1 Reply Latest reply on Jun 20, 2007 7:20 AM by Newsgroup_User
    flash cs3 bug
    jose_carlos
      Hi my name is José Carlos, sorry for my english I´m from spain, well I´m having troubles with flashCS3 or whit flash player 9 i don't know but I think it´s a bug in the program.
      When I write:
      on (release) {
      getURL("contacto.html", "mainFrame");
      it doesn't work of course you know that mainFrame is because my flash button has the instruction but in dreamweaver I have frames for the website, in all other versions of flash never have a problem but in the new version it doesn't work well, the main frame does't change or the explorer window opens like a pop up window.
      What do i do?!?!?!
        • 1. Re: flash cs3 bug
          Level 7
          jose_carlos,
          > When I write: [in Flash CS3]
          > on (release) {
          > it doesn't work
          The reason this doesn't work is because your document is configured to
          publish to ActionScript 3.0. This is NOT a Flash CS3 bug at all. ;) It's
          a result of the way AS3 works.
          > What do i do?!?!?!
          Either change your Publish Settings for ActionScript 2.0, or use the AS3
          approach to event handling. If you're using AS3, you'll also have to update
          getURL() to navigateToURL().
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
