2 Replies Latest reply on Mar 17, 2011 5:17 AM by nikos101
    Timeout Occurred before expected event for simple SequenceRunner
    nikos101 Level 2
      I'm having trouble with these tests. I'm always getting Timeout Occurred for my sequence in the test testOnLogout.
      Any ideas?
      Timeout Occurred before expected eventTimeout Occurred before expected event
      Error: Timeout Occurred before expected event
          at org.flexunit.internals.runners.statements::ExpectAsync/handleAsyncTimeOut()[E:\hudson\job s\FlexUnit4-Flex4.1\workspace\FlexUnit4\src\org\flexunit\internals\runners\statements\Expe ctAsync.as:319]
          at flash.events::EventDispatcher/dispatchEventFunction()
          at flash.events::EventDispatcher/dispatchEvent()
          at org.flexunit.async::AsyncHandler/handleTimeout()[E:\hudson\jobs\FlexUnit4-Flex4.1\workspa ce\FlexUnit4\src\org\flexunit\async\AsyncHandler.as:169]
            package tests.view
          import flexunit.framework.Assert;
          import mx.events.FlexEvent;
          import org.flexunit.async.Async;
      import org.fluint.sequence.SequenceRunner;
      import org.fluint.sequence.SequenceSetter;
          import org.fluint.sequence.SequenceWaiter;
          import org.fluint.uiImpersonation.UIImpersonator;
          import views.LoginForm;
          public class TestLoginForm
              private var view:LoginForm;
              [Before(async,ui)]
              public function setUp() : void
                  view = new LoginForm;
                  Async.proceedOnEvent( this, view, FlexEvent.CREATION_COMPLETE, 600 );
                  UIImpersonator.addChild( view );
              [After(async,ui)]
              public function tearDown():void
                  UIImpersonator.removeChild( view );
                  view = null;
              [Test(async, ui)]
              public function testOnLogout():void {
                  var passThroughData:Object = new Object();
                  passThroughData.username = 'test';
                  passThroughData.password = 'test';
                  passThroughData.selectedIndex = 0;
                  var sequence:SequenceRunner = new SequenceRunner( this     );
                  sequence.addStep( new SequenceSetter( view.username, {text:passThroughData.username} ) );
                  sequence.addStep( new SequenceWaiter(view.username, FlexEvent.VALUE_COMMIT, 400 ) );
                  sequence.addStep( new SequenceSetter( view.password, {text:passThroughData.password} ) );
                  sequence.addStep( new SequenceWaiter( view.password, FlexEvent.VALUE_COMMIT, 400 ) );
                  sequence.addStep( new SequenceSetter( view.domain, {selectedIndex:passThroughData.selectedIndex} ) );
                  sequence.addStep( new SequenceWaiter( view.domain, FlexEvent.VALUE_COMMIT, 400 ) );
                  view.onLogout();
                  sequence.addAssertHandler( handleOnLogout, passThroughData );
                  sequence.run();
              protected function handleOnLogout( passThroughData:Object ):void {
                  Assert.assertEquals(
                      view.username.text,passThroughData.username,
                      view.password.text,passThroughData.password,
                      view.domain.selectedIndex,passThroughData.selectedIndex);
        • 1. Re: Timeout Occurred before expected event for simple SequenceRunner
          mlabriola Level 4
          So, I am taking a guess here that what you want is the onLogout() call to happen as part of the sequence. But this is not what your code does. Sequences are defined and then run when you call the run() method.
          Here you are calling the onLogout method in the middle of defining the sequence.. then sometime later (likely after the logout is done) your sequence begins waiting for things to happen... and times out because nothing is happening.
          I think what you want here is to use the SequenceCaller class to actually execute the onLogout as part of the sequence.
          Mike
          • 2. Re: Timeout Occurred before expected event for simple SequenceRunner
            nikos101 Level 2
            thx mike, you mean like this: I'm still getting timeouts
                [Test(async, ui)]
                    var sequence:SequenceRunner = new SequenceRunner(this);
                    sequence.addStep(new SequenceSetter(view.username, {text:passThroughData.username}));
                    sequence.addStep(new SequenceWaiter(view.username, FlexEvent.VALUE_COMMIT, 400));
                    sequence.addStep(new SequenceSetter(view.password, {text:passThroughData.password}));
                    sequence.addStep(new SequenceWaiter(view.password, FlexEvent.VALUE_COMMIT, 400));
                    sequence.addStep(new SequenceSetter(view.domain, {selectedIndex:passThroughData.selectedIndex}));
                    sequence.addStep(new SequenceWaiter(view.domain, FlexEvent.VALUE_COMMIT, 400));
                    sequence.addStep(new SequenceCaller(view,view.onLogout ));
                    sequence.addAssertHandler(handleOnLogout, passThroughData);
                    sequence.run();
            FYI
                public function onLogout():void
                            username.text = '';
                            password.text = '';
                            domain.selectedIndex = 0;
