7 Replies Latest reply on Mar 22, 2011 2:06 AM by ckdkdkdlkdjfkljlkmvjklj
    Databinding
      Hi !
      I read the documentation about databinding but I still encounter some problems in my application..
      The actionscript class looks like this (Only kept the important parts) :
           [Bindable]
           public class Alarm
                     public var _tag:String;
                     public var _limits:ArrayCollection;
                      public function Alarm() {}
                public function loadAlarm(name:String) : void {
                          this.tag = name;
                          this.limits = new ArrayCollection([
                                    new Limit ("HH", 10),
                                    new Limit ("HI", 9),
                                    new Limit ("LL", 3),
                                    new Limit ("LO", 3.5)
      Now when I load my application there is no information displayed because of the empty constructor off course.
      When I then call the loadAlarm function with a button at runtime. The limits are displayed in a DataGrid
      but the tag stays empty...
      Both _tag and _limits have getters and setters and they are also public.
      I have putted a trace in the setter and getter of _tag and the function is called and the correct name is put into the tag
      so the value definitely changes !
      Here is are the mxml snippets :
           <fx:Script>
                <![CDATA[
                     import model.Alarm;
                     import mx.binding.utils.BindingUtils;
                     import mx.controls.Text;
                     import mx.events.ListEvent;
                     [Bindable]
                     private var myAlarm:Alarm = new Alarm();
                     public function onClick(evt:Event):void
                          myAlarm.loadAlarm("newName");
                          trace(myAlarm._tag);
           </fx:Script>
      <mx:DataGrid width="147" height="306" id="alarmColumns" dataProvider="{myAlarm.limits}">
           <mx:columns>
           <mx:DataGridColumn id="alarms" headerText="Alarm" dataField="name"/>
           <mx:DataGridColumn id="limits" headerText="Limit" dataField="value"/>
           </mx:columns>
      </mx:DataGrid>
      <s:List width="167" height="306" id="alarmlist" selectedIndex="0" enabled="true">
           <mx:ArrayCollection>
                <fx:String>{myAlarm.tag}</fx:String>
           </mx:ArrayCollection>
      </s:List>
      I really don't get why limits is changed but tag is not... Also the trace outputs the "newName" so it is definitely set !
      Many Thanks !
        • 1. Re: Databinding
          ckdkdkdlkdjfkljlkmvjklj Level 1
          myAlarm.loadAlarm("newName") => quotes missing because of syntax highlighting
          • 2. Re: Databinding
            huangxinghui
            why not use myAlarm._limits?
            <mx:DataGrid width="147" height="306" id="alarmColumns" dataProvider="{myAlarm._limits}">
            or change Alarm definition
            import mx.collections.ArrayCollection;
            [Bindable]
            public class Alarm
                        this._tag = name;
                public function get limits():ArrayCollection
                 return this._limits;
                public function set limits(value:ArrayCollection):void
                 this._limits = value;
            hope help for you
            • 3. Re: Databinding
              This does not matter actually, the limits are updated when I "load" the alarm so
              that is not the issue. It is the tag that does not change at runtime.
              • 4. Re: Databinding
                huangxinghui Level 1
                sorry, i misunderstand.
                the code change like this:
                    myAlarm.loadAlarm(newName);
                    var arr:ArrayCollection = ArrayCollection(alarmlist.dataProvider);
                    arr.itemUpdated(arr.getItemAt(0));
                use itemUpdated method to update the view
                • 5. Re: Databinding
                  Hi !
                  First of all thanks, this indeed works fine !
                  But..
                  I also have some charts and components that have to
                  be updated to. Now I can fix some of them with the solution you gave me.
                  But to put everything in a ArrayCollection, is that really the best way ? Because it
                  looks to me like a work around
                  Maybe I can make an itemUpdated method for my actionscript object ?
                  Also some of the dataProviders are functions of my object that return arrays or custom objects..
                  You can not change them into an ArrayCollection (compiler complained) so for those things, the solution does not work.
                  • 6. Re: Databinding
                    may be you should not use binding, just set the dataProviders directly
                    http://livedocs.adobe.com/flex/3/html/help.html?content=databinding_8.html
                    explain
                    the bindable metatag
                    hope help for you
                    2011/3/18 ckdkdkdlkdjfkljlkmvjklj <forums@adobe.com>
                    Hi !
                    But..
                    Because it
                    • 7. Re: Databinding
                      I fixed the issue by making the loadAlarm function a static one that returns a new Alarm object, instead of just changing the Alarm object. Because then the address of myAlarm remains the same so the dataBinding does not generates the necessary events..
                      Many thanks for the ideas !
