5 Replies Latest reply on Mar 17, 2011 3:39 PM by Ned Murphy
    Countdown Timer
    adzaus
      just want to know if some one can help me with my countdown timer.
      every time it gets to zero it goes back to 59:59:59:59.
      i need it to stay at 00:00:00:00 or even better make it flash.
      var thisYear:Number = 2011;
      var thisDay:Number = 28;
      var thisMonth:Number = 2;
      var thisHours:Number = 19;
      var thisMin:Number = 30;
      var thisSec:Number = 0;
      var countdownXML:XML = new XML();
      countdownXML.ignoreWhite = true;
      countdownXML.load( 'countdown.xml' );
      countdownXML.onLoad = function( success:Boolean ):Void
      var nowDate:Date = new Date();
      if( success ) {
           var eventDateData = countdownXML.childNodes[0].childNodes;
        if( eventDateData[0].attributes['year'] ) thisYear = Number( eventDateData[0].attributes['year'] );
        if( eventDateData[0].attributes['month'] ) thisMonth = Number( eventDateData[0].attributes['month'] );
        if( eventDateData[0].attributes['day'] ) thisDay = Number( eventDateData[0].attributes['day'] );
        if( eventDateData[0].attributes['hours'] ) thisHours = Number( eventDateData[0].attributes['hours'] );
        if( eventDateData[0].attributes['minutes'] ) thisMin = Number( eventDateData[0].attributes['minutes'] );
        if( eventDateData[0].attributes['seconds'] ) thisSec = Number( eventDateData[0].attributes['seconds'] );
        var testEventDate = new Date(thisYear, thisMonth-1, thisDay, thisHours, thisMin, thisSec );
        if( testEventDate <= nowDate ) {
         thisYear = nowDate.getUTCFullYear();
         thisDay = nowDate.getUTCDate() + Math.round( Math.random() );
         thisMonth = nowDate.getUTCMonth();
         thisHours = nowDate.getHours();
         thisMin = nowDate.getMinutes();
         thisSec = nowDate.getSeconds();
      } else {
        thisDay = nowDate.getUTCDate();
      startCountdown();
      function startCountdown():Void
      eventDate = new Date(thisYear, thisMonth-1, thisDay, thisHours, thisMin, thisSec );
      this.onEnterFrame = update;
      function update():Void
      //Current time
      var now:Date = new Date();
      var timeLeft:Number = eventDate.getTime() - now.getTime();
      //Converting the remaining time into seconds, minutes, hours, and days
      var seconds:Number = Math.floor(timeLeft / 1000);
      var minutes:Number = Math.floor(seconds / 60);
      var hours:Number = Math.floor(minutes / 60);
      var days:Number = Math.floor(hours / 24);
      //Storing the remainder of this division problem
      seconds %= 60;
      minutes %= 60;
      hours %= 24;
      updateCounters( days, hours, minutes, seconds );
      function updateCounters( numDays, numHours, numMin, numSec ):Void
      days.gotoAndPlay( 'to' + numDays );
      hours.gotoAndPlay( 'to' + numHours );
      min.gotoAndPlay( 'to' + numMin );
      sec.gotoAndPlay( 'to' + numSec );
      if some could help that would be great.
      Regards,
      Adam
        • 1. Re: Countdown Timer
          You could try adding a conditional after you call the updateCounters function in your update function...
          if(days == 0 && hours == 0 && minutes == 0 and seconds == 0){
                 delete this.onEnterFrame;
          • 2. Re: Countdown Timer
            adzaus Level 1
            is this where abouts i should be putting it becuase i am still having the same problem
            // first get this current year so this example
            // remains valid for some time to come
            if( success ) {
               thisDay = nowDate.getUTCDate() + Math.round( Math.random());
            } else {
              thisDay = nowDate.getUTCDate() + 30;
              thisMonth = nowDate.getUTCMonth() + 1;
            startCountdown();
            //Current time
            seconds %= 60;
            minutes %= 60;
            hours %= 24;
            delete this.onEnterFrame;}
            Date: Wed, 16 Mar 2011 20:27:52 -0600
            To: a_ollerton@live.com.au
            Subject: Countdown Timer
            • 3. Re: Countdown Timer
              Yep.  Maybe the problem lies in whatever you are doing with the counters.
              • 4. Re: Countdown Timer
                adzaus Level 1
                oh ok. would i be able to send you a zip folder that containes the .fla and .xml files if so please send me a email to a_ollerton@live.com.au. i have been trying to fix this for a while.
                Or
                Should i tell it to load a photo when it reaches zero.
                • 5. Re: Countdown Timer
                  You should look into what is happening with the counters.  How are those designed?  What would they be playing when they gotoAndPlay("to"+...)?  If they only go to a particular frame, and don't really play anything, then maybe you should try using gotoAndStop(...) instead
