3 Replies Latest reply on Mar 15, 2011 11:43 PM by Ten A
    textFrame.frameFittingOptions in indesign cs5
    frekfeng
      Hi:
         In indesign cs4, it works with textFrame.frameFittingOptions,
         but in indesign cs5 it said: Object does not support the property or method 'frameFittingOptions'
         Does anybody knows what i have to change to let it work in CS5?
         Thanks in advance.
        • 1. Re: textFrame.frameFittingOptions in indesign cs5
          Ten A Adobe Community Professional
          Hi, try below code.
          app.activeDocument.selection[0].fit(FitOptions.FRAME_TO_CONTENT);
          You can read "fitOptions" in OMV for more detail.
          Still, we are ALIVE...
          Ten wrote
          • 2. Re: textFrame.frameFittingOptions in indesign cs5
            frekfeng Level 1
            How can I set topCrop of frameFittingOptions
            In Indesign CS4
                 textFrame.frameFittingOptions.topCrop = '10'.
            How Can I do this in Indesign CS5?
            • 3. Re: textFrame.frameFittingOptions in indesign cs5
              You have to change frames contentType, when you want to set frameFittingOptions.
              textFrames[0].contentType = ContentType.graphicType;
              But script system can't detect change objects contentType.
              However, we can use getElements method.
              myFrame = app.activeDocument.textFrames.add();
              myFrame.contentType = ContentType.graphicType;
              myFrame.getElements()[0].frameFittingOptions.topCrop = 10;
              I think that put image into frame, using rectangle is better way.
              //sample, Image placement test
              //crop top and left
              var pageobj = app.activeDocument.pages[0];
              var imgobj = pageobj.rectangles.add();
              imgobj.visibleBounds = [0,0,200,200];
              f = new File ("~/test.eps");
              imgobj.place(f);
              imgobj.frameFittingOptions.leftCrop = 10;
              imgobj.frameFittingOptions.topCrop = 10;
              imgobj.fit(FitOptions.APPLY_FRAME_FITTING_OPTIONS);
              Ten wrote
