0 Replies Latest reply on Jun 15, 2007 7:46 AM by adam@blueapplestudio
    Custom Component Problem
    adam@blueapplestudio Level 1
      I am creating my first component and need a bit of help.
      My component is essentially a ruler with the minimum value (left most number) and maximum value (right most number) defined in the component inspector. This way the same ruler component can be used to display 0 through 20, and 5 through 600. There are two buttons- one increments up the ruler, and the other increments down. A text field displays the current value along the ruler, and updates as the user clicks an increment or decrement button.
      The problem is that no matter what the minimum value is set to, it always starts at 0. If I set it to 1 in the component inspector, it starts at 0. I can then click on the increment button; it gets up to 1, and will then not allow it to decrement further.
      What do I need to do to force the text field to its minimum value right away?
