackColor.rgb.red + "," + savebackColor.rgb.green + "," + savebackColor.rgb.blue + "</Colorb>");
              else {
              //alert("second");
              // Retreive saved information
              colorfOffset = app.activeDocument.info.instructions.indexOf("<Colorf>") + "<Colorf>".length;
              colorfLength = app.activeDocument.info.instructions.indexOf("</Colorf") -colorfOffset;
              saveforeColor = app.activeDocument.info.instructions.substr(colorfOffset, colorfLength);
              colorbOffset = app.activeDocument.info.instructions.indexOf("<Colorb>") + "<Colorb>".length;
              colorbLength = app.activeDocument.info.instructions.indexOf("</Colorb") -colorbOffset;
              savebackColor = app.activeDocument.info.instructions.substr(colorbOffset, colorbLength);
              //alert("Colorf = " + saveforeColor + " Colorb = " + savebackColor );
              // Restore Colors
              app.foregroundColor.rgb.red = saveforeColor.substr(0,saveforeColor.indexOf(","));
              saveforeColor = saveforeColor.substr(saveforeColor.indexOf(",") + 1,saveforeColor.length);
              app.foregroundColor.rgb.green = saveforeColor.substr(0,saveforeColor.indexOf(","));
              app.foregroundColor.rgb.blue = saveforeColor ;
              app.backgroundColor.rgb.red = savebackColor.substr(0,savebackColor.indexOf(","));
              savebackColor = savebackColor.substr((savebackColor.indexOf(",") + 1),savebackColor.length);
              app.backgroundColor.rgb.green = savebackColor.substr(0,savebackColor.indexOf(","));
              savebackColor = savebackColor.substr(savebackColor.indexOf(",") + 1,savebackColor.length);
              app.backgroundColor.rgb.blue = savebackColor ;
              // Remove footprint from metadata info instructions
              before = app.activeDocument.info.instructions.substr(0,app.activeDocument.info.instructions.indexO f("<Colorf>"));
              afterOffset = app.activeDocument.info.instructions.indexOf("</Colorb>") + "</Colorb>".length;
              after = app.activeDocument.info.instructions.substr(afterOffset, app.activeDocument.info.instructions.length - afterOffset);
              //alert ("before = " + before + " after = " + after);
              app.activeDocument.info.instructions = before + after;
              else { alert("You must have at least one open document to run this script!"); }
              • 4. Re: How to get the foreground/background color in photoshop.
                manish.mishra Level 1
                Well I am sorry for not mentioning this I want to get the information of foreground and background color in my plugin( As my plugin is automation type) when any action is performed, So that I can have information about the color when that action is performed
                • 5. Re: How to get the foreground/background color in photoshop.
                  Is your Plug-in a compiled plug-in using Adobe's SDK or a Script  like Adobe'd Automate FitImage Script plug-in?  If it is a script you do it like the post here if compiled check the SDK for a way you would do it for the compiler languaqge your using.
