For the case where custom typed ActionScript objects are
being used but are
seen as anonymous Objects by the receving application, the
following causes
may be the issue:
1. You don't have the correct [RemoteClass] metadata on your
custom AS3 classes.
2. You have the correct metadata, but you haven't imported
and referenced
the custom AS3 class anywhere in your application so it
wasn't linked into
the SWF and thus isn't available at runtime.
3. You've decided to register a class alias yourself via the
low-level flash.net.registerClassAlias()
function but this wasn't called before a remote instance of
the type was
received.
For the case where your message.body isn't of the type you'd
expect, like
Array or ArrayCollection - that's a little tricker to say why
in the AS-to-AS
(via message service) case. If ClientA creates an Array then
on the server
that will be an Object[] and thus sent to ClientB as an AMF 3
Array. If,
however, the server were to generate it's own collection
type, say java.util.ArrayList,
remember that that would appear as an
mx.collections.ArrayCollection back
in the Flex client and Array and
mx.collections.ArrayCollection cannot be
directly cast to one another. I don't think this latter
scenario is what
is happening here as your client is the one creating the body
of the message.
You should consider turning on Debug level logging in
/WEB-INF/flex/services-config.xml
and ensure that the ConsoleTarget has a filter to watch for
Endpoint.* to
see just what exact AMF type is being received and sent by
the MessageBroker
in FDS.
Pete
Hello FerrieJB,
> Hi,
> I'm a fairly experienced developer of Flex2 and FDS but
just now I've
> hit a snag I can't seem to resolve on my own.
> I'm using RTMP messaging to send Actionscript objects
from one Flex
> app to another, both running at the same time on the
same server,
> subscribed to the same destination and subtopic.
> The objects are sent in the AsyncMessage.body part, just
as many
> tutorials and training manuals use in their examples.
> The received data is handled by a function that read the
> MessageEvent.message.body which is typed as Object.
> The examples by Adobe always show how this property can
simply be
> cast back into its original type like this for instance:
> var myCollection:ArrayCollection = event.message.body as
> ArrayCollection
> Also it's noted that the body property of the
AsyncMessage object can
> hold any Object, built-in Flex component or custom
ActionScript object
> and that these can also be cast back into their original
types.
> Now I have written several custom AS3 classes, object
instances of
> which need to be sent to a messaging destination just
like this, only
> it won't work...
> The event.message.body does contain the information,
typed as an
> Object. That seems to work and all data is there, even
of the most
> complicated classes, but as soon as I cast this result
back into int
> original type using the keyword "as" it only returns
"null" (which,
> according to Flex documentation, happens when the left
expression is
> not an instance of the class right of the keyword). So
someway or
> another during serialization and deserialization my
datatype is lost.
> It's fairly easy to reproduce in an isolated Flex app.
At these two
> links are MXML files I used to reproduc the same
behaviour using a
> simple Array object. Now that should really give no
problem, but is
> seems it does! If I send String or Date it works fine
and I am able to
> cast it back in to their original types no problem. But
Array is
> broken?!
http://gozo.infoprofs.nl/ferrie/testA.mxml>
http://gozo.infoprofs.nl/ferrie/testB.mxml> Has anyone had any experience like this? Am I missing
something?
> Please help, I'm in the middle of a big project and this
comes at a
> most unfortunate time during development, so help would
be really
> appreciated.
> Thanks,
> Ferrie Bank
