• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
cp. file cannot be opened directly
New Here ,
Jun 15, 2007 Jun 15, 2007
If I try to open .cp file directly by clicking it, the Captivate gets stuck and it is only showing big white box in the middle of the screen. If I go through the Captivate program and open the chosen file from there, its open it right away.
The same problem occurs in InDesgin.
I reinstalled the Captivate and the problem remains.
Any ideas?
Thank you.
Branka
TOPICS
Getting started
Views
505
Translate
Translate
Report
Report
Community guidelines
community guidelines
Valorous Hero ,
Hi Branka
Ideas? Sure! But seeing how it's Friday and all, you probably won't like mine, as it's a bit on the snarky side.
Always open Captivate first? Then open the file you wish to use? (See, warned you it was snarky)
I'm not sure what I might try to make it work differently. Personally, I never open files this way. I always open them after opening the application I used to create them.
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
Hi, Rick,
Sure, I forgive you because it's Friday
I expected that you would tell me to open Captivate first...
As a reminder.. the same problem occurs in Adobe InDesgin. It looks like some some Adobe registry glitch.
Chrs.
Branka
Votes
Translate
Translate
Report
Report
Advocate ,
Just another obvious option ... you might open Control Panel and check the file-association for the "CP" file extension. It might be pointing to an old install in which case you can use the edit (association) to point to the current main folder.
I only suggest this because it is Friday, you understand ...
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thank you,
but , been there, done that...
Thanx anyway!
Yes, I understand...
Votes
Translate
Translate
Report
Report
Resources
Help resources
