3 Replies Latest reply on Mar 14, 2011 9:37 AM by JSS1138-N9wM26
    1080 50p and 25p workflow
    inertiahz Level 1
      Hi, I was after a bit of advice on how to use 1080 50p and 1080 25p footage.
      To give a bit of background, in my kit I have a Canon Legria HF21 and recently a Panasonic HDC-HS700, most of the content I film is interview / office based scenes which are then usually exported as 1280 x 720 25p in WMV and sometimes 768 x 432 F4V for web display.
      So the question is would it be best to set both cameras to record at 1080 50i or in there respective 25p and 50p then let Premiere sort out the differences?
      I have done some tests dropping the 50p footage onto a 25p sequence which seems to output fine in a 1280 x 720 25p WMV file, however I am unsure of what process Premiere is using to adjust the frame rate of the 50p footage, is it simply dropping every other frame?
      Any advice would be appreciated.
      Cheers.
