1 Reply Latest reply on Jun 13, 2007 1:00 PM by ntsiii
    Textinput in all the colums of the first row of datagrid
    appu19
      Hi
      i need Textinput in all the colums of the first row of datagrid.
      can ayone tell me the solution..
      Thx in advance.
        • 1. Re: Textinput in all the colums of the first row of datagrid
          ntsiii Level 3
          This will not be easy. i see two possible solutions.
          You could use a custom itemRenderer. This will require that you find some way to identify the dataProvider collection index from within the renderer, and set the renderer to editable when that index is 0.
          Or you could create a composite component using two dataGrids, one with a single row for the editable columns. There are examples available on combining two DGs this way.
          Again, this will be difficult, so be sure that it is absolutely required and consider some other UI approach if posible.
          Tracy
