0 Replies Latest reply on Aug 14, 2006 4:56 PM by VaporAction
    Need Barrier to Dragging
    VaporAction Level 1
      I need to make it so you can drop an object into a glass cylinder, however, once it's in the cylinder I don't want the user to be able to drag it out the sides of the cylinder...
      I tried creating an invisible object with which the element performed a hitTest and if true then stopDrag but the problem with that is then you could no longer drag it (sorta like it was stuck to the invisible object)...here's my code...
