4 Replies Latest reply on Mar 18, 2011 3:28 AM by solapola
    Flex PrintJob
    solapola
      Hi!
      I have a problem with the PrintJob and fitting the pages to the A4 size.
      I add to the PrintJob a list of objects and for presentation I use the PrintDataGrid, using only a column and inside a spark List component. I attach the example:
      private function doPrint(event:FlexEvent = null):void
      var printJob:FlexPrintJob = new FlexPrintJob();
      if (printJob.start())
      printJob.addObject(taskListView, FlexPrintJobScaleType.NONE);
      printJob.send();
      <mx:PrintDataGrid  id="taskListView" dataProvider="{hostComponent.taskList}" borderVisible="false" width="100%" >
      <mx:columns>
      <mx:DataGridColumn itemRenderer="com.tecfa.tseo.theme.tecfa.editor.print.PrintTaskItemRenderer" />
      </mx:columns>
      </mx:PrintDataGrid >
      The PrintTaskItemRenderer is a s:ItemRenderer with spark components.
      The thing is "sizeToPage" attributte is not working, anyone had solve this problem, or I have to use only PrintDataGrid and no components inside?
      Thank you
        • 1. Re: Flex PrintJob
          Flex harUI Adobe Employee
          Does the renderer correctly report its measuredWidth?
          • 2. Re: Flex PrintJob
            solapola Level 1
            Yes, the width it's ok
            I think the problem is with the ItemRenderer and is not fitting the objects in the pages, the objects are appearing cutted when a page finish ..
            Thats my Item Renderer, and I hacve another ItemRenderer Inside, maybe too much for Flex print?
            Thanx
            <s:MXDataGridItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                            xmlns:mx="library://ns.adobe.com/flex/mx"
            xmlns:component="com.tecfa.tseo.common.component.*">
            <fx:Metadata>
            [ResourceBundle("editor")]
            </fx:Metadata>
            <fx:Script>
            <![CDATA[
            import com.tecfa.tseo.theme.tecfa.graphic.icon.*;
            import mx.controls.listClasses.IListItemRenderer;
            </fx:Script>
            <!-- Main content -->
            <s:VGroup>
            <s:HGroup horizontalAlign="left">
            <s:Label width="40" text="{resourceManager.getString('editor', 'printView.id')}"/>
            <s:Label width="60" text="{resourceManager.getString('editor', 'printView.state')}"/>
            <s:Label width="40" text="{resourceManager.getString('editor', 'printView.page')}"/>
            <s:Label width="100" text="{resourceManager.getString('editor', 'printView.category')}"/>
            </s:HGroup>
            <s:Label width="40" text="{data.id}"/>
            <s:Group width="60">
            <component:IconButton iconUp="{ViewUnreadPenfingFeedback}"
              visible="{data.state=='UNREAD'}"/>
            <component:IconButton iconUp="{ViewPendingFeedback}"
              visible="{data.state=='OPEN'}"/>
            <component:IconButton iconUp="{ViewValidatedFeedback}"
              visible="{data.state=='CLOSED'}"/>
            </s:Group>
            <s:Label width="40" text="{data.page.id}"/>
            <s:Label width="100" text="{data.category.name}"/>
                    </s:HGroup>
            <s:HGroup horizontalAlign="left" paddingLeft="30">
            <s:Label width="40" text="!!"/>
            <s:Label width="100" text="{resourceManager.getString('editor', 'printView.author')}"/>
            <s:Label width="90" text="{resourceManager.getString('editor', 'printView.date')}"/>
            </s:HGroup>
            <s:List id="commentList" itemRenderer="com.tecfa.tseo.theme.tecfa.editor.print.PrintTaskCommentItemRenderer"
            borderVisible="true" dataProvider="{data.comments}" width="600" >
            <s:layout>
            <s:VerticalLayout paddingLeft="30" />
            </s:layout>
            </s:List>
            </s:VGroup>
            </s:MXDataGridItemRenderer>
            • 3. Re: Flex PrintJob
              Check the measuredHeight.  I'll bet it isn't right.  It doesn't look like
              you have enough height constraints to get it to calculate correctly.
              • 4. Re: Flex PrintJob
                solapola Level 1
                Yes! that was the problem..
                I have to use something like this :
                view.width=printJob.pageWidth;
                view.height=printJob.pageHeight;
                Now is not detecting when to start new pages in the validNextPage maybe because I'm using skins, but that's another problem..
                Thanx a lot
