3 Replies Latest reply on Mar 12, 2011 1:13 PM by [Jongware]-9BC6tI
    Script needed for Justification
    tpk1982 Level 4
      I have a setting of justification in my document as below.
      I just want a script identify this settings in document, if any violation found giving track to that paragraph(not for single line) to make this value. The need of this avoiding loose/tight lines. I know we can highlight this violation in preferences.
      Is it possible to create a script for this?
      Thanks in advance.
        • 1. Re: Script needed for Justification
          [Jongware]-9BC6tI Level 4
          Yes (cautiously), but what USE would it be?
          It does not remove the "track violation", it just changes its status.
          • 2. Re: Script needed for Justification
            tpk1982 Level 4
            Thanks for your reply. Actually if a line in a paragraph looks loose or tight, its because of our justification settings only. If you are giving tracking values, it will fill with words below line i.e it lends some character from next line. If we give positive tracking for a tight line, it will release some characters to next line. Is it possible to do this automatically?
            karthi
            • 3. Re: Script needed for Justification
              Yes (still "cautiously"), but how would this differ from what InDesign already is doing automatically?
              The tracking violation it shows is because there is no reasonable way to justify the text within the constraints given in the Justification dialog. If you want to allow tighter or looser tracking, specify this in this very same dialog!
              There is still no guarantee that changing the allowance will remove *all* tracking violations; at least, unless you allow so much variance it becomes virtually unimportant how much your text is tracked.
