Hello, I have this problem.
In my application i have datagrid1, and when i click on the field i create popUp, this popUp has another datagrid2 and i can add new field to it.
My problem is this: when i click on the field datagrid1 the first (i create popUp) and add new field to datagrid2 then adding only 1 field, but if i close this popUp, and click again (i create new popUp) and add new field then adding 2 fields and etc 3-4-5....
This i show some peace of code.
Here i create popUp with datagrid2:
private function targetValueCED(e:Event):void{
var popUp:TargetValueView=TargetValueView(PopUpManager.createPopUp(this,TargetValueView,true));
popUp.targetOb = targetDataGrid.selectedItem as TargetVO;
popUp.x=this.width/2 - popUp.width/2 + 40;
popUp.y=this.height/2 - popUp.height/2;
Here i create popUp for add new field:
private function newTarget():void{
var popUp:CreateEditValue = new CreateEditValue;
popUp = CreateEditValue(PopUpManager.createPopUp(this,CreateEditValue,false));
popUp.edit = false;
popUp.title = "Create new value";
popUp.ownerTarget = targetOb;
popUp.targetValueOb = new TargetValueVO();
popUp.x=this.parentDocument.parentDocument.width/2 - popUp.width/2;
popUp.y=this.parentDocument.parentDocument.height/2 - popUp.height/2;
And here i dispach event:
private function saveObject():void{
if (this.edit)
targetValueOb.data = inputName.text;
targetValueEvent=new TargetValueEvent(TargetValueControl.EDIT_TARGET_VALUE, targetValueOb, ownerTarget);
else
targetValueOb.targetId = ownerTarget.id;
targetValueEvent=new TargetValueEvent(TargetValueControl.ADD_TARGET_VALUE, targetValueOb, ownerTarget);
CairngormEventDispatcher.getInstance().dispatchEvent(targetValueEvent);
close();
And if you need my command class:
override public function execute(event:CairngormEvent):void
var delegate : TargetValueDelegate = new TargetValueDelegate(this);
try
targetValueEvent = TargetValueEvent(event);
catch(err:Error)
targetValueEvent=null;
if(targetValueEvent!=null)
myRequest = event.type;
switch(event.type)
case TargetValueControl.LOAD_TARGET_VALUE:
delegate.loadTargetValue();
break;
case TargetValueControl.ADD_TARGET_VALUE:
delegate.addTargetValue(targetValueEvent.targetValueOb);
break;
case TargetValueControl.EDIT_TARGET_VALUE:
delegate.editTargetValue(targetValueEvent.targetValueOb);
break;
case TargetValueControl.REMOVE_TARGET_VALUE:
delegate.removeTargetValue(targetValueEvent.targetValueOb)
Thanks for you help.
Hi Olga,
I'm not sure to understand correctly what is the issue you are encountering with Cairngorm listeners. Could you add a sample project or screenshots so that we can have a look?
Sorry for my post. I correct error, it was my error becouse i set controller some times.
Thanks.
