I have designed an e-form using Livecycle Designer.In this form there is a warning image (a small yellow triangle above every field) which is displayed, if the user enters incorrect data for that field, after saving the form.For this, I have called a standard function on presave event of the individual fields.This functionality is working fine.But the issue is suppose for any two fields if I enter incorrect data in second field and correct data in first field so after saving the form the warning image is displayed on the second field.Now if I interchange the values just for the first instance after saving the form the warning image is not getting displayed on the first field.If I make some changes in the form or even if I do nothing just click on a field and exit from it without entering any text and save the form the warning image is displayed.
This defect has been reported from my testing team and I have to close it as soon as possible. Kindly look into this issue and help me in resolving it.
Please find below the code for standard function:-
function
validateMixFields(field,imageField)
if (!((field.rawValue == null)||(field.rawValue == "")))
// Create a new Regular Expression Object.
// Set the regular expression to look for fields in general form.
var checkExpression = new RegExp("^[^<>=\"'`]*$");
// Test the rawValue of the current object to see if it fits the general format
var result = checkExpression.test(field.rawValue);
// If it fits the general form
if (result == true) {
imageField.rawValue
imageField.access
= "protected";
// all is well.
true; }
else
// fail the validation.
imageField.rawValue
= global.imagefield;
global.count
imageField.access
= "protected";
else
imageField.rawValue
imageField.access
= "protected";
~Views
Total Likes
