0 Replies Latest reply on Jun 13, 2007 7:01 AM by JM@FEDEX
    Wily Introscope settings for ColfFusion application
    JM@FEDEX
      I implemented Wily Introscope to monitor a ColdFusion application on a HP-UX server using 1.4.2.05 HP Hotspot JVM.
      1) Introscope settings (probes) reference Java classes and methods. By using the ..../WEB-INF/cfclasses, the only metrics I succeeded to set are, for instance;
      TraceOneMethodOfclass cfDispatcher2ecfc1427029379 _factor0 MethodTimer "...."
      where the reference to the method is "_factor<n>".
      Is there a way to associate this "_factor<n>" method name
      with a real function defined with <cffunction> tag into the CFML page source ?
      Otherwise I obtain a list of "_factor<n>" method names into the Introscope Workstation view, without to be able to associate each one with the relevant CFML page source function name.
      2) In addition, is there a way to instrument the Java class
      java.lang.runtime (for the method getruntime) ? This is called from ColdFusion page with this code:
      <cfscript>
      rt = createObject("java","java.lang.Runtime").getRuntime();
      </cfscript>
      I tried
      SetFlag: InstanceCounts
      IdentifyClassAs: java.lang.Runtime InstanceCounts
      TraceOneMethodIfFlagged: InstanceCounts getRuntime SimpleInstanceCounter "...."
      and then after unsuccess, I tried
      TraceOneMethodOfclass java.lang.Runtime getruntime MethodTimer "..."
      But it did not succeed, no metric appearing in the Workstation view after page call.
      Do you have any any idea ?:confused;
