1. Re: I keep getting this message
John T Smith Mar 16, 2011 8:34 AM (in response to Phillycop76)1 - Reader has a different forum http://forums.adobe.com/community/adobe_reader_forums
2 - Bad results from emailing a PDF is a problem with how email software "sees" a PDF, and how the document is then prepared to be sent over the Internet
Short version... email software encodes all attachements for transmission... a PDF is incorrectly "seen" as a text file, and the wrong encoding method is used... the file is then garbled upon receipt
Solution... ZIP all PDF files before sending via email
2. Re: I keep getting this message
Phillycop76 Mar 16, 2011 8:38 AM (in response to John T Smith)Thanks, I'll give it a try.
3. Re: I keep getting this message
~graffiti Mar 16, 2011 8:39 AM (in response to John T Smith)John T Smith wrote:
Alternately, you could post to a web space somewhere and email a link to the PDF.
4. Re: I keep getting this message
Lucien Schilling Mar 17, 2011 3:45 AM (in response to John T Smith)Email software does not alter the content of attachements even while coding the attachement to something "transportable". The e-mail progrom on the other side decodes the coded file and presents it correctly. I never had problems with that, even on different machines and OS. Zipping wouldn't help in this case. I suppose the files are not PDF files. PDF files bear a signature at the beginning of the data stream, you can open the PDF file in a text editor to check that signatue (Word, notepad or any other editor). The signature reads like %PDF-1.X. X is the PDF subversion number.
5. Re: I keep getting this message
~graffiti Mar 17, 2011 5:54 AM (in response to Lucien Schilling)Lucien Schillung wrote:
Hmmm.
Not sure why it's been an ongoing problem for many years and Zipping the file works 90% of the time then.
