2 Replies Latest reply on Mar 11, 2011 7:56 AM by the_wine_snob
    Permanently delete unwanted frames?
    nais80
      I would like to PERMANENTLY delete unwanted frames and can't seem to figure out how to do it.  Help!?!
      I've been able to make clips, but I can't permanently delete the unwanted intro.
      Thanks!
      Nai
        • 1. Re: Permanently delete unwanted frames?
          nealeh Level 5
          You can either change the In / Out points of the clip, or use the scissor tool to cut at the start / end of the unwanted material and then delete the cut portion. Note that if you plan to use transitions you should leave a few extra frames at the beginning / end of the wanted portion (see Handles & Transitions - What are They?).
          Cheers,
          Neale
          • 2. Re: Permanently delete unwanted frames?
            the_wine_snob Level 9
            Nai,
            If you are seeing Frames, that you thought you had edited out, in say a Transition, you have not allowed enough Handles. As Neale says, you just need to move your In and/or Out Point so that those Frames do not appear in the area of the Transition. The article that he linked to will explain a lot. Handles are not an easy concept to grasp at first, but once you "get it," you will not forget it.
