I am trying to put an android aplication working on the android emulator.
I have developed it in Flash Cs5, then i have created the apk file and installed it on the emulator.
The emulator has the adobe air for emulator installed.
When i try to run the app it gives my "the application ... has stoped unexpectedly. Please try again".
The aplication has a simple square.
When i write ./adb loga car, i have the following errors:
I/ActivityManager( 66): Start proc air.Final1 for activity air.Final1/.AppEntry: pid=1082 uid=10031 gids={3003}
D/TabletStatusBar( 258): lights on
D/dalvikvm( 1082): Trying to load lib /data/data/com.adobe.air/lib/libCore.so 0x4063abc0
I/WindowManager( 66): Setting rotation to 3, animFlags=1
I/ActivityManager( 66): Config changed: { scale=1.0 imsi=310/260 loc=en_US touch=3 keys=2/1/1 nav=3/1 orien=P layout=0x10000014 uiMode=0x11 seq=18}
D/Tablet/NotificationPanel( 258): notificationCount=0
W/dalvikvm( 1082): No implementation found for native Lcom/adobe/air/AndroidActivityWrapper;.nativeSetVisible (Z)V
W/WindowManager( 66): Window freeze timeout expired.
W/WindowManager( 66): Force clearing orientation change: Window{40c41db0 air.Final1/air.Final1.AppEntry paused=false}
D/AndroidRuntime( 1082): Shutting down VM
W/dalvikvm( 1082): threadid=1: thread exiting with uncaught exception (group=0x40014760)
E/AndroidRuntime( 1082): FATAL EXCEPTION: main
E/AndroidRuntime( 1082): java.lang.UnsatisfiedLinkError: nativeSetVisible
E/AndroidRuntime( 1082): at com.adobe.air.AndroidActivityWrapper.nativeSetVisible(Native Method)
E/AndroidRuntime( 1082): at com.adobe.air.AndroidActivityWrapper.SetVisible(AndroidActivityWrapper.java:651)
E/AndroidRuntime( 1082): at com.adobe.air.AndroidActivityWrapper.onSurfaceInitialized(AndroidActivityWrapper.java:614)
E/AndroidRuntime( 1082): at com.adobe.air.AIRWindowSurfaceView.surfaceChanged(AIRWindowSurfaceView.java:438)
E/AndroidRuntime( 1082): at android.view.SurfaceView.updateWindow(SurfaceView.java:571)
E/AndroidRuntime( 1082): at android.view.SurfaceView.access$000(SurfaceView.java:84)
E/AndroidRuntime( 1082): at android.view.SurfaceView$3.onPreDraw(SurfaceView.java:173)
E/AndroidRuntime( 1082): at android.view.ViewTreeObserver.dispatchOnPreDraw(ViewTreeObserver.java:590)
E/AndroidRuntime( 1082): at android.view.ViewRoot.performTraversals(ViewRoot.java:1325)
E/AndroidRuntime( 1082): at android.view.ViewRoot.handleMessage(ViewRoot.java:1944)
E/AndroidRuntime( 1082): at android.os.Handler.dispatchMessage(Handler.java:99)
E/AndroidRuntime( 1082): at android.os.Looper.loop(Looper.java:126)
E/AndroidRuntime( 1082): at android.app.ActivityThread.main(ActivityThread.java:3997)
E/AndroidRuntime( 1082): at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime( 1082): at java.lang.reflect.Method.invoke(Method.java:491)
E/AndroidRuntime( 1082): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:841)
E/AndroidRuntime( 1082): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:599)
E/AndroidRuntime( 1082): at dalvik.system.NativeStart.main(Native Method)
W/ActivityManager( 66): Force finishing activity air.Final1/.AppEntry
W/WindowManager( 66): Failure taking screenshot for (135x84) to layer 21045
W/ActivityManager( 66): Activity pause timeout for ActivityRecord{4073f990 air.Final1/.AppEntry}
D/dalvikvm( 66): GC_EXPLICIT freed 498K, 49% free 13968K/27015K, paused 60ms+18ms
W/ActivityManager( 66): Launch timeout has expired, giving up wake lock!
W/ActivityManager( 66): Activity idle timeout for ActivityRecord{4073f990 air.Final1/.AppEntry}
D/dalvikvm( 1070): GC_EXPLICIT freed 10K, 9% free 16186K/17671K, paused 9ms+5ms
I/WindowManager( 66): Setting rotation to 0, animFlags=1
I/ActivityManager( 66): Config changed: { scale=1.0 imsi=310/260 loc=en_US touch=3 keys=2/1/1 nav=3/1 orien=L layout=0x10000014 uiMode=0x11 seq=19}
W/ActivityManager( 66): Activity destroy timeout for ActivityRecord{4073f990 air.Final1/.AppEntry}
W/WindowManager( 66): Force clearing orientation change: Window{40745e50 Sorry! paused=false}
W/WindowManager( 66): App freeze timeout expired.
W/WindowManager( 66): Force clearing freeze: AppWindowToken{41524680 token=ActivityRecord{4073c818 com.android.launcher/com.android.launcher2.Launcher}}
I/InputDispatcher( 66): Dropped event because it is stale.
i hope someone can help
Thank you
Did you create your apk file using Flash Builder Burrito? If yes, Flash Builder Burrito does not support emulators. Packages created with Burrito are only intended to run on pyshical devices.
-Sedat Akkus
they do, however, run just fine on Honeycomb (API level 11) emulators
Yes, i am using burrito.
I have tried to test the app on a real mobile device and it works perfectly.
