6 Replies Latest reply on Mar 15, 2011 9:42 AM by Flex harUI
    Focus Problem
    huangxinghui
      code:
      <mx:TitleWindow xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" width="400" height="300">
       <mx:Form>
        <mx:FormItem label="name:">
         <mx:TextInput/>
        </mx:FormItem>
       </mx:Form>
      </mx:TitleWindow>
      when i click the textinput, then i can not focus out
      see the FocusManager source code, find this:
           *  @private
          private function getTopLevelFocusTarget(o:InteractiveObject):InteractiveObject
              while (o != InteractiveObject(form))
                  if (o is IFocusManagerComponent &&
                      IFocusManagerComponent(o).focusEnabled &&
                      IFocusManagerComponent(o).mouseFocusEnabled &&
                      (o is IUIComponent ? IUIComponent(o).enabled : true))
                      return o;
         // if we cross a boundry into a bridged application, then return null so
         // the target is only processed at the lowest level
         if (o.parent is ISWFLoader)
          if (ISWFLoader(o.parent).swfBridge)
           return null;
                  o = o.parent;
                  if (o == null)
                      break;
              return null;
      can not set titlewindow focus in
      how to click other area except textinput to publish focus out event?
      Thanks a lot!
        • 1. Re: Focus Problem
          Flex harUI Adobe Employee
          Add a close or ok/cancel button(s)
          • 2. Re: Focus Problem
            huangxinghui Level 1
            Thanks, alex
            but i want click the blank area to publish focus out event
            because i set a validator on the textinput
            <mx:StringValidator source="{textInput}" property="text" triggerEvent="focusOut"/>
            • 3. Re: Focus Problem
              I'm unclear how someone will close the TitleWindow.  Using the close button
              is a bit less usable because it is a small target and it isn't obvious what
              will happen when you click it.  Will it be the equivalent of "ok", "cancel"
              or will you get another dialog?
              So putting in buttons might be the best option.
              However, if you really must validating on clicking in the blank area, I
              would simply call the validator on CLICK if it didn't happen in the
              TextInput.
              • 4. Re: Focus Problem
                sorry, the titlewindow we set showCloseButton=true, this is only a example
                showCloseButton="true" close="closeHandler()" click="clickHandler(event)">
                <mx:Form>
                   <mx:TextInput/>
                  </mx:FormItem>
                 </mx:Form>
                <mx:Script>
                  <![CDATA[
                   import mx.managers.PopUpManager;
                   private function closeHandler():void
                    PopUpManager.removePopUp(this);
                   private function clickHandler(event:MouseEvent):void
                    trace("Focus=" + focusManager.getFocus());
                 </mx:Script>
                </mx:TitleWindow>
                then when focus out the textinput, we will call service to check input string is valid or not, so can not use button to check.
                Thanks for your reply
                • 5. Re: Focus Problem
                  so i extend the titlewindow add this code:
                  public function EnhancedTitleWindow()
                     super();
                     showCloseButton = true;
                     addEventListener(MouseEvent.MOUSE_DOWN, mouseDownHandler);
                  private function mouseDownHandler(event:MouseEvent):void
                     if (event.isDefaultPrevented())
                        return;
                     if (event.target == this)
                        this.setFocus();
                  give me some suggestions, Thanks a lot
                  • 6. Re: Focus Problem
                    I think I would just check if the TextInput contains the event.target and if
                    not, then call the validation method.
