11 Replies Latest reply on Mar 14, 2011 1:56 PM by mdermez
    Speed up a tween (CS4 AS3)
    mdermez Level 1
      I have an animated fish crossing the screen. I made that using the animated fish (movieclip1) following a path on a guide layer. All these are into another movieclip (2).
      I want in mouse hover condition to accelerate the tween. In other words I want the user to point the fish with the mouse (mouse hover) and then the fish tries to escape (tween acceleration). How can I accelerate the tween?
      Keep in mind that in fish movieclip(1) I have more than one Tweens. So the code must be for selected tween (named by frame label).
      Another thing is that acceleration mustn't be directly from 0 to 1. There must be an ease on the start and on the end of acceleration so it can be more realistic.
      I am not related on programming so I would like a complete answer (not just directions)
      My thinking of the code was:
      (if it's needed I'll have to import transitions.ease and tween)
      Function for mouse hover condition
      --> inside that function I have to define (I think) another function about acceleration of the tween
      Then I have to add eventListener  for the object.
      So my main question for the code is focused on tween acceleration
        • 1. Re: Speed up a tween (CS4 AS3)
          if your tween is on a movieclip timeline, the tween will play faster if you play the movieclip timeline faster.  you can do that, within certain limits, by using a timer instance's listener function to advance the movieclip's timeline.
          • 2. Re: Speed up a tween (CS4 AS3)
            mdermez Level 1
            I find it very useful. Could you give me an example?
            • 3. Re: Speed up a tween (CS4 AS3)
              var mc_playrateChange:Movieclip;
              framerateF(mc,32,1,mc.totalFrames);
              ///   don't change below ///
              function framerateF(mc:MovieClip,framerate:int,startframe:int,endframe:int):void{
              mc_playrateChange = mc;
              mc.timer=new Timer(1000/framerate,endframe-startframe);
              mc.gotoAndStop(startframe);
              mc.timer.addEventListener(TimerEvent.TIMER,playF);
              mc.timer.addEventListener(TimerEvent.TIMER_COMPLETE,playcompleteF);
              mc.timer.start();
              function playF(e:TimerEvent):void{
              mc_playrateChange.nextFrame();
              function playcompleteF(e:TimerEvent):void{
              mc_playrateChange.timer.removeEventListener(TimerEvent.TIMER,playF);
              mc_playrateChange.timer.removeEventListener(TimerEvent.TIMER_COMPLETE,playcompleteF);
              • 4. Re: Speed up a tween (CS4 AS3)
                mdermez Level 1
                Ok let me see if I got it right. (thanks for the code)
                lets say that I have a movieClip named "thatBall". Inside that clip there is a tween for the ball. The tween is 200 frames from 1 to 200.
                And also lets say that I want the speed up to run in a mouse click condition. The button will be named "btn1"
                framerateF(mc,32,1,mc.totalFrames); ///What is 32,1??
                mc.timer=new Timer(1000/framerate,endframe-startframe); ///endframe-startframe its a variable
                mc.gotoAndStop(startframe); /////you mean mc.gotoAndStop(1); ?
                mc.timer.start();
                mc_playrateChange.timer.removeEventListener(TimerEvent.TIMER_COMPLETE, playcompleteF);
                btn1.addEventListener(MouseEvent.CLICK,???) ////what function should I put here in order to activate the tween acceleration?
                • 5. Re: Speed up a tween (CS4 AS3)
                  function framerateF(mc:MovieClip,framerate:int,startframe:int,endframe:int):vo id{
                  mc.timer.start();
                  btn1.addEventListener(MouseEvent.CLICK,f);
                  function f(e:MouseEvent):void{
                  framerateF(thatBall,32,1,200); ///What is 32,1 -> framerate and startframe
                  • 6. Re: Speed up a tween (CS4 AS3)
                    mdermez Level 1
                    function framerateF(thatBall:MovieClip,framerate:int,startframe:int,endframe:int):vo id{
                    mc.timer=new Timer(1000/32,200-1); ////200-1?? is this right?
                    thatBall.gotoAndStop(1);
                    thatBall.timer.addEventListener(TimerEvent.TIMER,playF);
                    thatBall.timer.addEventListener(TimerEvent.TIMER_COMPLETE,playcompleteF);
                    thatBall.timer.start();
                    mc_playrateChange.nextFrame(); //// must be thatBall_playrateChange.nextFrame(); or it doesnt matter?
                    Again, thanks for your time!!! I really apreciate it!!!!
                    • 7. Re: Speed up a tween (CS4 AS3)
                      don't change the code in framerateF(), playF() or playcompleteF().
                      to speed thatBall, copy and paste the code i suggested.  you can change the frame rate in your mouse listener function:
                      framerateF(thatBall,50,1,200);  //play thatBall at ~ 50fps from frame 1 to frame 200
                      • 8. Re: Speed up a tween (CS4 AS3)
                        mdermez Level 1
                        Ok my bad. I just got the whole thing.
                        I have one more question (last I hope). I still dont get it with the btn1 listener.
                        function SpeedUP(e:MouseEvent):void{
                        so the btn1 listener should be something like this? :
                        btn1.addEventListener(MouseEvent.CLICK,SpeedUP)
                        • 9. Re: Speed up a tween (CS4 AS3)
                          mdermez Level 1
                          I got this error:
                          1046: Type was not found or was not a compile-time constant: Movieclip.  var mc_playrateChange:Movieclip;
                          • 10. Re: Speed up a tween (CS4 AS3)
                            that's a typo.  it should be:
                            MovieClip
                            not
                            Movieclip
                            • 11. Re: Speed up a tween (CS4 AS3)
                              mdermez Level 1
                              Your code worked almost fine - the thing is that is worked.
                              I changed the startframe with the currentFrame command in order to run the function from the frame that its triggered. I dont wont to put limits on startframe by defining it into the code.
                              The clip starts playing normally. Normal speed. In about the middle I want to change it speed. So (according to the code)  I just have to place the cursor on the clip in order to trigger the function (it could be with the clip of a button). The thing is that everytime that the function is triggered the clip starts -not from the frame that it was triggered- but from the begggining.
                              Do you understant what I am saying? Sorry for my english!!
                              thatBall.play();
                              var mc_playrateChange:MovieClip;
                              function framerateF(mc:MovieClip,framerate:int,currentFrame:int,endframe:int):void{
                              mc.timer=new Timer(1000/framerate,endframe-currentFrame);
                              mc.gotoAndStop(currentFrame);
                              mc.timer.start();
                              function SpeedUp(e:MouseEvent):void{
                              framerateF(thatBall,50,currentFrame,400)
                              function SpeedDown(e:MouseEvent):void{
                              framerateF(thatBall,30,currentFrame,400)
                              thatBall.addEventListener(MouseEvent.MOUSE_OVER, SpeedUp);
                              thatBall.addEventListener(MouseEvent.MOUSE_OUT, SpeedDown);
                              ///function mouseOverHandler(e:Event):void{
                                 /// addEventListener(Event.ENTER_FRAME, SpeedUp);
                              ///function mouseOutHandler(e:Event):void{
                                 /// removeEventListener(Event.ENTER_FRAME, SpeedUp);
                              ///thatBall.addEventListener(MouseEvent.MOUSE_OVER, mouseOverHandler);
                              ///thatBall.addEventListener(MouseEvent.MOUSE_OUT, mouseOutHandler);
