0 Replies Latest reply on Mar 14, 2011 2:42 PM by gunalexia
    Air and Java Integration
    gunalexia
      I am developing an air application,
      below is my JavaProcess.mxml
      <s:WindowedApplication
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="
      library://ns.adobe.com/flex/spark"
      xmlns:mx="
      library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
      creationComplete="windowedapplication1_creationCompleteHandler(event)"
      <fx:Script>
      <![CDATA[
      import mx.events.FlexEvent;
      import mx.controls.Alert;
      protected var process:NativeProcess;
      protected function windowedapplication1_creationCompleteHandler(event:FlexEvent):void
      var info:NativeProcessStartupInfo = new NativeProcessStartupInfo();// holds all info about native process
      info.executable =
      new File("C:/program files/java\/jre1.6.0_22/bin");
      //window program files/java
      info.workingDirectory= File.applicationDirectory;
      var args:Vector.<String> = new Vector.<String>();
      args.push(
      "-cp","../bin","net.Main");
      info.arguments =args;
      process =
      new NativeProcess();
      process.addEventListener(ProgressEvent.STANDARD_OUTPUT_DATA,onDataOutput);
      process.start(info);
      private function onDataOutput(event:ProgressEvent):void
      var message:String = process.standardOutput.readUTFBytes(process.standardOutput.bytesAvailable);
      Alert.show(message);
      </fx:Script>
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <s:Button label="call java" click="process.standardInput.writeUTFBytes('hello\n')"/>
      </s:WindowedApplication>
      and here is the Main.java
      package
      net.riaspace;
      import
      java.util.Scanner;
      public
      class Main {
      @param args
      public static void main(String[] args) {
      // TODO Auto-generated method stub
      String input;
      Scanner scanner =
      new Scanner(System.in);
      while(scanner.hasNext("Hello|stop"))
      input = scanner.next();
      if(input.equals("hello"))
      System.
      out.println("Hello Flex");
      else if(input.equals("stop"))
      return;
      I saw the above code from "riaspace"
      " video . I am working on windows machine and the above code doesnot work. The error I am getting is "ArgumentError: Error #3214: NativeProcessStartupInfo.executable does not specify a valid executable file" ,
      the path to java executable file I tried are
      1. new File("C:/program files/java/jre1.6.0_22/bin");
      2. new File("C:/program files/java/jre1.6.0_22/bin/java.exe");
      3.new File("C:/windows/system32");
      4.new File("C:\\program files\\java\\jre1.6.0_22\\bin");
      nothing works... anyone pls help.. Thanks in advance.
      My project workspace is " c:\Documents and settings\username\MyDocuments\MainFolder"  , may be that changes?
