5 Replies Latest reply on Mar 18, 2011 2:24 PM by rtalton
    How to style form labels?
    cut-copy-paste Level 1
      I'm using a (mx) form and I see absolutely no way to style the labels for the fields.  Is this for real? There has got to be a way...
        • 1. Re: How to style form labels?
          Raghuvasa Level 1
          We can override the styles by using external css file
          • 2. Re: How to style form labels?
            Can I style only the labels with CSS?
            I have applied styles to the formItems and it affects everything so I have to reset styles of everything else in the form which is not ideal.
            • 3. Re: How to style form labels?
              Angela's ARIA
              Hi cut-copy-paste,
              If you have a form similar to this:
                   <mx:Form>
                        <mx:FormItem label="Name :"                          styleName="formTitle">
                             <mx:TextInput id="senderName" />
                                   </mx:FormItem>
                        <mx:FormItem label="Email :"                          styleName="formLabel">
                             <mx:TextInput id="senderEmail" />
                        </mx:FormItem>
                   </mx:Form>
              You can link to a style sheet:
                   <fx:Style source="content-text-style.css"/>
              Where you can apply styles to the form components by naming them or naming classes that are applied to the components:
                   @namespace mx "library://ns.adobe.com/flex/mx";
                   mx|FormItem { fontSize: 10; }
                   mx|TextInput { fontSize: 12; }
                   mx|Button { fontSize: 12; }
                   .formTitle { fontSize: 20; }
                   .formLabel { fontSize: 12; }
              As the mx:TextInput component is placed within the mx:FormItem component  this may cause the style to be inherited.  Try specifying the styles  you want to apply to the mx:TextInput also.
              I hope that you find this helpful.
              Angela's ARIA
              Accessible Rich Internet Application
              • 4. Re: How to style form labels?
                I was aware you could use class names etc, yeah.
                I guess basically the answer is that you can't style the labels independently of the things that they contain, which is too bad.
                • 5. Re: How to style form labels?
                  rtalton Level 4
                  You were sooo close!
                  On your FormItem, simply set the "labelStyleName" property, NOT the "styleName".
                  /* CSS file */
                  Label.frmItemLabelSyle
                  color: #FF4800;
                  fontSize: 12;
                  <mx:Application
                  xmlns:mx="http://www.adobe.com/2006/mxml"
                  layout="
                  absolute">
                  <mx:Form
                  width="
                  300"
                  height="
                  100"
                  y="
                  50"
                  x="
                  50">
                  <mx:FormItem
                  label="
                  First Name"
                  labelStyleName="
                  frmItemLabelSyle">
                  <mx:TextInput/>
                  </mx:FormItem>
                  </mx:Form>
                  <mx:Style source="styles.css"/>
                  </mx:Application>
