Hi Guys,
I’m using RoboHelp to create HTML help. And the Help
file is for a large piece of software. Basically we have two
‘settings’ menu options: Parameters – Users and
Parameters – Parameters. And within each of these menu
options we have various tabs, each with 30 or 40 user or system
options on it. There are approximately 200 user options and 300
system options.
In my Help topics, I have hundreds and hundreds of links back
to the user and system settings. For example
If you set the
User must have depot access option (see the Parameters -
Users option and the User Options 1 tab) ……..
If you set the
Must have stock to sell option (see the Parameters –
Parameters option and the System Options 2 tab) ……..
The problem is that we are currently in the process of
changing the layout of the system and user options (so that you can
see the options in tree view instead of on tabs), and this includes
changing the name of each option to make it immediately apparent
what each option is (using full words in the option name rather
than abbreviations, and so on).
So, suddenly,
ALL the option names are changing, and they’re not on
tabs anymore, they’re in sections.
If all the names were being changed but were still on the
same tabs, I could do a multi-file ‘find and replace’
on the options – still fairly time-consuming, but not too
bad. But because both name and layout (section not tab) are
changing, I’m going to have to go through 600 help topics and
manually update each and every link to a user or system option.
What I need is some sort of mechanism where I can assign an
ID and its text to each system and user option and then use the ID
for a link. For example, perhaps create a table listing the user
and system options:
id = uo1
text = User can add hire item to a contract user option (see
the Hire Contract options)
id = u02
text – User can add hire item to a sales order user
option (see the Sales Order options)
and so on
And then for a link from a topic back to the option:
…. if you need to do this, set the (id=uo1).
And then when I build the Help file, each ID is replaced with
the text for the option.
Hopefully I’ve explained this reasonably clearly. Any
suggestions would be gratefully received.
Nicky
