0 Replies Latest reply on Mar 15, 2011 8:37 AM by Srini, uppu
    QTP Automation Testing of Flex 4 application using Runtime Shared Libraries(RSL)
    Srini, uppu
      Based on the research and a small POC the we performed, they realized that the  shared libraries must be either in swf or swz format. The application doesn't  load the swc format files, which are the only available QTP library formats  handy.
      .       Feasibility of RSL with the QTP automation  libraries:
      We tried searching around if there QTP automation libraries  available either in swf/swz and also tried looking around discussion forums to  see if the source code is available to compile it to the required formats.  However, as none of those were available handy, the RSL based mechanism to  dynamically load the necessary libraries couldn't be performed.
