1 Reply Latest reply on Jun 16, 2007 2:53 PM by SymTsb
    Can't get tween to work
      I have a number of movie clips in an array that I am cycling through presenting, fading and then removing. I am attaching the clips to the mc variable mClip1. mClip1 works for everything other than the tween where it just seems to skip the instruction, If I force the actual name of the mc, then it works. Are variables handled differently with tweens? Can anyone see a problem with the line of script calling the tween that would prevent this from moving the alpha of mClip1 from 0 to 75?
        • 1. Re: Can't get tween to work
          SymTsb Level 2
          It's skipping the instruction because the movie isn't loaded yet. Rather than using loadMovie, you should use the MovieClipLoader class and call the tween from inside the onLoadComplete event handler. That will insure that you movie loads when it is finished.
