8 Replies Latest reply: Mar 18, 2011 7:31 AM by Adam Cameron. RSS
    Calling an Oracle Stored Procedure.
    ilssac Community Member
      Stored procedures have always given me trouble, I'm not sure why.
      I want to call an Oracle Stored Procedure from a piece of CFML code.
      My CFML code:
      <cfstoredproc datasource="purload" procedure="PUR_XML_LOAD.load_raw" returncode="yes">
          <cfprocparam cfsqltype="CF_SQL_FLOAT" value="999" type="out">
      </cfstoredproc>
      The error I am getting:
      [Macromedia][Oracle JDBC Driver][Oracle]ORA-06550: line 1, column 18:
      PLS-00306: wrong number or types of arguments in call to 'LOAD_RAW'
      ORA-06550: line 1, column 7:
      PL/SQL: Statement ignored
      Test PL/SQL code that works in Oracle SQL Developer:
      DECLARE
       foo NUMBER :=999;
      begin
        PUR_XML_LOAD.load_raw (foo);
        dbms_output.put_line('>' || foo || '<');
      end;
      The top of the stored procedure:
      create or replace
      PACKAGE BODY PUR_XML_load AS
         -- *** PROCEDURE: PUR_XML_load ***
         -- Loads values from previously-validated XML file
         -- into the raw_pur table
         PROCEDURE Load_raw (res_val OUT NUMBER)
         AS
      So how can I make the CFML code function the same way as the PL/SQL code?
      TIA
      Ian
        • 1. Re: Calling an Oracle Stored Procedure.
          Dan Bracuk Community Member
          Make sure you have the correct value for the type attribute in your cfprocparam tag.
          • 2. Re: Calling an Oracle Stored Procedure.
            I've tried all three types, 'In, Out, InOut".  I get the same error for each one.
            This does not seem to be that hard.  There is only one paramter and it is a 'Number' type, which the chart tells me should be equivalent to "CF_SQL_FLOAT".
            • 3. Re: Calling an Oracle Stored Procedure.
              Adam Cameron. Community Member
              I hate to say it, Ian, but RTFM!
              You've specified it as an OUT param, but you're not saying what variable to put the result into.  And you're passing a value IN to it.
              Don't you want something like:
              <cfprocparam type="out" variable="myVar" cfsqltype="as apporpriate">
              I'm surprised CF ain't just syntax-erroring on that (this in itself is a bug, in my view), even before passing it to JDBC.
              Adam
              • 4. Re: Calling an Oracle Stored Procedure.
                All right:
                This WORKS:
                <cfquery datasource="purload" name="foobar">
                   DECLARE
                     foo NUMBER :=999;
                   begin
                   end;
                </cfquery>
                This DOES NOT WORK:
                    <cfprocparam cfsqltype="CF_SQL_FLOAT" value="999" type="in|out|inout">
                </cfstoredproc>
                Yes, I mean each of the three values for type does not work, not that I tried to put all three values into the type parameter at the same time.
                So what is the difference?
                • 5. Re: Calling an Oracle Stored Procedure.
                  Adam
                  To be fair, I had the Manual open in the tab preceding this tab.
                  Adding the variable property did not change the behavior.  I am still getting the same error.  I tried as many permutations of which I could think.
                  • 6. Re: Calling an Oracle Stored Procedure.
                    OK, maybe you're RTFMing, but maybe RWAS (Read What Adam Said) ;-)
                    Does THIS work:
                    <cfstoredproc datasource="purload" procedure="PUR_XML_LOAD.load_raw">
                        <cfprocparam cfsqltype="CF_SQL_FLOAT" variable="myresult" type="out">
                    </cfstoredproc>
                    Adam
                    • 7. Re: Calling an Oracle Stored Procedure.
                      Ok Adam, now WHY does that work?
                      How is that equivalent to the PL/SQL code I was trying to replicate?
                      DECLARE
                      foo NUMBER :=999;
                      begin
                      end;
                      Looking at that code, it seems to be passing IN a value, is it not?
                      • 8. Re: Calling an Oracle Stored Procedure.
                        You're not really passing anything in, you're providing a variable name to put a result in.
                        Think of it like the NAME attribute of a CFQUERY tag, eg:
                        <cfquery name="q">
                        You're not passing q in, you're telling it to put the result into q.
                        Adam
