4 Replies Latest reply on Jun 26, 2007 4:55 PM by kglad
    How to get Started with Obj Oriented AS3? (Flash Help seems broken)
    CPruittCCB
      OK I dont want to be the noob that doesn't read the manual and asks stupid questions, but I'm stuck here. It's been a LONG time since I had any real flash experience (Flash 5 in depth and a little Flash 8). But now my job has lead me back into some flash work & I'm basically starting from scratch. I'm trying to just get a simple SWF to load an external class & have the class retrun a value from a method.
      I define
      package
      public class Greeter
      public function sayHello():String
      var greeting:String;
      greeting = "Hello World!";
      return greeting;
      in an .as file (which is located in the same directory as my .fla) and then in frame 1 of my time line I have:
      var myGreeter:Greeter = new Greeter();
      mainText.text = myGreeter.sayHello("Bob");
      When I try & test the movie I get 2 errors:
      1046: Type was not found or was not a compile-time constant: Greeter.
        • 1. Re: How to get Started with Obj Oriented AS3? (Flash Help seems broken)
          Level 7
          CPruittCCB,
          I'm only getting one, which is "Incorrect number of arguments. Expected
          no more than 0," and the reason for that is because the sayHello() method
          isn't set up to receive any parameters. If you change your existing ...
          ... to this ...
          public function sayHello(msg:String):String
          ... just as a for-instance, that error goes away. Have you saved both the
          FLA and the AS file? If you haven't saved your FLA yet, it won't know where
          to find your Greeter.as file (that is, the Greeter class), which would
          explain your "type not found" error.
          Check Edit > Preferences, ActionScript category, and click the
          ActionScript 3.0 Settings button to make sure your classpath setting has an
          entry with nothing but a dot (.) in it. That dot means "Look in the current
          folder" when Flash needs to start hunting for external classes. Otherwise,
          you'll have to use the import statement to let Flash know where that Greeter
          class is.
          Another thing to consider, if you're expecting to see the word "Bob" in
          the text field, is that you're not currently passing the incoming parameter
          back out of the method (because there is no incoming parameter). Something
          like this would do it:
          package {
          public class Greeter {
          public function sayHello(msg:String):String {
          greeting = "Hello, " + msg;
          return greeting;
          David Stiller
          Co-author, Foundation Flash CS3 for Designers
          http://tinyurl.com/2k29mj
          "Luck is the residue of good design."
          • 2. Re: How to get Started with Obj Oriented AS3? (Flash Help seems broken)
            1. there's no string to pass to your sayHello method
            2. you must save your Greeter class file as Greeter.as
            • 3. Re: How to get Started with Obj Oriented AS3? (Flash Help seems broken)
              CPruittCCB Level 1
              Under most circumstances I'd have been skeptical of passing an argument when none is defined however I thought I'd heard (way back around AS 2) that AS was being based on JavaScript sort of rules so I thought perhaps that didn't matter. And unfortunately, that error wasn't my typo, its actually printed that way in the built in Flash help (see: Getting started with ActionScript > Example: Creating a basic application).
              Thanks for clearing that up, although I wasn't getting the error you mentioned. The compiler never got that far before it bailed.
              quote:
              OK, this turned out to be the problem... Just on a hunch I decided to consider case. Saving the file as [greeter.as/i] errors out but [ Greeter.as/i] does not. Is Flash really case sensitive with regard to file names? At any rate I've got my bearing a little better. thanks a lot.
              • 4. Re: How to get Started with Obj Oriented AS3? (Flash Help seems broken)
                flash is almost NEVER insensitive to case.
